It is currently Tue Jun 30, 2015 5:04 pm
Post a new topicPost a reply Page 1 of 3   [ 47 posts ]
Go to page 1, 2, 3  Next
 Post subject: 1985 sentra box
PostPosted: Mon Oct 24, 2011 10:56 pm
hey jnc,
I have a 1985 nissan sentra, its once had a rare cd17 diesel which ran like a sewing machine until about 206,000 miles, it lost oil pressure and died. Heres some pics of it with xxrs.., it has old school nismo/addco sway bars (yes they make them for this model). Bilstein front and rear shocks, 6kg front and 4 kg skunk2 coilover sleeves from an rsx and redrilled 240sx camber plates.
and a current pic with weds autobahn mesh.
I was totally bummed my Prized cd17 went out until this showed up. The cd17 block turns out
being a C series engine shares an extremely large amount of similarities to the CA18s block.
Furthermore with the B11 chassis being pre 2000 lbs, very much fun should result from a decent amount of power.
more later I guess xD
 Post subject: Re: 1985 sentra box
PostPosted: Tue Oct 25, 2011 10:44 am
Sucks the other motor died, but this one should make it fun.
Money Pits:
PostPosted: Tue Oct 25, 2011 2:45 pm
and out she came.
Also got one of these cool relay boxes and a complete CA18DE harness
out of a 1989 pulsar.
PostPosted: Wed Oct 26, 2011 6:30 pm
Swapped the differential+ bearings for one from a T11 stanza to suit the
1985 sentra cv axles. This is a transmission for a 1987 pulsar with the
ca16de
installed just after bearing preload checks.
Used the CD17 dust shield/trans plate, and 1987 pulsar CA16 flywheel+ clutch
deleted the power steering pump also, with a rear mount 1986 200sx alternator.
PostPosted: Wed Oct 26, 2011 7:04 pm
Cool car.
PostPosted: Thu Oct 27, 2011 10:27 pm
Placed all of the mounts U12 bluebird passenger side mount and the other CD17 engine mounts.
test fit went well.
also redid all the harnesses to suit the sentra, didnt get pics of that though :(
PostPosted: Fri Oct 28, 2011 1:54 pm
Im really liking this. Kudos man, I'm loving this build!
- 1984 Toyota Celica Supra 5M/5 Speed swapped <3
- 1986 Toyota Cressida 5M/Auto
- 1987 Toyota 4Runner SR5 Turbo <3
- 1985 Toyota Celica GTS Convertible
PostPosted: Fri Oct 28, 2011 2:41 pm
Lovin this build. I like seeing modern motors put into most older imports. Especially something this uncommon on the roads.
Money Pits:
PostPosted: Sat Oct 29, 2011 2:04 am
thats nice, we only had the ca18 as a DET, with turbo in what we call 200sx and you have as a 240sx. never seen it with a fwd gearbox. thats interesting.
Japanseklassiekers!
1970 C30 Laurel
1972 240Z
1973 610 Wagon
1977 260Z
1995 Micra
1999 200SX
PostPosted: Sun Nov 20, 2011 9:36 pm
Any update on this project? Looks interesting!
'81 Datsun 210
PostPosted: Mon Nov 21, 2011 9:39 pm
OH hey its blown, just wanted to let you know you've been a great inspiration with that B11 ice racer back in the day!
The CA is installed and functional, the right axle is a little short by 1/2" but the joint is still inside the cup far enough to be functional at all suspension positions. Ill have to order a custom shaft later on or frankenstein a set from another car or different year sentra. Ive put over 10,000 miles on it and it's been running very well. Furthermore the alternator was a bit close to the passenger frame rail, so I had to run the shortest belt possible to gain clearance from 1/4 of an inch to more than an inch which is the same as the old diesel engine. It is also running a walbro gsl391 190lph hour external pump without a surge tank, just have to keep it above 1/8 of tank capacity which is fine with me because it still has more than a 250 mile range with that.
And a video of the first time it ever ran. Timing was not set, there was no exhaust, and no air filter but wow what a great sound it was. Ill have higher quality video and more pictures with the swap fully complete when life slows down a little.
http://www.youtube.com/watch?v=ecsjEU5E ... r_embedded
PostPosted: Tue Nov 22, 2011 6:47 am
yes wonderin if you still had old diesel motor and if it was for sale phone# 214-240-0407 doug
PostPosted: Tue Nov 22, 2011 10:57 am
Nah sold it a while ago, its in maryland now.
Sorry.
PostPosted: Tue Nov 22, 2011 6:48 pm
Nice work Leadpaw! How aboutsome driving impressions? The car musy really haul now.
So you're using the original diesel transaxle? With the larger engine is that why the axle is short? If so is the other one too long now?
Mike
'81 Datsun 210
PostPosted: Tue Nov 22, 2011 6:53 pm
wow what a cool sentra. i saw a pulsar in a junkyard with a ca18de in it.... it was strange i didnt realize they offered that engine stateside. props for a different FF platform
mx32 2jz swap in progress
PostPosted: Tue Nov 22, 2011 7:49 pm
Mike
Im currently using a 1987 pulsar ca16de rs5f31a transmission, the cd17 F30a gearbox didnt work because the diesel engine had an absolutely massive flywheel, and bell housing to fit that. I also felt the rs5f31a trans was the minimum necessary to take the power of the ca18 (according to aichi machine the maximum designed input torque is 110ft/lbs for the 30a http://www.aichikikai.co.jp/en/products ... index.html). Since the bell housing was now shorter the diesel axle was too long to fit, so gas sentra axle it was which is a little bit too short. The cd17 block is almost identical to the ca18 in every dimension except deck height, it was about an inch or two taller than the ca18de block, id like to think the cd17 is probably closer to the ca20 in design.
Yeah the car is amazingly quick and torque steer surprisingly somewhat absent. Its great to have enough power to come out of lift throttle oversteer situations now rather than spinning out. Ill have some driving vids later :).
PostPosted: Tue Nov 22, 2011 7:51 pm
Thanks!
PostPosted: Thu Jan 19, 2012 1:04 am
Got rearended... please everyone never text and drive. Thankfully no frame damage, just some fairly minor body damage and my bumper cover went somewhere...
PostPosted: Thu Feb 09, 2012 5:34 pm
Was wondering if this cool Sentra diesel was still around.
Nice upgrade!!!
PostPosted: Thu Feb 09, 2012 5:52 pm
Always wondered if it was possible to make these generation Sentras "cool". You did. :tu: :mrgreen:
