It is currently Wed Jun 19, 2013 1:53 am
 Post subject: F31 build (leopard or infiniti M30) with L28et swap.
PostPosted: Mon Sep 05, 2011 12:49 pm
My F31 nissan just turned 20 so I figured I would post some details of the build here with a few posts to bring it up to the present.
This is cut and pasted from elsewhere and starts about 2 years ago.
Two years ago, I bought a M30 with a spun rod bearing and just went to a junkyard and got another cap and used bearing so I could move it around without it throwing a rod and ruining the block.
So......I suspended the engine on a sling I made from a 4x4 with some chains and large eye bolts with long threaded shanks so I could do the measurements needed to attempt a VG30et since I have every part to do so.
In the mean time, I bought another crank but soon found the VG30et swap would not be a fun road to go down because of the already too steep steering shaft angles which are made worse by trying to fit a Z31 turbo crossmember........and I wasn't interested in laying down the rack....which again makes the angles more steep.
The other alternative is making one's own turbo manifolds to relocate the turbo and possibly losing power steering or A/C.
I got discouraged and it sat for 2 years.
Upon getting fired and my landlord putting the house up for sale, I needed to make this car mobile so I just installed what I had lying around which is a L28et and a built 3n71b.
I had already converted it to a front sump by relocating the oil pickup and fitting a front sump oil pan from a first generation maxima (l24e) as well as drilling a new dipstick hole (not in the front blank dipstick boss because it goes through an oil galley which is drilled deeper in the rear sump iteration of the L28).
Yes, I replaced that weak felpro gasket with a proper stock gasket.
I also own a 1984 rear wheel drive maxima which is similar to the M30 in many dimensions and I also had spare engine mount brackets as well as the sump because this L28et was supposed to go in that car but I just bolted turbo manifolds onto the stock L24e and drove it 50,000 miles that way.
The maxima mounts were perfect for front to rear location but had the engine 2 inches too high so I found that S30 or S130 mounts would mount the engine (kind of) closer to the proper height and had the proper front to back location........but not ready for prime time.
Time to cut and weld the S30 mounts which seem damn weak as delivered from factory compared to the S130 (280zx) mount.
Right side is actually a S130 mount but they are same dimension but with extra bracing in between.
Turns out is is a lot more of a pain in the ass and requries mucho time on the grinder but I was able to drill a hole through both the stock portion and my welded pad which will have a bolt in case my welds turn out be metal caulking (not likely as I used a torch to preheat the work area)
I cut them shorter and re-angeled them rather than molest the crossmember since I may want to fit the soon to be rebuilt VG30.
I do have a spare crossmember that might be for sale soon.
Left side mount made from s30 (no webbing between legs).
On the left mount, I cut a slot in the added pad and fed the front portion through it for an extra measure of safety.
I would have done the right side that way but I cut the wrong leg off and had to end up cutting both.....Doh!!
If I don't mount something to the extra bit of pad, I will probably cut of the extra bit but it does clear the 280zx a/c compressor.
Next was my ghetto turbo drain I have put on many a car but this time I actually had the engine out of the car when I installed it.......making sure to cause a huge mess of "ultra copper" rtv.
If you're wondering where the flange came from.......
A bit of grinding the periphery causes the screen to magically disappear.
Now you have a flange to mount to a 3/4 inch hole you just drilled into your front sump converted L28et with a unibit.
Then it was time to mount a 3n71b tranny which isn't longer than the stock tranny but the bellhousing has to move back a few inches to restore stock L engine clearance to firewall.
That one shiny bolt is ground such that it fits like a glove into a countersunk hole.
Yes I will be tying the two individual mounts together on that one side........someday if necessary.
More pics to follow of clearance between s30 fan/clutch assembly and stock radiator as well as 280zx turbo radiator which seems to fit.
My plan is to run a 1987 300zx turbo ecu first since I have one and an adapter made from the connector of a m30 ecu and 300zx harness plugs but it will eventually run on a late VG single cam engine'd nissan quest or pickup ECU in the hopes that I can fool an emissions inspector (if I move to an inspection state or Obama has his way) by blowing clean readings and the car looking stock underhood with no shiny pipes or racer boy looking stuff.
Another benefit of those ecus is that they are obdII.
