It is currently Sat Jan 31, 2015 11:01 am
 Post subject: A little help with my KGC10 rear subframe mounts etc please.
PostPosted: Sun Jul 08, 2012 1:41 pm
Ive started assembling the rear suspension. However one of my staff who assisted in the tear down is no longer with us and im left with a 1000 boxes of washers, nuts, bolts, rubbers etc.
Does anyone out there have a break down of what bushing, washers, spacers are required for the complete rear set up. Pictures will do.
My old workshop manual doesnt really give me the details i need.
Like rear subframe, when mounting to the floor is there any rubber islolators etc.
Moustache bar, again when mounting to the floor are there any isolators?
I hope you get the idea.
Cheers
no commercial links
 Post subject: Re: A little help with my KGC10 rear subframe mounts etc ple
PostPosted: Sun Jul 08, 2012 4:22 pm
I'll scan the exploded diagram from the parts manual for you when I get home, Dave (or have you got that already?)
PostPosted: Sun Jul 08, 2012 7:06 pm
Kev,
If you can post the scans here, I'll like to take a look at them too.
PostPosted: Sun Jul 08, 2012 7:14 pm
For the time being, I found these pics of the moustache bar in my car
It looks like there is big and a small washer on the bottom, and at the top the castellated rubber part must be a separate isolator, since it's not part of the bush.
PostPosted: Sun Jul 08, 2012 11:50 pm
Ok, thats solved the moustache bar.
no commercial links
PostPosted: Mon Jul 09, 2012 7:57 am
Here you go, matey, hope it helps
PostPosted: Mon Jul 09, 2012 9:14 am
Hiya Kev
any idea what that part is between 12 and 6?
no commercial links
PostPosted: Mon Jul 09, 2012 4:28 pm
Can't really say, Dave, I've never had that apart before :)
PostPosted: Mon Jul 09, 2012 9:22 pm
I think 6 is the flat washer with the rubber on it. Then 11 & 12 are on the inside of the car and hold the main bolt in. That extra part may be part of the body or something that is pressed into the body.
PostPosted: Mon Jul 09, 2012 11:05 pm
I think your right, I wonder how thick the washer is?
no commercial links
