It is currently Wed Jan 28, 2015 2:15 am
Post a new topicPost a reply Page 7 of 8   [ 148 posts ]
Go to page Previous  1 ... 4, 5, 6, 7, 8  Next
 Post subject: Re: Detroit Hako Update! Work in progress
PostPosted: Mon Jul 07, 2014 6:07 pm
Little update...
Welding work complete
PostPosted: Mon Jul 07, 2014 6:09 pm
Driver side was the worse totally rebuild looking pretty good
PostPosted: Mon Jul 07, 2014 6:13 pm
Fuel tank needed a little lovin.
PostPosted: Mon Jul 07, 2014 6:26 pm
New tension rod
New front A-Arm with hiem joint for adjustment. Re welded R180 to R200 mustache bar
old and new heim joint
Front A-Arm powder coated finished up
PostPosted: Mon Jul 07, 2014 6:31 pm
So welding is complete, minus fender nuts being welded so I dont have to rivet the flares to the body
Allen Head screws nut will be welded inside
PostPosted: Tue Jul 08, 2014 1:59 am
I love your approach to this project. I'm very much looking forward to the 'finished' product.
Nissan Bluebird SSS Coupe #25 Race Car
http://japanesenostalgiccar.com/forum/viewtopic.php?t=24339
PostPosted: Tue Jul 08, 2014 12:54 pm
i love the suspension work :tu:
PostPosted: Tue Jul 08, 2014 3:06 pm
Lookin good !
PostPosted: Sun Jul 13, 2014 8:43 pm
Hey man! I've been wondering where your car has been! That's so awesome that you have one here in Michigan, we needed something like that to mix things up. Glad to see it's still around and getting some work done. I can't wait until it's back out on the street. I'll do whatever I have to, to see that out and driving!
PostPosted: Mon Jul 14, 2014 7:37 am
It wont be ready for Woodward... Most likely getting painted within the next couple months and on the road next spring. Its been a Hell of a learning curve and lots of cash has been put into so far.
Still need to get some work done on the Stroker but other then that majority of the work complete
PostPosted: Sat Jul 19, 2014 9:45 pm
Finally pulled front and rear suspension out. Time for some reconditioning...
PostPosted: Sat Jul 19, 2014 9:52 pm
Pulled the hubs off to replace bearings... One bearing sealant gasket torn to shreds
PostPosted: Sat Jul 19, 2014 10:06 pm
New bearings
Time to try to update the brakes and here where the problems begin... Thought it was a plug in play kit yaaaaa right... All bolts needed to be replaced, calipers came with one stripped thread each and no machining on rotors grrrrrrr!!!!
Those nice calipers I got powder coated... Well one thread on each were stripped
So helicoil to the rescue...
PostPosted: Sat Jul 19, 2014 10:14 pm
First problem somewhat resolved...
Issue two) rotors wont fit hub size. Had to check to make sure it was a hako hub... Rotors never got machined!
Grrrrrrr
PostPosted: Wed Jul 23, 2014 11:24 pm
Looking good Jose! :tu:
I thought of you when I saw this car up for sale, your work is 10 times better.
http://www.goo-net-exchange.com/usedcar ... index.html
PostPosted: Tue Jul 29, 2014 5:42 am
Just been through this whole thread and must say I'm impressed with the standard of work and attention to detail.
Seeing how much work you've done has given me confidence as I think my old Cedric shouldn't need anywhere near that amount of bodywork (famous last words)
I've been battling with what colour to go for to be that bit different and your colour samples helped me as well.
I was considering pearl white but after seeing colour 7 of the blue/green tones it has made me rethink my ideas.
Do you have a name for that colour?
Of course it's hard to visualise how a colour would look on the Cedric when the Hako looks fabulous in any colour :-)
PostPosted: Fri Aug 22, 2014 1:32 pm
After mock up on R32 Brakes with Questionable hakosuka strut decided 4mm off the back of the hubb may do the trick. If not will be buying new Coilover and hub Fingers crossed... All the measurements work out should work no problem...
In other news body is coming along SLOWLY!!! At this rate if the car doesnt get painted by Nov, Late fall 2015 will be put back together...
Driver fender has a wierd kink in the door cut line, Will file parallel it to door
PostPosted: Fri Aug 22, 2014 1:56 pm
Out with some old stuff!
Powder coated control arms front crossmember rear crossmember r200 mustach bar
New Swaybar bushings
R200 Like a glove/Modified r180 mustache bar
PostPosted: Fri Aug 22, 2014 2:03 pm
New Ball joints and steering rods
Polished up my camber plates
Little love on my rear shock Repaint new Energy suspension bushings
Sumit racing on hour glass bushing for the top still hasnt arrived yet
PostPosted: Thu Sep 25, 2014 9:40 pm
Anyone suggest a colour code for the last colour?
(Numbered 7 but I think it's 9)
Keen to find a colour similar to this
