It is currently Tue Jan 27, 2015 2:00 pm
Post a new topicPost a reply Page 3 of 4   [ 76 posts ]
 Post subject: Re: S30 Project RBZ
PostPosted: Mon Jan 14, 2013 4:05 am
very very nice!!! for the horn button try some double sided tape. it'll wedge it in there and help it stay put at the same time. just be sure you maintain the contact point still so your horn works
PostPosted: Sat Jan 26, 2013 12:07 pm
Installed the Nardi steering wheel to finish it off the interior some little things pending though
Some pictures i took, car was a bit dirty though.
After driving some issues are coming up, like
1. Brakes not taking enough pressure
2. Some heat coming from from the gearbox opening
3. Clutch pedal needs a bit of alignment
4. Exhaust is too low might need working on gearbox mounting and move the exhaust up
5. Steering rod had some problem during alignment time running -1.7 camber on one end and -1.1 on other will be fixed soon
Coils, some trunk emblem, speedo GPS module and fuel sender are on order will be replaced next week. Apart from this car drives very nice suspension if a bit stiff i guess will loosen up after some driving.
1972 240z Project RBZ
1972 Skyline GC10 Hakosuka
2011 Sykline V36/G37s
PostPosted: Sat Jan 26, 2013 12:10 pm
Awesome Aamir :tu:
PostPosted: Sat Jan 26, 2013 12:18 pm
ToolZ wrote:
Awesome Aamir :tu:
:tu: could be better or better yet to come
PostPosted: Mon Jan 28, 2013 5:56 pm
Coming along really well, the car looks superb!
1975 C110 Skyline Coupe
PostPosted: Tue Feb 26, 2013 11:36 am
Small video testing the gopro
[/url]http://youtu.be/pTpRYrKlJVY[/url]
PostPosted: Tue Feb 26, 2013 2:20 pm
very nice job 8)
PostPosted: Tue Mar 05, 2013 3:22 am
Lots of work has been done, changed the brake booster, custom fitted one from some Mitsubishi pickup, fitted nicely on 1" willwood brake master cylinder. Sorted out the gear mounts and downpipe, some dropping in the front on right side it bottom out already seems like fenders flares might not be installed properly or some other issue.
Installed custom door sills
Had some stickers lying with me which I ordered at different times stuck those
Datsun and Cusco
Project X workshop just repping them for a while
Cusco rear strut
Old school :)
JAF and a tricky JNC (courtesy to Toolz)
PMC-S, Prince motor-sports some might not feel this on a Z but I love it
One more along with repping :tu: JNC in Dubai
PMC-S inside on console
Speedcorner
Last found an old one lying around perfect!
Exhaust all sorted
Almost final height, already bottom out in front right side
Left front side seems a bit more lowered but its more to do with the way flares are installed
Next up is changing the downpipe this week ,then installing coils on weekend a do the final tune along sorting out AC ducting.
PostPosted: Tue Mar 05, 2013 4:04 am
:tu: :tu: :tu: :tu:
PostPosted: Wed Mar 06, 2013 6:36 am
Perfect bro. this is one of the best Resto-Mod 240Z i have seen. Good job and keep it up.
:tu: :tu: :tu:
PostPosted: Fri Mar 15, 2013 1:04 am
Crank and Pistons feature of the Z
1972 Datsun S30 RB-Z. Al Ain, UAE | Crank and Piston Car Culture Lifestyle Community
More and wallpaper shots on the website
PostPosted: Sun Mar 17, 2013 12:34 pm
beautiful build props to you its incredible
:mrgreen: :tu:
PostPosted: Tue Mar 26, 2013 3:44 am
Very nice!
What is the brand of those seats? OMP? I have been looking for a suitable set of seats for my z. I already had a pair of glassfibre buckets, but those were impossible to mount low enough. I am 186 cm tall and it was impossible to wear helmet with those seats..
Did you modify original floor and mounting points?
C10 Nissan 2400 GT -72
RLS30 260Z -74
C210 Skyline 240 GT 2door ht -80
PL510 1600 -71 4 door sedan
Toyota Land Cruiser BJ45 Troop Carrier -83
G160 Datsun Patrol short safari -81
C32 Nissan Laurel 2.4e SLX -88
PostPosted: Sun Mar 31, 2013 2:43 am
260z wrote:
Very nice!
Hi, got it through a friend here he owns some car parts shop, according to him these are done by same manufacturer who also do contract manufacturing for OMP and some recaros.
These sit as same level as stock ones Im 176 and there is still room over my head but havent tried it yet with a helmet
PostPosted: Sun Mar 31, 2013 3:29 am
Some work done in past few weeks
Changed the coils, plugs (thought plugs were changed in previous workshop), installed GPS module for the autometer speedo as had problem in getting signal from the gearbox and also installed the autometer fuel center unit.
