It is currently Fri May 22, 2015 1:41 pm
 Post subject: 70` Datsun 1800L C30
PostPosted: Tue Aug 06, 2013 4:33 am
Hey all. Time to make a small contribution to the JNC Datsun garage
Reading about Stevs great resto job on his L30 made me want one of these again,
and when a decent example turned upp for sale, I bought it.
It has some flaws (mostly interior) but cant be too picky since they`re fairly rare.
Drove her 400K home when picking upp and it was great fun.
Slight u-joint noise and leaky gas filler hose, but presice steering and good handling. A bit less grunt than I remember but havent driven one in close to 27? years. Exhaust is mostly homemade and appears too thin pipe has been used.
One muffler is deleted but still fairly quiet.
Any pointers for parts is welcome. JDM taillights would be mean :)
A couple of pics:
i
 Post subject: Re: 70` Datsun 1800L C30
PostPosted: Tue Aug 06, 2013 10:57 am
:shock: that is looking good!
Stev has a great project on his car indeed, i have a C30 myself but thats not looking half as good as this one.
Any plans with it? Or just keep it as is and drive it as much as possible?
Japanseklassiekers!
1970 C30 Laurel
1972 240Z
1973 610 Wagon
1977 260Z
1995 Micra
1999 200SX
PostPosted: Tue Aug 06, 2013 4:46 pm
Thanks, yea looks good on the outside, body`s fairly sound.
Just read your project thread. Will be a mean machine. Time for an update or on a break?
My plans with this one... will depend on whatever parts I stumble across
Will try to keep it on the road as mods / maintenace /repairs are done
Even tho its 43 years old, its a great ride and belongs on the road
Get her tidied upp
Ive got a set of 7x14 melber pentas that might look ok on it
bring the front down a notch but nothing extreme
If a g20 comes along, maybe get a mild cam grind and sidedrafts
build a decent exhaust
look into the suba r160 lsd mod
Saw Stev had found some polybushes so may look into that
Dont like the front seats - worn- wernt good in my previous one either
Any idea if 300zx struts will fit these ?
Anyone know boltspacing of zx steeringarms to strut bolts ?
Cheers
PostPosted: Wed Aug 07, 2013 1:35 pm
Cleaned the enginebay. Not too shabby
Car is resprayed some years ago but not the bay
PostPosted: Wed Aug 07, 2013 6:30 pm
"Too thin" exhaust piping may well be factory original. Nissan used very thin exhaust piping. Aftermarket piping is usually thicker, that's the good news. The bad news is that fitting thicker exhaust tubing to the factory manifolds and mufflers / resonators takes an experienced exhaust system mechanic. It can be done! I had to replace the exhaust down pipe on my 1967 RL411 sedan last year. The correct pipe was never really available as spare parts. After all, Nissan never figured anyone would keep the car longer that 10 years. A good mechanic successfully fabricated a replacement section from "standard" thick wall tubing.
MikeRL411
PostPosted: Fri Aug 09, 2013 2:25 pm
That's looks like a G-series engine.
PostPosted: Sun Aug 11, 2013 10:10 pm
its a G18
Japanseklassiekers!
1970 C30 Laurel
1972 240Z
1973 610 Wagon
1977 260Z
1995 Micra
1999 200SX
PostPosted: Mon Aug 12, 2013 5:10 am
Yea, G18 1815cc. Your G20 would look good in there :roll: :lol:
PostPosted: Thu Sep 19, 2013 7:17 am
Did a bit of comparing of c30/280zx struts before the forum collapse - this is going from memory so..
same strut tube diameter 51mm
same disc to strut angle 10,1 - 10 deg.
same steeringarm to strut bolt spacing - about 80mm
Different spring O.D, zx is wider
different diameter hub center 73 ? - 64mm?.. not sure about those figures
complete zx strut with brake weight is about 29 kg
brakes of zx are to big for 13" rims - looked like 14" will work
some brake shots:
PostPosted: Thu Sep 19, 2013 5:36 pm
Most people either remove the spring seat for threaded collars, or remove it and weld the stock spring seat onto the 280ZX strut. :tu:
That's a good thing. Means bigger, beefier bearings too.
They came stock with 14" wheels, and I have yet to come across a 14" wheel that doesn't fit. :tu:
FYI, there are a handful of 13" wheels that do fit, and a few more if you're willing to grind on the caliper a bit. :P
PostPosted: Thu Sep 19, 2013 5:37 pm
Also, it will most likely narrow the front track width about 1/2" per side. Keep that in mind when wheel shopping. :tu:
PostPosted: Sun Sep 29, 2013 2:42 am
Thanks for info John
Will keep an eye out for suitable spring seats as I want to keeep original struts unmolested.
Bigger bearings sound better . On my old c30 I renewed all wheelbearings and drove 150000km with 30mm slipp-on spacers , bolt extenders :roll: and 180B sss wheels without problems so originals aren`t bad either.
Didnt have a suitable wheel available so couldnt measure backspacing differece
but will check before buying wheels.
PostPosted: Sun Sep 29, 2013 12:19 pm
found some pre facelift jdm tailights. Needs tlc tho
PostPosted: Sun Sep 29, 2013 2:29 pm
nice, i have a set of them too!
Japanseklassiekers!
1970 C30 Laurel
1972 240Z
1973 610 Wagon
1977 260Z
1995 Micra
1999 200SX
PostPosted: Tue Apr 08, 2014 10:46 am
Out of Storage for Seasons first drive
http://imagizer.imageshack.us/v2/640x48 ... 3/s8zf.jpg
PostPosted: Sun Apr 13, 2014 8:34 pm
What a thoroughly cool ride! 8)
Can't be many of these left in Norway. I certainly don't recall having ever seen one back home in Denmark...
Best Regards,
Anders.