I have not cut anything on the car itself other than the stock exhaust pipe just after it collects though I will cut the harness since I have a spare.
The stock 280zx turbo turbo elbow/downpipe clears the steering shaft like the car was made for it.
Soon I will slightly move the receiver/dryer from it's stupid location so I can adapt the M30 power steering pump to fit the 280zx bracket but for now it can hang out where it is.
So far, this hasn't cost me jack shit since I already had this stuff laying around and I've only spent like 4 full days working on it.
Engine bay pics.
Stock 280zx turbo turbo elbow clears steering shaft easily........made quick adaptor for smaller o2 sensor required by either m30 or late z31 turbo ecu but I may run an early z31 turbo ecu rather than wire in dropping resistors so two bolts later, I can screw in large sensor.
Money is tight so it's all labor......except a bit I set aside for the driveshaft shop.
 Post subject: Re: F31 build (leopard or infiniti M30) with L28et swap.
PostPosted: Mon Sep 05, 2011 12:55 pm
No money but plenty of time so I tied up some loose ends.
Still waiting for front driveshaft from a S13 to be fitted with 280zx turbo 3n71b yoke and a distributor shaft so I worked on some details like the fan and such and ran it for 1 hour twice a day for the last 3 days mostly idling and it seems pretty ok.
Zero smoke and no dead holes.
I'm surprised since the pistons came out of a 90,000 mile 280zx n/a that was filled with water and rusted the bores.
I hammered them out with a 3 foot pry bar right through the rusty bores and, when I realized I was sold an engine missing a few piston skirts and broken ring lands, I just cleaned them up by soaking each in carb cleaner until the rings unstuck and then I worked them until they were clean without removing the rings and honed the f54 turbo block and slapped them in.........crazy......I couldn't find even the slightest scratch on the ring surfaces after their trip through rusty bores.
I realized I needed a throttle when I got in the car and stupidly stood on the gas pedal as it ran.............DoH!!!.......not much worse than a flaccid pedal.
The stock L-engines use a linkage rather than a cable.
I had both a 240sx and a 1992 stanza throttle body (stanza one is better for fitment to 300zx....it says "nissan" rather than "Jecs" on it) and contemplated fitting them but I have zero cash for piping to the larger diameter throttle body so I used stock 280zx pipe and I then decided to remove the cruise control portion of the throttle cam and cut a little out of it a bit rather than try to fit it to the throttle body itself.
If you use it and the plastic bushing it fits over, it will slide right over the stock L28 throttle linkage in a place where the stock M30 cable only has to make a "S bend" and it doesn't bind at all.
Then you just drill it where it sits (once in proper position) and feed a bolt through it.
If you look close, I left on enough of the round portion to keep the throttle action as linear as possible since the L28 linkage that links the shaft to the throttle body already takes a bit of linearity away and not keeping the round portion would exaggerate it to the point that the car would not be fun to drive.
Feels like stock....but bracket looks cheesy.
It's one of the brackets from the VG30 that came off of the VG30 cut down and put upside down.
That took an unbelievable amount of time in the burning hot sun routing the throttle cable here and there and everywhere to come to that solution but the actual work was only a few minutes.
I did find out that the throttle cable still works smoothly when tied in a loose knot but I am currently runining it with less tight curving than the stock setup so it is smooth like butter.
More time permitting, I will make it look good.
Engine running in car........sadly there are two harnesses in the bay (m30 one unused) but if I had a driveshaft, this car would be mobile.
S30 fan clears radiator by 5/8 of an inch........that's twice the distance of a stock BMW 635csi.
I guess I should work on getting the M30 harness working with the engine but still need a distributor shaft to give the 1987 300zx turbo ecu the proper crank reference it expects.
Both the engine and the car have suffered years of hackery at the hands of chumps so I have a bit of work in front of me to undo it before I start on a very stout L28et build with the FS5r30 tranny using austin hoke's adapter.
FEW DAYS LATER.....
Did some cutting on the M30 harness in preparation for using the M30 ecu with the L28et.
I used the dropping resistors but wired it and used plugs so I can just unplug them and plug in a loopback in case I want to use high impedance later on.
I may just drop in the stock M30 high impedance injectors and see what happens since I will be running minimal boost.............non-turbo injectors worked fine on my L24 maxima with a turbo so........
