It is currently Sun May 24, 2015 8:36 am
Post a new topicPost a reply Page 5 of 8   [ 148 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
 Post subject: Re: Detroit Hako Update! Work in progress
PostPosted: Sat Oct 19, 2013 9:32 am
Uploaded with ImageShack.us
New Kicks
New Rad
PostPosted: Sat Oct 19, 2013 9:33 am
PostPosted: Mon Oct 28, 2013 10:21 pm
Glad a great car went to a great home!
PostPosted: Tue Nov 05, 2013 7:25 pm
Jgonzo911 wrote:
Please update with how you tackle this spring assembly. I just picked up a set of power fender mirrors for my S130, unfortunately the spring assembly on the underside are severely rusted. I've tried bringing them back and looked all over for something that matches-to no avail.
BTW-Im out in Ann Arbor. I gotta check out this car sometime. Great job so far. :tu:
PostPosted: Tue Nov 12, 2013 6:15 am
sonethirty-
I have a portable blaster $30 from harbor freight. Blasted the spring till most of the rust is gone then grinded the rest away. VHT Rattle canned it black. Since the car will no longer be seeing any type of rain unless I'm caught in it. its good enough.
My springs on my mirrors were the same way, I did the same process.
PostPosted: Tue Nov 12, 2013 6:17 am
sonethirty- Any big plans for S130?
PostPosted: Tue Nov 12, 2013 12:45 pm
Any updates?
When are you putting it back together :tu: ?
PostPosted: Mon Nov 25, 2013 6:28 pm
Jgonzo911 wrote:
sonethirty-
Thanks, I'll have to try this.
Always big plans for my Z, but it will have to wait until I can afford a place that has garage space for my Z33, ZX and one of our DD's. Until then my father is kind enough to store it in his garage down south. Restored most of it, next is a taking care of a few rust issues-then a quality paint job. I've got a bunch of goodies for it-ill pull it all together after that.
:tu: and lets see updates!
PostPosted: Tue Dec 03, 2013 10:30 am
If you don't mind me asking, what car are the 4-piston calipers off of? Also, what size wheels are you going to use?
1977 Datsun 280Z
1982 Mazda RX7
PostPosted: Fri Dec 20, 2013 9:49 am
:shock:
Your going to have to let me know the next time you have the car out and about. I live up near Flint but would have no problem driving down to the D to check this car out. I am EXTREMELY jealous that you have one and I love that its so close to me. Keep up the good work.
:tu: :tu: :tu:
PostPosted: Sat Feb 01, 2014 11:10 am
Pain in the ass getting New weather strip in place
popsicle stick to the rescue!
All finish with glass in place
PostPosted: Sat Feb 01, 2014 11:35 am
Lots of welding!!!!!
Initial look with paint ahhhhh doesnt seem that bad YA RIGHT if theres a bubble or chip theres way more going on behind the scenes.
So time to peal back some of the previous work from japan... Just to say if theres an overlap patch EVERYTHING behind that patch is still rotting away so all patches must come off! Cleaned, cut out, and re patched properly
rocker patches were nasty!
PostPosted: Sat Feb 01, 2014 11:37 am
Cut out time
rocker replacement fitted up to factory flange
PostPosted: Sat Feb 01, 2014 11:41 am
wheel arch fix... Not exactly how I wanted to fix it but it worked out in the end.
Used three pieces to replace the 10 japanese this Crap pieces
Some partes were rotted bad needed the flanges cut back
PostPosted: Sat Feb 01, 2014 11:48 am
AWWWWWW small bubbles that shouldnt be that bad
Really!!!
YIKES
Still needs much lovin but fixed
PostPosted: Wed Apr 02, 2014 9:30 am
Passenger rocker work in progress
PostPosted: Wed Apr 02, 2014 6:21 pm
PostPosted: Wed Apr 02, 2014 6:36 pm
new rocker extended out
door alighned
rocker welded into place
PostPosted: Wed Apr 02, 2014 6:38 pm
rocker corner welded in place
PostPosted: Wed Apr 02, 2014 6:39 pm
fender rienforced...
