It is currently Tue Jun 18, 2013 7:33 pm
Post a new topicPost a reply Page 7 of 9   [ 166 posts ]
Go to page Previous  1 ... 4, 5, 6, 7, 8, 9  Next
PostPosted: Tue May 11, 2010 10:00 pm
bout time we got an update lol
TacoDelRio wrote:
PostPosted: Wed May 12, 2010 3:28 am
yeaaaaaaaaaaaaaaah, i know :(
PostPosted: Sun May 16, 2010 6:28 am
....and...
PostPosted: Sun May 16, 2010 5:32 pm
ok ok ok.. Exhaust nearly welded up.. My mate was doing some welding and welds to close to the tip and welded the wire to it.. *sigh* oh well..
I keep looking at my front bumper dreading working on it lol
PostPosted: Mon May 31, 2010 3:06 am
PostPosted: Sat Jul 24, 2010 9:19 pm
Any Updates on this? :wink:
PostPosted: Sun Jul 25, 2010 2:25 am
Havnt done much, Well working on the wiring. Ran into some problems i need to sus out..
Here are some pics of the clean up we did :)
And yeah, that is me.. Scruffy as FARK
PostPosted: Tue Aug 03, 2010 10:08 pm
A little update, Good old Deecee picked up some supplies for my wiring in the ecu.
Finialy found the keys for the dam thing :D :D :D, So now i can actaully disarm the alarm (damn dynatrons)
BIG NEWS
Were moving, Bad news is that i have the pack the garage up, luckly we cleaned it out and filled the works rubish bin with what came out, lol :lol:
Luckly the new place has the same size garage but needs some TLC, so that will be intresting. Maybe ill document "garage repairs" in this thread.
The reasion for the move is that my partner has 5 horses and we have been paying for grazing off sence (avg 300 a month)
This place is a lifestyle block, nice and quiet :D
PostPosted: Thu Aug 05, 2010 11:57 pm
At this rate the R30 will be going for awhile yet :lol:
Congrats on the new house
PostPosted: Sun Dec 19, 2010 2:17 am
Cos Nick is such a slackass..
Just a couple of pics I found off my phone of some welding back at the old house
So last week I was over at Nick's to evaluate the wiring job ahead of me.
Yes, I did kindly volunteer to do his engine wiring and figure out any other electrical gremlins :)
We pulled the dash out to expose the bird's nest that is the factory wiring. Oh the fun of it all :)
Today I wandered over after some errands to start on the engine wiring and sorting it out. Nick had already started on the new link ecu engine loom by putting on a plug, but I wasn't satisfied in trying to figure out the link loom in situ, so I pulled the wiring out and grouped all the wires by function. This will make it easier to wire up to sensors, coils, injectors etc later on.
Half a mess
Tidy and grouped logically ready for wiring to the engine components.
More wiring fun later. I have to pull the old alarm and ensure that the timing thingimebob works. Nick, remind me to bring a battery over to get the headlights, dash and indicators working :)
PostPosted: Sun Dec 19, 2010 2:42 am
yay, fixed...
ok.. Dave dont forget the battery :P
Dave is dam awesome. Brought us some bar stools!.. yippie :D
PostPosted: Sun Dec 19, 2010 9:03 pm
Thats the plan mate :)
PostPosted: Wed Jan 19, 2011 3:58 am
on the weekend i took a break from my own car and worked on Nick's car for the day. can't be bothered explaining as i normally do, but the pictures should do the trick :)
edit - i'm going to explain what i've done just as a record for me :D
So Nick asked me some months ago to start to pull apart the plug so he could fix the broken insulation on the wire. Using a small screwdriver set, i popped the tabs and pulled the wiring from the plug
as you can see, the insulation has broken exposing the raw wire. This was the same for all wires into the plug.
the rubber grommet acts as a water resistance barrier. Commonplace on plugs in the engine bay. I pried open the retention tabs to release the grommet.
and pushed the grommet back along the wire. At this stage, I closed the tabs back so I could slip the heatshrink onto the wire
i then bent the wire 90 degrees and used a heat gun to shrink the heatshrink over the broken insulation.
then replaced the grommet, closing the retention tabs. its a tight squeeze with more insulation under the grommet
as you can see, all need repairing.
and all done
i pushed the wires/connectors back into place, ensuring that the metal lug clicked into place. as the grommet was thicker due to extra insulation, i used the jewellers screwdriver to force the grommet into place in the hole. always good when there is a satisfying click
nick was starting to mount the ecu, relays and fusebox. he had to cut the mounting tabs on the relays as he has relay holders for mounting. side cutters for the quick win.
next job was the coil loom. this came from an RB/holden setup (Nick can confirm) and we were having trouble tracing wires back to the ignitor, so I decided to strip it down to be able to trace wires back more easily
the person who nick got the loom and ignitor had replaced broken plugs previously, and subsequently soldered the new plugs on. UGH! Joints were not insulated properly, this having corossion on the wire and one of the solder joints had broken apart. If we were to fire up teh car, then tracing that issue would have been one of the last things we would have inspected. Lucky that I exposed the loom and its crap.
as you can see, insulation that has dried out and broken, exposing the wire.
all loom tape and insulation off. meassy job!
i like to use crimps when joining wire. Stronger and better electrical connection than solder.
4 plugs were replaced by the previous person, so 12 wires to crimp up. wires to particular coils were labelled 1-6. zip tied to ensure that I knew where everything should be going.
crimped up ready to insulate
smooth! everything a lot better now
takes a little while to do the job right, but at least we know that when the engine starts, that this is not a weak point if we need to troubleshoot.
roughly finished. I noticed that the two original plugs were broken and these will have to be replaced using the same methods as per above.
Once that is done, then i can go around with loom tape and some split corrugated plastic cover and that is one job done and dusted.
The White Elephant
PostPosted: Sun Jan 23, 2011 5:18 am
I hope hes got burbon in that coke for you on the 10th photo!
PostPosted: Sun Jan 23, 2011 1:24 pm
nope - i was just drinking coke for the day and he had some beers. i have to drive home after i do work at Nick's place, so i generally don't drink.
The White Elephant
PostPosted: Sun Jan 23, 2011 9:16 pm
updated with run through of what i did on the coil wiring loom :)
The White Elephant
PostPosted: Sun Jan 23, 2011 11:34 pm
thanks for the updates dude :)
PostPosted: Mon Jan 24, 2011 2:42 am
no worries. the photos were pretty self explanatory, but some context always helps
The White Elephant
 Post subject: Re: Stagefumers, Custom R30 build, OMG A UPDATE!
PostPosted: Mon Oct 29, 2012 9:25 pm
Well guys, i think its been over. hurrmm a year now? since ive posted a update.
Not much had been happening on the car front, no money etc. But something has been able to be done thanks to some deals i have done with my neighbor.
This is what availed :P
Please excuse the bad cellphone pics
 Post subject: Re: Stagefumers, Custom R30 build, THERE IS A UPDATE OMG!
PostPosted: Tue Oct 30, 2012 4:27 pm
Looks good! :tu: :mrgreen:
