It is currently Mon May 25, 2015 12:47 am
Post a new topicPost a reply Page 2 of 3   [ 51 posts ]
 Post subject: Re: Docaam 72 2000GT Skyline, GC10
PostPosted: Sun Jan 05, 2014 11:05 pm
Awesome good news to see you can use RHD in Dubai
PostPosted: Mon Jan 06, 2014 10:33 pm
Doc wrote:
nice build!
pictures say more than words (see my own thread :mrgreen: )
What happend with the alignment :shock:
camber is a good thing, but only if it is negative :mrgreen:
keep us updated ;-) :tu:
Alignment will be done way in the end, as suspension and engine is still out
Suspension work is all done, coil over experiment worked and came out great, rest testing that will be after engine is in and check the spring load.
The struts were cut and piece with billet steel made to be welded and have a thread on top, then a sleeve to go on the billet part from lower end and will take the coilover from top, gives height adjustment as well.
Here all parts
Cutting the struts
Welding it
For top custom plate with same holes as stock upper mount from outside but inside same as stock coils so was replaced.
So final outcome from this before
to THIS
For rear just installed the suby ones as is, will get it painted once cars gets paint as needed to move the car now, there will be two springs one on the coils and other stock one which came cut from Japan.
Tie rod ends are fixed as well came out similar size to hako
The end bushes were replaced filled with grease as well
Before
Now
As finishing the front suspension so got some brake pads which will fit Hako as well
As said earlier sent all bolts, locks of hood, trunk, hood hinges, headlight rear trims, fuel line and some other misc for galvanizing to get it cleaned up and rust free came out good not great but will serve the purpose.
got some brass bolts to go along with some of these engine parts.
Now will fit all engine parts and try to start the engine as all engine suspension job is done repaired or replaced except rear control arms, in the meanwhile push the bodyshop guys to finish the bodywork to have the car on the road before summer
1972 240z Project RBZ
1972 Skyline GC10 Hakosuka
2011 Sykline V36/G37s
PostPosted: Tue Jan 14, 2014 2:43 am
Engine all bolted up, looking great, might look at cam cover again once engine is dropped in, now bolting up the gearbox in a day or two and start the engine to check if everything is ok.
Front suspension parts all bolted up which is a good news as tie rod ends was from other cars, but with few washers everything looks good.
Now waiting for the bodywork guy now to start his work
PostPosted: Wed Jan 22, 2014 1:07 am
Started the engine, ran great with good compression
https://vimeo.com/84742916
Not sure how to embed it
PostPosted: Wed Jan 22, 2014 10:23 am
Amazing job on that engine. Can't wait to see what you do with the rest of the car, keep up the good work.
私♥フェアレディ・ゼット - 1984 Z31 300zx
PostPosted: Sun Aug 31, 2014 12:52 am
Reviving the thread with latest updates
There was always a plan to delete the surfline very few go for that in sedan, but mines were rusted and wanted bigger wheels
Cut and installed temp wheels (Atara Racing 15x9 -13)
Took the car for paint job and pending bodywork to Performance Garage
This was done in first one hour impressive all paint stripped
Cleaned up engine bay remove all clips and battery holder (relocate to trunk)
Few days passed by, initial primer
Been shopping for a while, all emblems, all rubbers for doors, glasses lights etc and other misc stuff from Japan
Managed to cut the fender flares for coupe and somehow fit at the back, seems ok so far will know once its lowered
For paint was looking for something in green, finalized these two shades for test panels
Bit lighter in Sun
Test fitment of all panels done
As per the plan engine bay will be painted then car will be taken to install the engine and finish engine bay then rest of the paint
After blacking out the front dont like paint peeking out from headlights and front grill
PostPosted: Wed Sep 24, 2014 1:03 am
Some more update on the project
Engine installed after painting the engine bay
With new radiator and some other things, might change the engine cam colour later on
Doors, fenders and trunk was painted earlier inside out
Car was sprayed few days back, color came out great was a risky choice but very happy with outcome
This shows the shade nicely with some metallic glitter added
Also wheels on order Glowstar from Starroad in diamond cut finish 15x8.5 & 10.
Next is painting inside and under the car followed by assembly
PostPosted: Wed Sep 24, 2014 5:11 am
Color looks good. Can't wait to see it on the ground with those star road wheels.
PostPosted: Thu Sep 25, 2014 2:57 am
Love the work you've done to this.