Plugs, no idea how the car was running and even tuned on these, I did ask the workshop when installing other things to change it got back to them and they said politely ohh we forgot :td:
Got NGK BCPR7ES aka 3330
Old fuel sender which came with surge tank out
Was broken thats why gauge always showed FULL :roll:
Autometer one height adjusted and there it goes in
Autometer GPS speedo interface, peace of mind now accurate reading regardless of tire/diff sizes
Splitfire coils for Neo
Time for these to go out
Old vs New
Done
Plugged and ready to fire
Took the car to a local meet and did shoot with some 350z and 370z
Burj Khalifa (tallest tower in the background ;)
PostPosted: Sun May 05, 2013 10:11 pm
Top Performance magazine did a feature on the Z, published in their May issue
More pics and details in the magazine its free and can be downloaded here:
http://www.performancemag.net/home/
PostPosted: Sun May 12, 2013 10:15 pm
Got some pictures from the feature off
http://www.motoringme.com/features/modi ... tsun-240z/.
PostPosted: Sun May 26, 2013 2:39 am
Ok project moving in another phase Engine SWAP. As people on some forums know I sold my current setup with everything including radiator, ecu etc.
I was planning for a while to swap RB25/30 NA setup but after reviewing it a lot working with different heads and lack of upgraded cams in some heads dropped the idea. Moved to VQ35DE/HR for which wiring is a bit of a pain but then couldnt find HR engine and where I found with online wiring service (2k$) and engine cost over all project costs jumped.
So in between talking to few installer came across something unusual and interesting taking it as a challenge.
VQ30DET, its a rare engine same quad cams but block is much stronger then VQ35 and low compression as it comes with a turbo from factory.
As per some forums stock engine is running on 5-6psi and gives around 280hp and turbo can go easily upto 14psi before playing with the wastegate and power can go upto 350ish but still needs to be checked, as people are running cars upto 500whp on stock block and its holding great so there is good potential in the engine. Being a destroked version compared to VQ35 its revs better as well. One other things which my mechanic said engine is without VVT so can change the cam gears as well if needed along with cams maybe for future.
After looking for a while found one here, as per Air flow meter clips seems like came out of 2002-2006 model Nissan Cima here it is
Bought the whole things with 8 speed CVT gearbox lol, and engine mounts sway bars and most importantly ECU and harness.
Was lucky found a CD009 gearbox out of 2006 JDM 350z as well.
Covers removed from engine it needs proper cleaning for sure
There will be alteration needed in cross member, whole exhaust manifold on engine and might need to move the turbo a bit as well.
I opened up the engine so do some colours and for some porting the exhaust and intake inlets, engine was clean but too much slug inthe oil sump seems like car was running on those 30k limited oil, but compression came out good. Only problem was turbo came out broken one fan was missing so will change that from the shop got the engine.
Fan was chocked and one side one is missing, as for the size seems bigger then RB25 turbo more like GT25 series size.
Engine opened up
Intake and TB
Lower intake manifold
These are parts I dropped for chroming will do a contrast in these three, (sample chrome piece on left side ;))
Pulleys as well for chroming
This thread is going to be busy again
PostPosted: Wed May 29, 2013 12:11 am
Did some quick port and polish job done.
Removed cam and timing covers got those chromed first!
Red and black colour was applied on these along with matte and glossy clearcoat to have have some kind of anodized effect in red and other black chrome.
Will be installed once engine is all cleaned up
Removed the old engine and engine bay came out messy, thinking of painting a satin black or sating finish golden while its empty, any suggestions?
Engine mounts are in works, which is the tricky part will update how it goes.
PostPosted: Mon Jun 03, 2013 1:26 am
Removed the Adaptronic ECU little bit of wiring to be removed then previous engine and other stuff will be shipped ti California
Dropped the new engine in to have some measurements for exhaust manifold and custom mounts
Sits way back and intake might touch the hood
Gearshifter braket needs goood 4-5" of cutting to come in place of stock hole as well.
Crossmember is touching the crank case but will move the engine down another 3-4". Will alter the cross member might make a new one and move the radiator close to engine along with AC condenser and Oil cooler. Intercooler will be in same place as before might be longer pipes but wont be close to hot oil cooler.
Parts already ordered will be here in a week's time
1. Griffin Double Pass Radaitor 19" X 24"
2. 16" Flex-a-Lite high majic 3300 CFM puller fan with shroud would need some shroud work, going with single big fan then twins as last time.
3. JWT clutch and flywheel combo
4. Moshimoto Intercooler
5. Moshimoto Coolant reserviour tank
Also converting to power steering as feeling wise stock wasnt that good and crossmember is in works so would be easier to do now. so got these
1. Used 2000 Subaru forester steering rack
2. New outer tie rod ends for 1998 subaru legacy/impreza
3. 84 toyota celica inner tie rod ends
4. Whiteline steering rach & Pinion mount bushes
5. Energy suspension stock steering rack bushes
6. Moshimoto Power steering bottle ;)
There is a DIY to install subaru forester steering rack using celica inner and legacy outer tie rod ends, lets see how it goes.