Funny how injectors 1,3, and 5 each have their own power wire but 2, 4, and six all use a single red wire for all three to feed the positive side.
I put them all together to feed a block and then ran individual power feeds to the injectors.
I also spent forever trying to figure out a mystery wire that was blue with white stripe.
My wiring diagram for the ecu says it is a comm line but it turned out to be the a/c compressor clutch wire.......LOL.......forgot about that in my frenzy.
I also found you can fit the M30 power steering pump to the stock 280zx (1981 and later rack cars) bracket with 5/8 inches of spacers and welding in a brace.
Then you replace the ribbed belt pulley with one from an early pathfinder or Z31 so the V belt can work with the stock 280zx crank pulley and tensioner though I will have to find a longer low pressure line (return line) from another car that will allow me to keep the power steering Res. in the stock location........it seems to hover where it is just fine for now.
I'm amazed at how easy this has been so far.
PostPosted: Mon Sep 05, 2011 12:56 pm
Finally got a 280zx turbo distributor shaft so I swapped over the disc from the Z31 distributor to the 280zx turbo distributor and got the wiring harness sorted to reach the bare neccessities to run.
I felt really bad cutting the 280zx turbo specific connector off of the distributor but better that than ruining the harness of the standalone 280zx turbo system I made to initially run the engine.
I used the M30 tps but it has a narrower distance between the mounting holes so I cut and ground the 280zx turbo tps until only about 50% of the metal backing remained and tacked it to the m30 tps.........good to go and adjusted easily.
I have the air cleaner/maf for the vg30 setup in stock location and used the intake pipe off of a 1984 toyota camry.
One side fits the turbo exactly and the other fits very snugly inside the extension rubber tube on the M30 maf.
It's tight enough that it leaks no air.
It starts up and runs fine even with the turbo injectors.........but I had to bypass the dropping resistors to get it started the first time since I had replaced some injectors with some that had sat in a box for 5 years.
I haven't hooked up a knock sensor to the car may be falling back to a lame ignition curve because the ecu doesn't see the sensor.
It seems fine everywhere else in the rpm range with zero missing or popping but I haven't driven it since I still lack the driveshaft.
I'm sure idle would be better once work out a way to use the idle control circuitry with the 280zx hardware.
Next is making all the rest of the circuitry working that the ecu expects like egr, a/c idle up, idle air control, temp gauge..etc..........that and soldering on the connectors the 280zx turbo specific alternator and tranny expect....but at least I can now start the car from inside and it would run fine if I had a driveshaft.
More pics once the harness is fully taped, splitloomed, and routed.
FEW DAYS LATER......
No more pics yet but, while contemplating 3.54 diff from 280zx, I found that the pinion yoke from the 280zx turbo or z31 300zx will bolt right in.
I did remove the abs sensor that is on the nose of the long nose r200 but it didn't look like it would interfere with the 208zx rectangular flange (of course....no tone wheel for abs).......but why have it there if there is no tone wheel acting on it?
Both of those flanges make the overall driveshaft length needed to be about 1/2 inch longer than with the M30 flange on the diff. but, if you have a one piece driveshaft made that is long enough for proper penetration into the tranny for use with the M30 flange, then the 1/2 inch less penetration with the z31/280zx turbo flange is no big deal.
The 280zx n/a is the same dimension and will work as well but it features M8 bolts instead of M10.
R180 use a thinner pinion shaft so you cannot swap on a flange from one of them.
I just had a 280zx turbo driveshaft lengthened for this car and should get it back next week early.
I'll still pick up the 3.54 from the 280zx turbo in the junkyard since I doubt 3.9 with no overdrive will be much fun on the highway.
It also seems the 280zx C/V type axles are the same length with the only difference being the flange on the stub axle being a smaller bolt circle on the 280zx than the M30 so I'll guess you can put M30 axles and flange into a 280zx turbo just fine or the other way around......as long as you bring the flanges on the stub axles.
I haven't checked the spline count on the flanges so see whether they are swappable back and forth so measure first before jumping into that.
The reason you might want to use M30 axles on the 280zx turbo is that the 280zx turbo c/v axles have to be cut open in order to replace boots while the M30 slip over and are clamped.
