It is currently Wed Jul 01, 2015 10:13 am
Post a new topicPost a reply Page 1 of 3   [ 56 posts ]
Go to page 1, 2, 3  Next
 Post subject: Got Me a Datsun 210
PostPosted: Thu Nov 21, 2013 11:16 pm
ITB's are not what i will use as i am going to do dual side draft solex carbs, but it will look very close to it, and a custom made header i will be fabricating for it after i do the engine swap in it this should be up and running by summertime, hopefully.
 Post subject: Re: Got Me a Datsun 210
PostPosted: Thu Nov 21, 2013 11:21 pm
Here is the look i am looking for, but without the body kit and 15 or 17 inch wheels that fit perfectly no hella-flush crap in my cars!!
PostPosted: Thu Nov 21, 2013 11:22 pm
Wheels wheels wheels!
These are my choice for now!
PostPosted: Sun Nov 24, 2013 6:34 pm
Cleaned and put together the front end!
PostPosted: Sun Nov 24, 2013 6:48 pm
Please, Please, Please.... tell me you're going to keep those awesome "210" decals down the sides... :D
Soooooo retro!! 8)
I'd love to get some old Datsun to keep my '77 Trueno company... :wink:
Best Regards,
Anders.
PostPosted: Sun Nov 24, 2013 9:04 pm
if that was mine one of the first things id look into is some jdm bumpers
A-Series POWAH!!
PostPosted: Sun Nov 24, 2013 9:24 pm
Both advises above are a yes and a MUST!
Thanks guys!
here is what i was trying to get from Japan!
PostPosted: Mon Nov 25, 2013 5:34 am
Why not keep the ITB's? What are the spec's on the motor?
PostPosted: Mon Nov 25, 2013 3:10 pm
i want to keep it non EFI, something different than the usual SR20,
The engine is all stock 145 to 165 JDM first gen SER powerplant, maybe a upgraded sr16 hi comp pistons head port tomei solid lifter rev kit and hi rev cams will be ready by the time i need to rebuilt the engine, but way down the road!
PostPosted: Wed Nov 27, 2013 12:54 pm
Ok here is somethin i do last nighet when imsomnia attacks,
Went downstaresand start mocking up the engine tranny combo,
If you are familiar with Nissan u must know SR20 block castings are different from FWD to RWD
But u can use the FWD one in RWD with some modifications but you cant do the other way around!
You need to trim all that to get the RWD starter on its place,
Then in order to atach the tranny on that side a heavy duty bracket need to be fabricated, and that bracket is bolted to the side of the block and goes back to the tranny bellhousing under the starter, this bracket must be minimum 3/8 thick steel or 1/2 inch aluminum,
It will be cool and super strong, this way any SR20 block could be used and i dont have to be obligated to use the ABUSED RWD blocks only!
Ps
By the way those mods is only on the starter side cuz the other side it a prfect fit!
Pss
And Just in case you guys ask or worried about the amount of material to be removed from the block,,,
Is not that much for real, the RWD casting do not have the starter ring whatsoever and the only difference is the lower ear for bellhousing attachment is in a lower position, thats it, i am just replacing the lower ear with a fabricated bracket that bolts to the engine block next to the motor mount bracket and maybe 3 or 4 oil pan bolts all together,
I do drill one hole on the tranny bell to acomodate the top right hand bolt and use a spacer betwine the tranny bell and the engine cuz the bell is hollow there,
But here is a rugh sketch of what that bracket will look like!
By the way the top bracket is not necesary but i just trow it out there just in case someone ask!
PostPosted: Sat Nov 30, 2013 3:40 pm
Free 14x6 Appliance wire mag wheels
Cleaned and paint em dark bronze, this will do for now!
PostPosted: Sun Dec 08, 2013 11:42 pm
here is some nice wheels someone send pictures to me,
Atara Racing, they are watanabes knock offs but they got something i like that i dont like in the watanabes and i cant figure it out yet!
PostPosted: Sun Dec 08, 2013 11:52 pm
here are they mounted on a Datsun B310 Station Wagon!
PostPosted: Tue Dec 10, 2013 10:44 pm
Score a NEW OEM EDM Grill!
PostPosted: Mon Dec 16, 2013 10:20 am
Look forward for updates on the engine/ tranny mating work...any particular reason for going FWD engine/RWD tranny instead of a complete RWD set up? what are your plans to address the distributor/ firewall clearance?
PostPosted: Mon Dec 16, 2013 2:58 pm
Good question here,
Reason to this is cuz engine comes with the car, also i was thinking by doing it this way i dont have to be obligated to just the RWD engine plus the FWD ones are less abused and easy to obtain in better conditions, doing it this way i can use both castings with no worries on which one i could find first.
On the distributor i will make a modification on the firewall, to fit it, i have done it many times with other swaps i have done before like the 20 valve 4ag in many AE86 and TE72 ext ext.
Something like this more or less!
PostPosted: Thu Dec 19, 2013 7:20 am
toyota1515 wrote:
Good question here,
understood....I have never really gave this swap any thought so i really want to see the out come.
PostPosted: Mon Dec 23, 2013 3:42 pm
New grill just arrive today from Denmark AWESOME, chrome trim deleted, 5 Philips head bolts and is in, wont do grill 1/4 light till i am 100% sure i cant get the JDM bumpers!
PostPosted: Fri Dec 27, 2013 2:43 pm
here is the block already cut and with the tranny and starter installed,
next will be the bracket fabrication, to make this work the way it should!
PostPosted: Thu Jan 09, 2014 8:26 pm
Here is what a friend of mine find for me in Dominican Republic!
Look like This year start up good,
The rear JDM small bumper is found and paid for and the Front one still on the search but with a lead already by my same friend!
