It is currently Mon May 20, 2013 2:25 pm
Post a new topicPost a reply Page 2 of 3   [ 58 posts ]
 Post subject: Re: S30 Project RBZ
PostPosted: Mon Nov 19, 2012 8:14 pm
Wow, this is an amazing build! Good work bro.
PostPosted: Mon Nov 19, 2012 10:49 pm
the thread is kind of upto date now
13th Nov 2011
Finally I an say car is in final stage of completion :)
As I did the paint job almost 10 months back and car was roaming from workshop to workshop there were minor damages to paint so found it better to get it resprayed it all over again and move to fixing parts.
It was painted on Thursday and today they were doing polishing, should be done by wednesday and installation of parts will start
I am doing a custom center console in the dash, it was like this
Now I close the whole middle part, it will have the map light then airduct, then different lights and switches along with starter button and then the gauges
There are four LED lights for High Beam, Turn Indicators, Hand Brake & Seatbelt ( had extra so using it), then four switches one for fan, AC, rear defogger and hazzard. I moved the big AC controller in the glove box for a cleaner look.
Middle console I got it repaired was broken in three pieces with cracks. Upper part will have SST audio face and after will have HKS Boost controller. Then both the parts will be wrapped in carbon fiber
I have been collecting lots of small parts over past months
I am changing all the rubbers front windscreen, rear, main door strip, upper door strip, lower door strip and two small rubbers on each corners. Will be changing all rubbers for quarter windows inner, outer and straight one. I also got cowl and three piece hatch rubber kit as well. Rear headlight rubbers seals are there as well and also got window channel rubber from Datsun Bluebird hopefully it will fit as well. So finally everything will be replaced
Also got all OEM Nissan clips and pins and all small rubbers for trunk, hood struts, battery holder, horn, wiper blades etc. Got clear small fender lights and window opener from Singapore
New door handles and hood badge
Also ordered some custom 240z engraved SS kick plates from UK
Old Vs New
For audio there was no place for a normal headunit so I ordered SST Secret Audio unit, its a small display unit and rest goes under the seat and have a radio frequency remote which can operate upto 5 meter distance. It plays radio, SD card, USB and iPod connectivity.
Some stock chrome pieces like AC vent for middle part and Ash tray was in bad shape so did some polishing with Brasso FTW
Before
After one hour of scrubbing and polishing
Before
This still under process as inside part needs to be painted so will spray paint it silver.
Other interior panels had cracks in it as well so I will be repairing it with epoxy resin then sand it and spray matt black.
I have a carpet kit coming on thursday and CF fender flares this weekend as well. Will post more details by this weekend.
16th November 2012
Update from wednesday
Rubbers getting installed
Changes the windscreen moulding as previous one had some gaps though it was new as well
Yellow and red side lamps replaced by JDM white ones
Ashtray painted silver and polished
Custom console piece, on top there will be stock map light and then AC vent
Front lamps with new clear covers and whole casing was cleaned and painted matte white
Was there in the workshop whole thursday getting things done
Installed short throw shifter
Took a lot of work to made it fit as brackets were small so was coming out but managed by making custom brackets
Carbonfiber work was done on center and dash console
As all lights were replaced or refurnished so I open up tail lights as well, will spray silver in the casing and covers were sanded and will be clearcoated
Finally by night time lots of things were on the car, installed the front air dam as well
1972 240z
2011 G37s
PostPosted: Mon Nov 19, 2012 10:50 pm
Updates from Yesterday
Some more work done almost done, hopefully will take it for carpet soon
Went with Toyota Celica Fender mirrors as opposed to Datsun which usually people use, like the length of these and the angle. Painted the stalk black. Front bumper, anfront grill also painted same black installed.
Removed the stock hood lock and installed these pin ones.
Removed the CF spoiler I felt was slightly bigger will check later, tailights were done as well
Center console parts ready as well
Audio headunit with brakcets
Gauges, toggle switches and starter button, LEDs to go in
Meters are a bit tilted towards drivers side
AC vent and stock map light
Seats were installed as well, didnt need any bracket were bolt on stock rails just holes were widened
1972 240z
2011 G37s
PostPosted: Tue Nov 20, 2012 10:06 pm
Sent the car yesterday to the interior shop to do a custom carpet work, door panels in leather/alcantara and might wrap the dash in alcantara. Just some phone pics after it was washed to go, paint job looks good considering its not polished yet.
1972 240z
2011 G37s
PostPosted: Wed Nov 21, 2012 3:09 am
Looking really really impressive mate. 8)
PostPosted: Thu Nov 22, 2012 8:09 pm
Making some nice progress there mate, looking good!