PostPosted: Mon Sep 05, 2011 1:05 pm
Got driveshaft back.
Drove it..........seemed pretty smooth and fast.
Lost all gears in tranny.
Called wrecker.
Started car back up.........tranny acted fine........for about 500 yards........no gears at all.
Turned off......started back up........good for 500 yards before no drive whatsoever.
No shuddering or slippage so I surmised it was some debris floating into the filter which removed all pressure........glad I didn't rev the piss out of it when it failed or it would have burnt and sent debris all through the tranny......Lucky.
Took off pan and found a mini-mountain of rear clutch particles just under the pickup of the filter.
Removed and took apart tranny................everything except the low/reverse clutch are fine which is good.
Ordering friction materials and new band........everything else was fine and since there was no burning.
I guess sitting for 5 years twice was a bit hard on the friction material.
This gives me the opportunity to modify the valve body while it's apart so it should be good for near 500hp after it goes back together......probably next weekend.
Amazingly easy and only used a pair of snap ring pliers to take it apart.
It seems if the jatco 3n71b and 4n71b trannies don't burn and overheat, then there is almost zero wear inside since everything else was at like new specs.
Pic of old frictions.
FEW DAYS LATER....
Finished rebuilding tranny........unbelievably easy to rebuild an auto (3n71b) if it just broke and wasn't driven until it circulated abrasives throughout the tranny or burnt.
Car is now daily driver and drives amazing similar to a z31 even with the L28et.
Now that the general swap is done, it's time to actually do something on the rest of the car like installing the intercooler and upping boost to 10psi (flattops).
ANOTHER DAY PASSES......
Got the speedometer working by using an electronic sensor from a 240sx.
I tried two different size gears on it....one was a 3.54 from a Q45 and it worked when I clocked the sensor 90 degrees from where the tab is.
Since I still have the 3.90 gears in the car, I put back on the 240sx gear and speedo is damn close.
If you guys have electronic speedos, you can use most any tranny nissan made for any car and get it to work.
The automatics like 4n71b and RE4R01a have 30mm diameter speedo pinion housings and the RE4R03a (Q45, Z32, and J30) have 28mm housings which look almost exactly like the ones found in the FS5W71c trannys.
The FS5R30 tranny can use sensors from a variety of skylines, pathfinders.....etc but each sensor seems to have it's own offset for the intended gear.
It seems the early pathfinders and late Z31 turbos with digital dashes still have a cable drive though I have seen some Z31 FS5W71c with a cable driver on late Z31 with analog dashes that have a bolt on sensor but I'm not sure if that signal is compatible with the M30 cluster.
Pictured below are the 240sx sensor out of a RE4R01a tranny that happens to have the exact same diameter as the sensors/drives that fit the 3n71b and 4n71b.....they are both jatco trannies so it makes sense.
I installed the black gear on it in anticipation of my 3.54 gearing but put the pink gear (came on it) back on and it is in my 3n71b now and pretty accurate.
You can see how nissan offset the housing depending on the gearing and the amount of offset is actually visible if without removing the sensor from the car....if you can look closely.
To run the black gear on that sensor, I had to clock it 90 degrees which makes the gear tips flush with the housing like the sensor on the right.
Another view
I'm sure there is a proper offset sensor housing but I've only found them in 28mm outside diameter on the RE4R03 trannnies out of Q45 and J30 infiniti.
I haven't confirmed it yet but it seems the 28mm sensors from the q45 and j30 might fit the FS5w71c tranny....not sure yet.
As far as FS5R30 trannies, here is the sensor out of my pathfinder shorty tranny.....it is actually a speedo drive housing but the sensors and drives out of these trannies seem to follow the same offset and gear relationship as the shorter sensors on the other trannies.
The housing diameter is 30mm.
So.......a small change in speedo drive gear ratio seems to not requrie replacement of the drive gear off the output shaft of the trans..............at least the change from 3.9 to 3.54.
Also....as mentioned above, you can reclock the housings if you can't find the proper offset housing..............probably with varying degrees of success and finding a way to secure it to the trans since the mounting tab is somewhere other than where the trans expects it to be.
PostPosted: Mon Sep 05, 2011 1:11 pm
I added the 280zx turbo injector cooling fan after experiencing vapor lock after parking it for 15 minutes and trying to restart it after a hot soak.
