It is currently Wed Apr 01, 2015 3:44 pm
Post a new topicPost a reply Page 6 of 6   [ 110 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6
 Post subject: Re: More DR30 goodness (madness?)
PostPosted: Sat Mar 16, 2013 2:47 pm
Towards the end of January I snagged a trio of Omori Meter period gauges for less than the intended budget, but they arrived in Nagoya a day too late for Ewan from Hayatonka.com to squeeze into the container. Fortunately, there's always EMS shipping....... so five days later, they turned up in New Zealand:
The backlighting is dead (on all three, oddly enough) but that's a relatively minor setback. More on that later, actually, below.
With the gauges now here I sketched out a quick design brief for the gauge/boost controller panel and templated it out of cardboard with hopes of getting one laser-cut out of some form of metal once the final layout is determined. Briefly toyed with the idea of including panel-mount 3.5mm audio and USB jacks (for the stereo and Link respectively) but have decided against this for aesthetic and safety's sake - the last thing I want to happen is for some unwitting passenger to attempt plugging their USB device into the port and somehow frying the Link :o
Included the 3.5mm and Link inputs in the template to see how they'd look once positioned, even though I'm still undecided as to their merits. The little black vivid dots indicate where the factory mounting holes are located for the bracket which usually sits behind the fascia (and has since long disappeared from this car).
I then realized I was still missing some ignition-related componentry for the Link, so in lieu of getting fancy coil-on-plug sequential gubbins (which, as pointed out by some people, can be susceptible to heat failure due to their location atop the engine) I decided to keep it simple with a set of coilpacks instead. Hopefully these prove to be satisfactory for 300-400PS (they're from a Mitsubishi 4G63)... if not, back to the drawing board. NZEFI do a performance coil setup for a shade under $600, which could be an alternative, albeit pricey, solution. I just hope this won't be the weak link in the entire chain.
The mounting hardware finally arrived for the TS-X11 box speakers as well, so I wired and fitted those:
Don't mind the blue towel, that's only there to protect the new rear seat from the worst of the sun's rays. Which just leaves the giant rat's nest up front to take care of.
The old gauges will find a new lease of life in my track car, a mid '80s FWD Ford Laser TX3 (same as Mazda 323 GT) which I've been hacking around in (and blowing up countless engines) for some years now.
And on that bombshell, the epic parts collection mission for squid which has taken somewhere in the order of four years has finally concluded. Period-correct gauges were the very last thing(s) that needed crossed off the big list, so it is time to write up a plan to bolt things on and get stuff fabricated, etc, and present said plan to the right people.
Meanwhile, over the last few months the coupe started exhibiting all the signs of a rattly timing chain, which has been a constant thorn in my side. It's done a shade over 146,000km which isn't exactly high mileage, but nonetheless, in the interests of keeping the car in healthy shape the rocker cover was removed for inspection and possible overhaul of said component. I was a bit apprehensive of what I'd find under the cover, as many horror stories abound of sludged-up Nissans due to lack of servicing.
To my surprise though, there's nothing to see except sparkly clean internals. No horrid buildups of sludge to be found anywhere, I guess this car really was looked after in Japan.
as I suspected, the chain is in fact slack, and moves way too easily with one finger - at a guess, about 2-3cm of play? The red arrow indicates the amount of lateral movement along the left hand chain guide, which is a fair amount actually. Guides themselves all look fine, with minimal grooving.
The underside of the rocker cover is super mint, even the mesh is perfectly unblocked. Ah well, at least I can rest assured knowing that this engine hasn't been cooked during its lifetime. I also found the source of a small rear rocker cover leak - as you can see, the pesky gasket is all misaligned and pinched. Will fix that up as well as a couple of other issues that need remedying, the most serious of which is the braided hose leading to the clutch slave, which has split from age and started leaking.
Ordered a new top timing chain from Stewart Wilkins Motorsport in Australia, which arrived in New Zealand after a four day wait (thanks express courier!)
Geez I hope this all goes back together easily enough...
as it turns out: not only had the chain stretched laterally, but the modified Mazda ratchet tensioner (which was originally fitted to cure the well-known FJ20 startup rattle) had also fallen apart, which didn't help matters any. I do wonder how long parts of it have been swimming around in the sump for...
...where the hell is the rest of it?
Anyway, I had planned to pick the coupe up this weekend fully repaired and ready but circumstances dictated otherwise, so instead I spent yesterday morning pulling apart one of the Omoris I'd bought for squid in the hopes of resurrecting the dead backlighting. Managed to find a disassembly guide on the interwebs and after somewhat apprehensively prying the front bezel off I carefully de-soldered the old-style incandescent lamps (which were in fact blown) from the existing circuit board and replaced them with a pair of white LEDs and in-line resistors.