1975 C110 Skyline Coupe
PostPosted: Fri Nov 23, 2012 12:32 am
Looking good Aamir! :tu:
PostPosted: Fri Nov 23, 2012 12:36 am
On your home ground :)
1972 240z
2011 G37s
PostPosted: Fri Nov 23, 2012 12:41 am
I know buddy. I hereby promise to try and free up some time this week to come and shoot the Z.... promise :D
PostPosted: Sun Nov 25, 2012 12:54 pm
very nice, i like the out come so far, the time and effort put in is showing in the results. keep the updates comming, i want to see the final product.
PostPosted: Sun Nov 25, 2012 2:06 pm
FYI, the clear side markers are not "JDM". They are aftermarket pieces. All the stock 240Zs used the same side lights in all markets. :tu:
PostPosted: Sun Nov 25, 2012 10:23 pm
Interior work in under way, as my car had no head liner and carpet so instead of getting stock one, did a customized job here works out much cheaper.
Roof liner and A pillars are done in something like alcantara material which according to the guy is same as used in merc :roll: so far so good.
For carpet just the under liner for sound deadening and carpet over it sticking it at most of the places, its just loose pieces will have a plastic backing and will be in foot well and trunk area.
1972 240z
2011 G37s
PostPosted: Thu Nov 29, 2012 3:37 pm
Interior is all done, car is ready for registration just few small things, left hopefully next week it will be running on the road
View of the seats front front
Center console, might do the gearshifter boot again later
Armrest in alcantara with same stitching as seats
Roof liner and sunvisors
Trunk area carpeting came out very nice
Overall very happy with the quick and clean interior job
1972 240z
2011 G37s
PostPosted: Thu Nov 29, 2012 7:58 pm
Wow. :shock:
Very well done. :tu: :mrgreen:
PostPosted: Thu Nov 29, 2012 8:20 pm
Love it, love love love!
More updates please, heart sank when i was reading and saw there's no videos of it running ;(
Own a Crown? Take an interest into these beautiful cars? Come join the community over at www.toyotacrowncentral.com/forum!
PostPosted: Fri Dec 07, 2012 12:42 pm
nice car, any updates?
I'm just picking here, but I tend to not like autometer gauges in a JDM themed car. Defi or anything else would be more fitting imo. Autometer is great for american cars, but i just dont like them in japanese cars. lol
PostPosted: Mon Dec 10, 2012 8:01 pm
MashaAllah Z is looking very very nice. :tu:
I should be start my build in a years time.
PostPosted: Fri Dec 14, 2012 7:42 am
Its ok man, I found them to be fine and serve the purpose, couldnt find any other 5" speedo guage and infact a full set. I found these better looking with LEDs in the night and everything flows with the theme
Changed the differential finally, thanks to John at Betamotorsports for providing the custom stub axles, Sti diff fitment took 10 mins all bolt on just the drive-train needed the holes to be redrilled
Sti to S30 halfshafts Stub axles
Drive-shaft holes were re-drilled
Cusco rear strut bar fitted, front will fit after all engine work
Was tired of all messed up wiring and VTC was not working as well so went with Adaptronic Standalone ECU for RB25
As the engine theme was black colour so changed coil and cam gear cover to carbon fiber ones.
Car finally has some number plates
1972 240z
2011 G37s
PostPosted: Thu Dec 27, 2012 1:25 pm
As I said earlier when the shop was doing wiring i sent crank covers and intake manifold for polishing, so today everything came back and was installed along with coil pack and camgear covers in carbon fiber
Got this long time back today installed it
Compared to Chinese Nismo one
Replaced
Custom radiator cooling plate not liking it much but will fix it later maybe cut in half and some more bends, was done in aluminium then chrome plating.
Got aluminium covers for headers and turbo plate and removed the stock ones
Coolant overflow tank custom made according to the body curves in aluminium
Chrome cam covers with coil pack cover in carbon fiber
Cam gear cover changed to the carbon one, some changes were required as cover was for series 1 and Neo is slightly different.
Intake manifold installed
With fuel rail
1972 240z
2011 G37s
PostPosted: Sun Jan 13, 2013 10:40 pm
Got the last set of missing parts some new emblems, strut covers, door handles and misc clips and stoppers
for Nadri had to buy both Momo and workbell adaptor still the horn button is loose any suggestions?
After the wiring got the car on dyno (AWD Mustang) but couldn't go above 230-240whp, coils start misfiring, but did the tune and car is running perfect now, pushing around 215-220whp on 5psi. Will change the stock coils, plugs and do a retune after a month or so.
Did a quick cleaning job, all left now is to check the brakes as pressure is very low even after 1 inch willwood brake master cylinder
Installed some generic pedals
Will install Nardi after all the mechanical work, interior is all set now
Installed the front Cusco strut bar cheery of the top for the bay :), loving the engine bay some cleaning of nuts bolts is there but thats more of an ongoing project
Installed spacers front and back fitment is superflush
Front needs a drop but will do once final alignment is done as caster, camber and toe is totally out as well
Courtesy of recovery vehicles :( infact all wheels has big curb marks
Stanced out nice in the end
With my DD, perfect combo of beauty and the beast
1972 240z
2011 G37s