From the 280zx up until the late early 1986 Z31s Nissan used injector cooling fans to blow air over the injectors and rail for 17 minutes after you shut off the car.
The late 1986-on Z31 and the M30 get around this by using dual inlet injectors and some ZX turbos can get away without running them because they have a huge hole right above the turbo where hot air convectively flows out rather than being trapped in the engine compartment.
The late Z31s and other VG30 went to dual inlet injectors which makes the hole in the hood and the fan non-necessary.
Fuel comes in the side and goes out the top toward the regulator where it is sent back to the tank.
This ensures cool fuel is quickly sent through the injectors and rails rather than the old way which only flushed part of the rail while leaving boiling fuel in the injectors.
So...I installed the 280zx fan, sourced a timer unit from a Z31, and wired it up per the manual....
Wrong....the Z31 manual is wrong because they just copied over the wiring pinout and diagrams from the 280zx manuals....which were also wrong.
I used the schematic supplied in the 280zx manual and followed the board traces through the components to determine the correct pin out and now it works.
Luckily, the manual being wrong caused no smoke when connecting it that way........It just did nothing.
It works correctly with the wiring on the right side of the diagram.
This whole saga was quickly cut and pasted from my posts in other forums and quickly kludged together here so some things might be out of order or missing.
This car has driven 30,000 miles since the swap was made and I recently had a thermostat stick closed.........luckily I was logging data with a laptop plugged into the consult port of the vg30 stock ecu for the M30 car....1991.
Sadly, it got to 329 degrees F before I could pull over and the head gasket popped so.......the L28 with the pistons that were hammered out of rusty bores gets some equally abused 280zx turbo dished pistons so I can run 87 octane when in low boost mode and save 40 cents per gallon (us).
Once it is back up this week, work goes on finishing prep. work for the LD28 I have and fitting a turbocharger to it for use in this car.
PostPosted: Mon Sep 05, 2011 1:23 pm
I did end up fitting the 3.54 diff from the 280zx turbo and still need overdrive so either a built 4n71b ........maybe, I bite the bullet and install the fs5r30 with L engine adapter or just buy a fs5w71b and fit the s12 clutch pedal though brake pedal will take a bit of yard scrounging or mods.
I ended up replacing the 240z metal fan and clutch with a s13 ka24 fan clutch with the stock 280zx fan blade but it was now too close to the radiator.
This was solved by mounting the fan blade to the clutch on the opposite side.
I used longer bolts threaded through front to back that protruded to form studs to mount the fan.
I used a nut on each bolt to space the fan back further and also allowed the metal inner ring of the fan to clear the fins of the clutch. (more spacing brings the fan closer to the engine)
Since the fan no longer was centered by where it mounts to the clutch, I forcefully turned the fan blade opposite the clutch which centered the bolts along the axis I wanted centering.....then I tightened the nuts..........no vibrations from fan.
As of now, it clears the 280zx front pulley by 3/8 inch and the radiator by about 3/4 inch.
It's still a daily driver so I have to keep that in mind when I work on it.
Sure looks a lot like the R31 engine bay.........of course it is a F31 so only minor differences in the car anyway.
PostPosted: Mon Sep 05, 2011 1:40 pm
Had a little time on my hands so........Added a supra intercooler using various saab and volvo intercooler piping and stock volvo/saab hoses (cut to proper lengths for a stock look) that allowed me to route through the headlight openings in the core support without cutting anything or moving the stock air filter box and intake tubing.
A little black paint on the one non-black tube in the system should look damn near like the intercooler came from the factory.........maybe a little dirt on the one silicone coupler I used would blend it into looking more stock.
And a much larger picture which shows entire installation from high above.
http://farm7.static.flickr.com/6191/6113550701_41cdcd801f_b.jpg
Boost is now referenced from the intake manifold because the intercooler system has a pressure drop across it that takes away 1.5 pounds of boost at redline and 10psi.
Stock nissan L28et "blow off" (vacuum control valve) is augmented by much larger recirculation valve that routes the backed up boost that stacks up in front of the throttle plate to the turbo inlet.
This is necessary because of the larger volume of pressurized air in the intercooler system versus the stock "j-pipe".