As you can see, there's not much to the whole package, although I was pretty careful not to upset the calibration on the gauge itself.
Success! There are a couple of bright spots thanks to the LED positioning, but once in the car it shouldn't be as noticeable. One gauge down, two to go.
Re-assembly will take place once I buy some paint to touch up the bezel, as unfortunately the only way to disassemble these gauges is with excessive prying force. Hopefully once they are mounted in the panel the damage/markings won't be visible.
PostPosted: Sat Mar 16, 2013 3:16 pm
looking great edd :D
PostPosted: Sun Mar 17, 2013 4:59 am
:tu: :tu:
PostPosted: Wed Jun 19, 2013 3:58 am
Recently picked these TS-X7 shelf speakers up for cheap due to the woofers being busted (and the foam rings had all but disintegrated).
Sent them away to be repaired and they just arrived back today, so fitted them into the coupe this evening.
They contrast nicely with the TS-X11s in the other Skyline :) Gotta love that authentic '80s look...
PostPosted: Sun Jun 23, 2013 5:10 pm
i keep getting outbid on a set of lonesome carboy's haha
PostPosted: Wed Jul 31, 2013 2:31 am
Yup it's crazy how much all that retro gear goes for nowadays. I've been keeping an eye on the local auctions here but stuff usually goes for top dollar and gets resold on eBay. Other times it all gets buried in "bulk lot" auctions where the seller doesn't bother to list anything separately - which is how I missed out on a KEX-888 cassette player as part of a collection that went for $16.00!
I bought these recently but just like the TS-X7s the woofers have turned to dust :(
Got a set of TS-X8s arriving soon though, unknown condition but they might be okay.
PostPosted: Sat Aug 03, 2013 6:06 am
Got bored, went for a late night drive.
PostPosted: Sat Aug 03, 2013 5:28 pm
I want those speakers!! how are they?
PostPosted: Mon Mar 30, 2015 2:37 pm
They were great, but I've since replaced them with some full alloy chassis TS-X9s.
They're the "little brother" to the TS-X11s that everyone foams over. The alloy enclosures and giant woofer magnets make them heavy (7lb per box) and despite lacking one speaker each compared to the TS-X7s the tradeoff is superior quality sound.
Meanwhile the sedan has languished in the corner of the shed under a thick layer of dust for far too long, but I've been keeping a surreptitious eye on Yahoo for various bits and pieces to buy and keep aside for when I finally restart the project.
I got sick of dealing with "Skyline Army" retards who either wanted to charge eye-watering amounts of money or failed to respond, so ended up buying one of these from Yahoo for less than the local price, even after taking shipping into account.
Factory DR30 steering wheel. Just so I have a "stock" piece should I ever decide to repurpose my Nardi or Personal wheels.
A few months ago a set of tidy door cards were listed, so I requested the services of Alex @ Moonlight Racing to secure them for me. Boom!
The front door cards on squid are a bit worse for wear - the map pockets are missing and the trim has screw holes from where someone's carelessly mounted a pair of ugly box speakers.
Just think, I went to all this trouble for a pair of front map pockets and a few less screw holes :P
But at least I can now fit the factory umbrella...
...and it's good to have spares anyway. One of the rear door cards in the sedan is falling apart where the top section meets the fabric, if I remember correctly.
Next step is to try and secure some replacement boot carpet, and then the interior should be complete, save for the construction of my custom gauge panel and repairing the tear in the driver's seat.
I also need to save up for another FJ20ET dizzy to rebuild and then convert into a crank angle sensor to drive the Link G4. They are readily available from YAJ, but are expensive even in unrestored form.
Turns out that two of the Omoris I'd taken a gamble on buying in Japan (oil temp and water temp) had busted senders/mechanisms in addition to blown backlighting. Bummer.
Robinson Instruments in Onehunga were helpful enough when I phoned to inquire about getting them repaired, but as they'd never worked on Omori gauges before they couldn't really give me an accurate quote for repair. I did find out that the core disassembly charge would be $37.50+GST per gauge, plus appropriate labour/inspection costs before any repairs could be made, so that's probably the best option I've got short of importing another pair off Yahoo. The added bonus is that I can get the backlights fixed at the same time.
In the meantime a triple set of '80s Lamco gauges happened to come up for cheap on Trademe. Thinking they could be a nice alternative option, I decided to chuck a bid in.
Okay, they do look rather... industrial, so I will find another use for them elsewhere.
PostPosted: Tue Mar 31, 2015 12:04 am
Been a while mate.. :)
Glad to see some work on the ol girls :)
Users browsing this forum: R34 and 2 guests
