It is currently Sun May 26, 2013 2:01 am
 Post subject: MK63 VS S/Z fronts
PostPosted: Fri Aug 31, 2012 5:22 am
anyone know if these have the same bolt spacing? i have some front Z32/S14/15 brakes, and im thinking about buying a set of brackets that are listed for MK63's, but im not 100% sure they will work. any ideas?
 Post subject: Re: MK63 VS S/Z fronts
PostPosted: Fri Aug 31, 2012 12:12 pm
Will not work. Buy the bracket for the R32 upgrade. The spacing is the same as your Z32/S's.
PostPosted: Fri Aug 31, 2012 8:10 pm
figures LOL, Thx!
PostPosted: Tue Sep 04, 2012 9:26 am
I have a set of 4 piston front calipers that will bolt onto your stock front strut, use your stock caliper and not require any spacers or adapters. It will also fit under a 14" rim if you are still running something that small. I can mail FPO/AP no problem.
PostPosted: Tue Sep 04, 2012 10:39 am
Can you send pics to me? If Wook doesnt want?
I'm looking into purchasing Z32 TT front calipers they are Aluminum 280mmX30mm...
Are these the same as R32 type M
Rubber-Soul.net caliper bracket
■ caliper bracket for Skyline R32 Type M (steel)
\ 31,500 list price (\ 30,000) \ 25,200 deals (\ 24,000)
※ caliper is also available for turbo Silvia, S15 S14 except for type M to Skyline. (For the Fairlady Z32 and R33 are not allowed.)
Trying to confirm Want to purchase the bracket from Rubber-Soul but website says z32 will not work (wondering if they meant Z32 NA)
Jose
PostPosted: Tue Sep 04, 2012 11:58 am
Z32 on a stock KGC10 front strut will not work. The caliper and rotor are too large and conflict with the steering. Check out: viewtopic.php?f=12&t=19003 for pics. If you upgrade the front struts to newer skyline assemblies then no bracket is needed to run S13/14/15 or Z32 or R32/33/34 brakes. See my brake/suspension thread at: viewtopic.php?f=7&t=19655. There is a pic of my fronts with the modified struts and Z32 fronts.
The older 4 piston calipers I have work with the stock rotor and stock front strut.
PostPosted: Tue Sep 04, 2012 12:39 pm
JNCR,
Thanks that clears things up for me. I thought with the bracket http://www.rubber-soul.net/p-brake.htm sales its possible to run Z32.
Had a good Source for the Z32 calipers for cheap looks like I'll pass.
Jose
PostPosted: Tue Sep 04, 2012 2:30 pm
The link provided states the brackets will not work for R33 or Z32 brakes. Can you read Japanese?
PostPosted: Tue Sep 04, 2012 5:16 pm
Thanks, for the help...
Users browsing this forum: 31GUN, Google [Bot] and 7 guests