Nissan Bluebird SSS Coupe #25 Race Car
http://japanesenostalgiccar.com/forum/viewtopic.php?t=24339
PostPosted: Thu Sep 25, 2014 2:37 pm
Love the wheels, excellent restore job
PostPosted: Sun Nov 02, 2014 9:25 pm
Moving along assembly which is done fine some parts came in, as because of painting all factory stickers (AC/Radiator/tire pressure/Ok seal/oil cap/hood lever/high ocatane indicator etc)were gone got some new and some accessory ones PMCS, Sport corner, commonly used on skylines. Some bigger ones will go inside hood and some on car. Still need to find the right place for these stickers.
New OEM wiper arms and blades
Using current fog lamps on hakotora (WIP) so new of hakosuka
For rear got 14k springs with adjustrer
And got custom Gaz shocks thanks to friend in UK, these are with 20 damper setting and short stroke so wont bottom out when lowered
Send the headlamp frame and front grill for polish then paint
Now final status of hako
Another electric pusher along with stock clutch fan, very high power pusher
All moldings and rubbers installed except inner door wetting
New redline fuel pump and regulator, trunk was painted and gas tank was sprayed flatblack came out very nice
Rear and front bumper refinished, taillight panel needs rechrome but cant find anyone locally to chrome this material
PostPosted: Wed Nov 05, 2014 6:44 pm
If you don't mind me asking, where'd you get all the stickers? I've been looking for a PMCS one for the longest time.
1977 Datsun 280Z
1982 Mazda RX7
PostPosted: Wed Nov 05, 2014 8:14 pm
Where did you get the GT-Ki badge?
PostPosted: Tue Nov 11, 2014 11:42 pm
Rubber soul Japan they have majority of these. If just a PMCS better just get it bade locally there are high res files on the net already.
YAJ one company was selling there some Omori or something
Moving on removed the rear subframe for undercoating and installing rear coilovers
Wash and painted
Whole car undercoated
Sending the car for roof and carpet work as roof liner needed to be installed first then the rear windscreen
All four corners different height :)
Extra fan as pusher for radiator
PostPosted: Tue Nov 18, 2014 7:38 pm
Wow. :shock:
Can't wait to see this finished! :tu: :mrgreen:
PostPosted: Wed Nov 19, 2014 1:59 am
That colour!!! :tu:
Adam
1973 KHGC110 Datsun 240K Skyline Hardtop (Kenmeri) Datsun Racing Team Group C Race Car
^^^ https://www.facebook.com/WestsideKRacing
1975 HGC110 Datsun 240K Skyline Sedan (Yonmeri) Cruiser
PostPosted: Mon Nov 24, 2014 2:03 pm
This is amazing!
Flickr
'72 Hako | '02 NSX
PostPosted: Sun Nov 30, 2014 9:03 pm
Interior and some clean up on engine was done recently
Whole interior relayed gone with fabric roof compared to plastic as in OEM and used some sound dampener then full custom carpet
Custom B pillar covers
Removed the stock fuel lines, changed the coil to MSD, installed Moshimoto radiator overflow tank, changed stock radiator cap with HKS one, new plug leads, polished the strut bar and refinishing of some engine painted as was damaged over a year while engine was lying around.
Changed all the bolts to newer ones in engine bay and front end, had to cut and weld the front coils for height adjustment still I think needs more cutting as cant go lower in setting any further, will look into that after installing all pending body pieces but this is how it sits now.
As of now we are finishing the battery relocation to trunk and final wiring job, car should be ready for registration test sometime next week, getting impatient and cant wait :)
PostPosted: Sun Dec 14, 2014 1:02 am
After quiet some time took some pictures from a camera rather then phone, car is going for registration tomorrow, little work is still there but nothing big can say almost its done except future interior work and installing new wheels and front lip in coming few days.
Engine bay all done only need oil catch can waiting for filter for that, went with Vibrant one.
Interior can live with it for a while till redo it,
See the rear fender flare coming out once the rear door is opened
For cooling purpose some Japanese touch
Added new steering wheels as well
Ordered battery relocation kit came slightly bigger one but still looks clean and good
All fender flares installed except left front one will be installed today all chrome moldings
Stickers installation started :)
PostPosted: Fri Jan 09, 2015 10:07 am
:shock: :tu: 8) :D ...pretty much sums it up for me....impressive work from your team sir!
cron