Now that the entire factory infiniti M30 induction system is installed, I can no longer hear the recirculation valve operating.........all you hear from this car is a little bit of fan noise and turbo whine.........well....and tires burning.
Wastegate spring was threaded for length adjustment but is set to 6psi and the car's been run to 10psi using the boost control valve (my limit for flat top engine with 93 octane) without any pinging and the boost shoots right up to 10psi and stays steady all the way to redline.
A "grainger valve" was used for boost control.
With this "grainger valve", the wastegate actuator diaphragm does not see any boost at all until boost climbs to the value you have set by adjusting the valve.
It's also good to run this if you have moved the wastegate actuator's boost reference from the turbo housing to the intake manifold because this valve is also a one way valve which means your wastegate actuator doesn't see the intake manifold's 25 to 30 inches of vacuum when you drop throttle at high rpms. (good for a 20 year old actuator diaphragm that has never seen any vacuum).
Grainger part number 5Z763 for $9.73.
http://www.grainger....5&cm_vc=IDPBBZ2
I swapped the orientation of the ball and spring around so the ball seats on the body end rather than the knob end as delivered by grainger and drilled a 1/8 inch hole almost all the way through the body of the valve (not all the way through) with the .025 inch hole drilled inside the larger hole for the final 1/16 of an inch.
The small hole is necessary because the valve from grainger is one way and would keep pressure on the wastegate forever....or until the leaks do thier job.
The .025 hole size seems to work well enough that boost behavior is sweet.
Most I have seen on the internet are drilled on an adapter.........but I did not want an adapter.
You can just see the hole near the orange loctite in the pic.
Sure you can try to drill that tiny and fragile bit all the way through but I was doing this in a vise with a standard and relatively large hand drill so the 1/8 inch hole minimized the amount of .025 drilling required.
The hole is in the body in a place that would not interfere with operation of the valve.
I wanted a more streamlined installation with minimal size and parts so I got a double ended hose barp, cut it in half, drilled the hole in the knurled portion of the grainger valve larger, and pounded the barb through from the inside to keep it captive unlike most I've seen on the internet where it is pounded in from the outside.
I did have to grind the barb lip formed by cutting the double ended barb in half so it would go into the knurled adjuster of the valve as well as shorten the spring a bit (might not have been necessary to shorten the spring but the bit of hose barb does shorten the compartment by 1/8 inch where the spring seats).
I also sourced the proper hose barb for the other end and did not need an adapter.
This leaves you with a grainger valve that won't spit out the barb that some recommend you pound in from the outside.
$80 total expenditure on intercooler, boost control, and boost recirculation system........all sourced in two 1 hour junkyard trips, one trip to lowes, and one trip to grainger........and some vacuum hose.
I need to do a couple of things like making the EGR work, the IAC, and deleting the aux air regulator as well as routing the water lines from the regulator/throttle body to the water cooled center section of the new turbo slated for installation.
Waiting on custom a/c lines and finishing a support for the rear mount of the power steering pump......well....that and a proper upper radiator hose.
Nistune will be purchased with DLP designs 8 channel usb data acquisition system as well as a dished piston L28et for higher boost levels.
Note the walmart "neverstart" marine battery which has two extra terminals and, for some reason, cost considerably less than the automotive use battery of the same specs..........at least when I bought it 2 years ago.
http://www.walmart.c...attery/16782694
Currently, the extra ground cable makes battery to body and battery to engine connections redundant and the extra positive terminal can be used for something that draws big current such as amps for a subwoofer or maybe a huge laser to blind chumps who cut me off.
I mentioned a subwoofer but I found that putting 6x9s in the rear deck of a car with a decent sized trunk offers up some pretty tight bass and enough volume to leave my ears ringing after a loud song.
I had originally tried infiniti kappa 6 1/2 components but it was not nearly loud enough behind a $75 buck pioneer head unit without supplemental amps so in went some 8 year old (6 years in a box) pioneer 4 way 6X9s that were purchased because they had the LOWEST wattage rating I could find for that speaker size.
Sometimes you get lucky with stereo installations and sometimes you spend tons of time and money for something that never does sound good.
Since the car originally had bose speakers, I had to fashion 1 inch thick shims carefully cut into bizarre shapes as to minimize any obstruction of the 6x9 speaker through the very odd shaped speaker holes.
