It is currently Sun May 19, 2013 3:55 am
Post a new topicPost a reply Page 1 of 2   [ 34 posts ]
 Post subject: DR30 guys, s13 coilovers help.
PostPosted: Thu Jun 23, 2011 2:08 pm
Can any body give me a quick rundown of what is needed to get s13 coilovers to fit a DR30? Any pictures, links or help would be much appreciated.
'71 4 DOOR 510
'83 DR30 SKYLINE
'03 350Z TWIN TURBO
'07 MAZDA 3 HATCH
'09 ACURA RDX
 Post subject: Re: DR30 guys, s13 coilovers help.
PostPosted: Thu Jun 23, 2011 9:31 pm
http://www.skylinesaustralia.com/forums ... -skylines/
I think its covered in the classic skylines section of Skylines Australia.
PostPosted: Fri Jun 24, 2011 12:56 am
Hey mate
Mines done it's easy you just need s13 front hubs and a drill for the rear top mounts.
Try getting r32 or 33 front brakes if you can ... The tie rods won't fit but you can die grind them or getting aftermarket ones but seriously easy job and it helps the handling no end.
Marc
PostPosted: Fri Jun 24, 2011 6:28 am
thanks guys that helped a lot!
'71 4 DOOR 510
'83 DR30 SKYLINE
'03 350Z TWIN TURBO
'07 MAZDA 3 HATCH
'09 ACURA RDX
PostPosted: Fri Jun 24, 2011 7:44 am
Dav if you do this document it too. This is a mod I was thinking of doing along with a RB20 tranny swap.
PostPosted: Fri Jun 24, 2011 1:25 pm
I have a photo series of mine when I did them if you think it would be valuble here?
PostPosted: Fri Jun 24, 2011 1:41 pm
Ya that would be great .
PostPosted: Fri Jun 24, 2011 2:50 pm
I am starting to collect parts for this hopefully I should have it done in a few weeks. I am having some one help me out so I will try to document as much of it as I can and do some sort of write up about it.
'71 4 DOOR 510
'83 DR30 SKYLINE
'03 350Z TWIN TURBO
'07 MAZDA 3 HATCH
'09 ACURA RDX
PostPosted: Thu Aug 04, 2011 9:47 pm
So The coilover swap is done. I actually didn't do any of the work so I have no pictures of the process. The parts used were stance GR+ coilovers, S13 front knuckles, hubs, front brake calipers and rotors. The car handles much better, and actually absorbs bumps better too. The OEM suspension was toast. It needs an alignment but before I do that I need to source some new inner and outer tie rod ends and ball joints.
And this is how the car sits now.
If anyone wants me to crawl under the car and take pictures of certain items I would be more then happy to.
'71 4 DOOR 510
'83 DR30 SKYLINE
'03 350Z TWIN TURBO
'07 MAZDA 3 HATCH
'09 ACURA RDX
PostPosted: Fri Aug 05, 2011 12:31 am
Looking good :tu:
Cant see anyone fitting under that to take photo's, I'm built like a bamboo pole and still cant get under mine :lol:
PostPosted: Fri Aug 05, 2011 6:29 am
Good info. Slightly off topic but since we are on the topic of s13 struts and the Aussie guys are posting. Do you guys know if s13 struts will work on c110 W/out major mods? Since c110 are somewhat common out there figured I'd ask.
Thanks guys
http://www.HistoricJ.com
PostPosted: Fri Aug 05, 2011 7:11 am
Ya maybe a few photos of it with the wheel off.
PostPosted: Fri Aug 05, 2011 8:02 am
Yes, Pics please :)
Brody
1983 DR30 Skyline- fun time?
2006 Subaru WRX- Race car
2008 Subaru STi- Daily driver
PostPosted: Fri Aug 05, 2011 8:53 am
Ok I'll try to get some wheel off pictures this weekend. If I can't do it this weekend ill do it next week some time for sure.
'71 4 DOOR 510
'83 DR30 SKYLINE
'03 350Z TWIN TURBO
'07 MAZDA 3 HATCH
'09 ACURA RDX
PostPosted: Fri Aug 05, 2011 12:11 pm
ya. some with the wheel off and with it turned. I want to see how it mounts. Also if you can get a shot of how your control arm look from the front. Are they parallel with the ground or angled up or down?? What set up were you running before you changed? (lowering srpings, cut springs, homemade coilovers, etc..)
PostPosted: Sat Aug 06, 2011 3:39 pm
good stuff.. luckly mine came with suspension.
http://DonaldJackson.TeamMNR.com
PostPosted: Sun Aug 07, 2011 1:01 am
Nice, thats exactly what I was planning on doing with my DR30, I imported a set of Stance GR+ for my MX5 a couple of years ago and I've been really happy with them, so was thinking about a matching set of S13 GR+ for the DR. Only problem is that they ended up being bloody expensive after shipping, duty and GST, although our dollar is quite a bit stronger against the US dollar now which would help a bit
PostPosted: Sat Aug 13, 2011 12:53 am
Ok so here goes with some help and photos!!
step one..
you will first need to source some s13/s14/a33/c31 front knuckles s14 is best if you want 5 stud.. in my build im using s13 + r32 GT-R Brakes..
find your brakes make sure they fit
next step get coilovers for an s13 pic just an idea
the rears you will find to be a little to long if you want it super low..
as with my car and maybe others you may find that the rear upper shock mounts need to be changed or the mount points redrilled i redrilled mine (no photos sorry)
next you need to remove your old struts the rears bolt strait in, aside the above mentioned top mount.
Front.. you first off remove the strut first remove the tie rod ends with a ball joint/taper splitter then remove the bottom two bolts facing upward do both sides first as the Swaybar holds the lower control arms (LCAs)up then remove the brake line bracket followed by removing the brake hose from the back of the calliper undo the three retaining bolts under the bonnet and then remove the strut..
left behind you will see the LCAs with a steering knuckle attached to the lower ball joint again use a ball joint splitter to remove the r30 knuckle.
now your ready for install!!
with the lower ball joint now exposed you simply fit the s13 knuckle onto it and do the bolt up! you then bolt in your s13 struts into the upper mount 3 nuts..
now you will need to go to a suspension shop or a wrecker and get some clevis bolts and nuts (the clevis attaches the bottom of your strut to the new s13 knuckle
you then fit your wheel bearing, brake disc, brake hose and tie rod end
your tie rod end will not go into the taper ot the s13 knuckle far enough to get a split pin through the castle nut you can get after market tie rod ends or get a nilock nut or die grind the taper slightly all of these ways work fine..
from there select your on level of slamadge!!!
PostPosted: Mon Apr 09, 2012 8:11 pm
It looks like you used 300zx tt front calipers. If so what rotors did you use to keep the four lug?
PostPosted: Tue Apr 10, 2012 4:15 am
wonder if this would work on a KGC10???
why does the skylines australia site have to be down :(
