It is currently Wed Jun 19, 2013 3:39 pm
 Post subject: 280ZX Differential
PostPosted: Sat Aug 18, 2012 12:55 am
Does the 280ZX turbo with manual trans all have a limited slip differential? I have never been able to find a straight answer on this.
 Post subject: Re: 280ZX Differential
PostPosted: Sat Aug 18, 2012 1:59 pm
No.
PostPosted: Tue Aug 21, 2012 6:26 am
Ok, thanks.
Is there any way to tell if the Z has one short of driving it?
Or did they not come with one? I would find it hard to believe if this were the case but I guess its possible. These have a R200 differential right?
PostPosted: Tue Aug 21, 2012 3:45 pm
no 280ZX ever came with an LSD from the factory. not sure how you got "possible" from "no"
they all came with open R200s
PostPosted: Tue Aug 21, 2012 10:39 pm
Easiest way to check is this.
Put car in neutral.
Jack up 1 rear wheel off the ground.
Turn the wheel.
1, If it spins you have an open diff.
2, If it locks you have an LSD
3, If it gets a bit harder but still spins it's probably a worn out LSD.
To check, jack both rear wheels off the ground and turn 1 wheel.
If both wheels turn the same way it's an LSD.
If the other wheel turns opposite to the way you are turning the wheel it's an open diff.
Simple. 8)
PostPosted: Fri Aug 31, 2012 12:14 pm
Z31 turbos have the LSDs. CLSD is better than VLSD.
PostPosted: Fri Aug 31, 2012 7:02 pm
only 4/87+ Z31T has CLSD
misinformation sucks :|
'88 SS had VLSD
shimmed VLSD can be rad, I had one and loved it till my hybrid axle broke, now I'm rocking a welded and it's awesome, too.
Users browsing this forum: Nismopunch and 2 guests
