It is currently Wed Mar 04, 2015 1:47 am
Post a new topicPost a reply Page 4 of 6   [ 102 posts ]
 Post subject: Re: Hakosuka Parts Interchageability Thread
PostPosted: Fri Aug 24, 2012 4:37 pm
anyone know if the Z heater hoses in the engine bay match the Hako hoses? i want to get some silcone hoses, but i can find theses two hoses in silicone on the auctions in japan. i have the two main rad hoses in silicone, but the other hoses on my engine are kevlar braided, and i hate them..look SOooo dated and they collect so much dirt.
PostPosted: Fri Aug 24, 2012 5:19 pm
it's been soooo long since i had a heather in the Z that i honestly don't remember what the hoses looked like... i even filled in the holes in the firewall where the heater hoses went through... looking at internet pics though, it seems like it's more of a straight shot from the engine back through the firewall to the heather core... the hako's heater hose goes around the back of the engine and enters through the firewall practically on the header side of the engine...
you could get universal silicone hose in straight and 90degree pieces in the right diameter and make your own setup if you really wanted to ditch the stock rubber hose...
PostPosted: Fri Aug 24, 2012 5:25 pm
Hey kevin
I seem to remember from your build thread that when you removed your heater core out of the equation, you got some allen head pipe plugs to seal the outlets at the front cover fitting and at the back of the cylinder head... I don't think you ran a short section of hose with a bolt and a worm drive clamp... did you?
Do you remember if they were M20 x 1.75?
The strangest thing happened last night when I was at the hardware store for some housewares... I happened to find myself in the plumbing aisle and with the front cover water fitting in my pocket... and i happed to come across a 1/2" pipe plug that LOOKED awfully similar for thread pitch and diameter...
Lo and behold it threaded up just fine...
soo strange.... will pressure test out of curiosity over the weekend to see if it's something i'd consider using on the engine...
PostPosted: Fri Aug 24, 2012 11:08 pm
Hey E,
in your conversation with Kev,
is that the plug on the side right above the dizzy? i used a big ass bolt with teflon on mine, but i hate it. i know here in Japan the auctions have thermo housings that have a removable plug in it, i may buy one of those eventually.
on the subject of my hoses, i may just order some silicone, or i may suck it up and just replace with new rubber for the time being.
PostPosted: Sat Aug 25, 2012 7:38 am
Hey Tim
I was referring to the water fitting at back of the cylinder head on driver side of engine, and water fitting on front cover also on driver side of engine ( the smaller pipe that goes to heater on front cover fitting is threaded into the fitting - therefore its removable)...
PostPosted: Tue Aug 28, 2012 4:29 pm
Hey kevin
I originally looped a pipe from the back of the head to the water pump inlet, but there is a school of thought that says that will re-route hot water back into the water pump, and that ain't good.
So I blocked them off with these brass plugs, but IIRC they weren't a normal thread, they were a BSP or tapered pipe-thread that i got from a hydraulic parts store.
PostPosted: Sun Nov 04, 2012 8:13 pm
Can anyone confirm if the hakosuka door handles are the same as 510 and Z also window crank?
Thanks jgonzo911
PostPosted: Mon Nov 05, 2012 8:29 am
AFAIK door handles for hako and Z ARE NOT the same
A Z window crank will work - but if you're looking for an exact match it is NOT THE SAME
PostPosted: Thu Dec 13, 2012 7:01 pm
Served beautifully and coordinator ....Accept traffic brother Bujabr of the Kingdom of Saudi Arabia
PostPosted: Fri Dec 14, 2012 1:07 am
Wtf is this sh1t?
Look out for 071-GTX number plates in brissy.... Thats me!
PostPosted: Fri Dec 14, 2012 7:58 am
Wtf is this sh1t؟
Please explain more?
PostPosted: Mon Dec 17, 2012 8:27 pm
what does your comment have to do with interchangeable part on Nissan and Datsun cars??
PostPosted: Mon Dec 17, 2012 9:02 pm
Datsun ksa wrote:
Wtf is this sh1t؟
You explain
PostPosted: Mon Dec 17, 2012 9:31 pm
i think ksa is using a translator and doesn't speak english
he's not a spammer
-Matt
PostPosted: Tue Dec 18, 2012 2:41 am
LOL
I hope that he can figure out that we are all confused by his replies!
PostPosted: Wed Dec 26, 2012 2:15 am
well why dont we translate it back and see what the original text was?
Japanseklassiekers!
1970 C30 Laurel
1972 240Z
1973 610 Wagon
1977 260Z
1995 Micra
1999 200SX
PostPosted: Wed Dec 26, 2012 6:37 am
no way to do that unless he posts in his language
PostPosted: Mon Jan 07, 2013 1:51 am
he's not a spammer
H HHHHH
PostPosted: Sun Feb 10, 2013 2:35 am
Datsun KSA maybe just illiterate or dyslexic but...
حاول هذا المترجم للغة العربي http://www.babelfish.com/
driversity.tumblr.com
PostPosted: Mon Jun 17, 2013 9:00 am
Can anyone confirm that 240z front rotors/pads and 240z rear alloy drums/shoes fit a 71 kgc10?