While the front 6 1/2s in the doors are pathetic in comparison, the 6x9s are shockingly loud and friends make me open up my trunk to prove I have no subwoofer or supplemental amps.
Fronts also used 1 inch thick shims because the door holes are somewhere between 5 inch aftermarket speakers and 6 1/2 speakers........pretty easy....bolt speakers to shims and bolt entire assembly to the door though I may be tempted to play around with the factory bose enclosures with an aftermarket speaker installed later on.
All speakers are under the stock covers so any sideways baseball cap wearin' thieving ass'd nimrod will see nothing worth breaking into the car for.
I'll try to add pics of the speaker install for the M30 guys because I have shared in their pain.
At least 25,000 daily driven miles so far and here's how it looked during my trip to kennedy space center to do some aero testing on the twin turbo ford GT.
And a much larger version of the pic above......
http://farm7.static.flickr.com/6190/6113553535_cdb90d678f_b.jpg
It is parked under a tree I used 22 years earlier to pull an engine in my 1969 ss chevelle (455 olds) that broke an oil pump as I was moving and had only money for gas........but plenty of tools and the parts necessary to pull off the job.
This is located in a state picnic area on Indrio road just east of I95 in florida and the engine was pulled during a monster lightning storm.
Sadly, moving the seat forward to get my tools out poked a hole in my can of "off" initiating a panic stricken and can tearing application of the insect repellent but the downpour of rain washed it off I was eaten alive by mosquitos anyway.
PostPosted: Mon Sep 05, 2011 9:48 pm
this is awesome :)
im in the process of swapping my l28et into an s13.... i may need to pick your brain for wiring help using the stock efi
mx32 2jz swap in progress
PostPosted: Tue Sep 06, 2011 4:44 pm
What's your horsepower goal?
Will this be a street driven daily driver or a track car?
With the answers to these questions, I can show you a few different paths that can be taken to get what you want.
There a lot of options and directions to go with some requiring more work than others.
The issue with the m30 stuff is that's it's very rare so I am experimenting with common nissan systems that currently litter the junkyards of the world but are more modern.......but.....sadly less supported.
PostPosted: Tue Sep 06, 2011 7:17 pm
im looking for a street driven car.... probably a z31 ecu setup w stock injectors/turbos for now.
i am already diving into both diagrams but some of it is a bit unknown to me.
i have the turbo ecu already from an 85. all i need is the maf and chopper wheel and then i should be good to go.
id consider outsourcing the wiring if you would be interested.... thats the one thing i struggle with the most
on a side note, ive found 3 m30s in the jyards in the last two trips.... so im sure i could find alot of it if need be.
PostPosted: Wed Sep 07, 2011 12:26 am
The Z31 stuff is pretty well supported and far more common than the m30 stuff.
The M30 system tops out at 300hp with the stock N60 MAF but I'm sure it can run a larger air flow meter.
Mine was pretty easy because I used the system already in place for the V6 and lengthened the wires rather than use any of the 280zz harness.
I think z31, m30, and the s13 use part of the body harness for the maf and the coil/ignitor and it might merge with the injection specific harness just inside the firewall so you might be able to graft you s13 connectors from the s13 injection harness to the Z31 harness for various things like speed sensor, ignition switch, power.....etc and make it plug and play.
Then you just lengthen the z31 harness for injectors and sensors.......and all those grounds.
The Z31 is supported by JWT and Nistune and a mustang cobra MAF can be used with very little change to the original harness.
Most of the more modern ecus require a good bit of rewiring than the option above.
I would offer but I am currently rushing to prepare this car for some runs a the NASA shuttle landing facility.
PostPosted: Wed Sep 07, 2011 5:01 pm
Great post. I love the step by step details. I'm also good at mechanical work but lousy at wiring. I'd love to know how you made a stand alone L28ET harness because that would save me so much time doing a turbo swap on my '75 280Z. I have some of the stuff to do the Z31 swap but to me that seems like more work than the basic swap.
2007 Honda Fit sport, 5 speed-daily driver
1975 Datsun 280Z-turbo conversion underway
PostPosted: Wed Sep 07, 2011 10:37 pm
What year is the S13?
I would like to check the pinout and connector type vs other nissans.
I had only one afternoon to remove the engine, transmission, dash, and harness from the 280zx turbo so I just unplugged the injection specific harness and cut where it met the factory harness.
I got lucky because it only had a couple of connectors that merged it with the main wiring harness and that I didn't miss much.
The 1981 harness has dropping resistors and the 1982/1983 does not as well the later harness features a fuel pump controller but I have bypassed them in the past.
I'll take a couple of pics and throw out a few details on it either tomorrow or in a couple of days.
I think I wrote on the connectors with a sharpie detailing what each terminal was so it should be easy.
That said, the 300zx ecu and harness, though very similar, seems to have much less issues with running issues that are corrected by wiggling the wires which signifies either a cold solder joint on the board or the connectors not making good contact.
If your 280zx turbo seems sluggish....reach down and move the harness and the car might suddenly come alive. Most of mine were that way.
As far as the S13, I will read up on the pinout of the connector and see how close it is to later vg30 systems which might simplify things.
What I really want to do is get hold of a nissan frontier supercharged ecu and harness, add the crank sensor, and run that on the L28et but with the later high impedence turbo injectors.
It should require no tuning for stock boost levels.
One more thing about nissan ecus.......even as far back as the 280zx turbo, the cars ignore the 02 sensor for trimming fuel after you get to 3500rpms and I believe some later vg30 start doing that at 3000 or so.
This can greatly affect your highway mileage if the majority of your cruising is above the rpm threshold.
PostPosted: Fri Sep 09, 2011 7:26 pm
its a 90' so a single cam
i have a eccs diagram i could scan so you could take a look. ive been busy with my home currently as our basement flooded out and destroyed alot of my stuff, including my 83 harness diagram
if i could just get some basic guidlines on how to splice it into the factory harness id be set. i dont think there would be much id need to run. maybe a half a dozen wires or so.
PostPosted: Thu Oct 06, 2011 9:52 pm
I did some checking and the M30 harness connector is not pin compatible with the 240sx.
I'm still checking the more common maxima and pickup/pathfinder ecus are of the same family which would make things easier in that you could lengthen the portion of the harness outside the firewall to match the 280zx hardware.
Then you would have to interface the harness with the rest of the car both inside and out.
It would be the same for the 300zx harness.
PostPosted: Sat Oct 08, 2011 12:22 pm
well honestly id need more help just knowing what the pin outs on the s130 harness are... i cant find one anywhere. i have spare connectors and i could make it plug and play with the s13.
im not sure how the fuel pump works on the s130 either
PostPosted: Fri Oct 14, 2011 12:46 pm
S130 harnesses are getting pretty rare and even the Z31 harness is getting rare.
I am looking at pathfinder and maxima ecu/harnessing of various years that might prove to be super common and inexpensive.
The 1999 and later for the single cam vg30 are programmable but they require another sensor that reads the ring gear for misfire information....since about 1996 or so.
It's possible that the nissan quests/maximas/pickups of the early 90s might be a great resource in starting points for a harness that's easy to modify because they would also be closer in configuration to your S13 because the year is similar.....might even have similar connectors on the injection harness to interface it with the rest of the car.
They are similar to my m30 ecu and many have a nissan consult connector that you get a cable to connect to communicate with a laptop though not for tuning.....just reading/displaying data and codes.
The later ecus are also for use with high impedence injectors so you would need to use dropping resistors to use the stock 280zx turbo injectors.
Of course, these require you to use the 280zx turbo distributor and swapping in the optical disc from the engine management system donor vehicle.
I am busy but have been checking around.
PostPosted: Sun Oct 16, 2011 4:19 pm
yea i found some info on hybridz about pinouts for the turbo harness... i already have a turbo harness so it shouldnt be too bad to hook up 12v power for the ECU, switched for the injectors etc. i plan to use the stock s13 fuel pump relay and ECCS relay.
the engine is not quite ready to drop in, so i havent looked at the notes i have in a bit.
PostPosted: Mon Oct 15, 2012 7:31 am
Took the car to "midnight madness" at Palm Beach International Raceway a few days ago.
L28E flattops, P90 head, stock L28et injectors, 7 pounds boost, 3.54, 215/60-15s, automatic, intercooler.
PostPosted: Mon Oct 15, 2012 9:50 am
which is you? and is that 1/4 mile?
