It is currently Thu May 23, 2013 9:00 am
 Post subject: steering slop
PostPosted: Sat Oct 27, 2012 1:40 am
i recall a while back we were discussing steering slop reduction by adjusting the steering box, i wanted to see if anyone confirmed the process of adjusting that steering box? I'm not sure if the process would be similar between the Z and the KGC10?
can someone please chime in and give me some ideas?
Please and Thank you!
 Post subject: Re: steering slop
PostPosted: Sat Oct 27, 2012 8:08 pm
Well, Zs don't have a steering box, they are rack and pinion. :wink:
The Skyline has a worm gear steering box, and the adjustment procedure is pretty straightforward. On the top of the steering box you'll see a big nut, with what looks like a slot for a screwdriver on the "bolt" that it's on. You simply loosen that nut, use a screwdriver to tighten that "bolt" down a bit, then tighten up the nut. Not unlike adjusting rocker arms on the engine, there needs to be a tiny bit of slack in it or it will increase wear on the steering box.
This is a steering box from a 1200, but you get the idea...
PostPosted: Sun Oct 28, 2012 3:54 am
Thanks! i will give it a go and see how it works out!
Users browsing this forum: moominsean and 3 guests
