It is currently Sat May 18, 2013 4:14 am
 Post subject: My 71' SR20VE 510
PostPosted: Tue Oct 18, 2011 12:47 am
I have the car posted around on other forums but I never got around to posting here so I'll just post everything, including the updates, in my first post. I just had it re-tuned and it put down 220/hp and 164/tq.
Current mods -
Motor and go stuff
S14 SR20DE block with SR20VE NEO VVL head (11:1)
R&D Factory high capacity oil pan
Custom Danstoy intake manifold, AE111 ITB’s and T3 velocity stacks
One off DGR equal length stainless 4-1 header
Custom DGR aluminum radiator with 12" electric fan
RCI aluminum overflow tank
LS7 coilpacks
2.5" exhaust with stainless Magnaflow muffler
S14 5spd with short shifter
Modified S14 driveshaft
4:38 JDM Subaru LSD
RCI aluminum 10 gallon fuel cell with walbro pump
Electronics
Haltech E6X EMS
Custom S14 wiring harness
Greddy oil pressure, fuel pressure and water temp gauge
Prosport 80mm tachometer
AEM UEGO wideband
Suspension
MADDAT engine mount kit with 1" front swaybar
MADDAT steering box brace
S14 Meagan front coilovers on 280Z spindles
Techno Toy rear coilovers
Techno Toy RCA’s
Techno Toy Camber plates
Techno Toy tension control rods
Cusco strut bar
280Z front disk brakes
Interior
Recaro SRD seats with schroth harnesses
Nardi Deep corn 350mm wheel, ACR (Japan) Steering wheel adaptor and Works Bell quick release hub
New carpet
Odyssey battery/bracket relocated behind passenger seat
Fire extinguisher
Taking delivery
Some initial pics
Edited pics
First updates -
Resprayed the door panels from the nasty original blue to black
Scrapped and recoated the fender wells
Low oil pan is low
Just finished these updates last week -
Prosport 80mm tach
matching Greddy fuel gauge
tripple gauge pod
AEM UEGO wideband gauge
orange LED bulbs to replace the stock speedo bulbs
mounted a fire extinguisher because you never know.
Header - welded two o2 sensor bungs, had it performance coated from Polydyn and replaced the stock gasket with an S15 7 layer gasket
a new set of LS7 coil packs
I had the injectors cleaned, flowed and balanced
-8 AN lines and fittings from valve cover to the catch can
I had the lower intake runners, velocity stacks and the catch can chromed
I tapped the lower runners for vacuum lines and ran them to a vacuum distribution block --> to MAP sensor
I had the valve cover and strut bar ends powdercoated a custom mix (pics do the color no justice)
Transmission and LSD flushed and filled with Amsoil
brakes and clutch bled and filled with ATE super blue racing fluid
 Post subject: Re: My 71' SR20VE 510
PostPosted: Tue Oct 18, 2011 6:47 am
Very nice!! :tu: Would love to hear the SR running...mmmm ITBs
PostPosted: Tue Oct 18, 2011 9:12 am
Nice, very nice, i like the car and the engine, and the combination is great!
Japanseklassiekers!
1970 C30 Laurel
1972 240Z
1973 610 Wagon
1977 260Z
1995 Micra
1999 200SX
PostPosted: Tue Oct 18, 2011 6:13 pm
O mai goodness. A carb'd SR20!! :shock: Super nice. I love it :tu: !! Is this how the car was delivered to you?? Looks like the car was well taken car of.
Constructive criticism: I honestly have reserves about the battery placement though. Although, Optima makes their batteries sealed, they also recommend that it's best that it be place in a separate sealed box of it's own due to possible fumes that may escape. Just a risk I personally wouldn't take.
Painting those interior door panels and adding the carpet was an awesome move. I hope that my 510 will eventually come out looking this nice. I still have a long way to go on my project.
What are the wheel specs btw?
I don't mean to drill you but that's a nicely done up 510.
PostPosted: Tue Oct 18, 2011 10:54 pm
Not quite. Individual throttle bodies. Still fuel injected but uses the same principal as twin dual throat carbs like dcoe webers or Dellorto dhla's etc which is one lot of mixed fuel and air per cylinder.
Best of both worlds really when you think about it.
In saying that, I think there are some SR20's getting about with carbs, there's no reason why it cant be done :mrgreen:
PostPosted: Wed Oct 19, 2011 8:11 am
Thanks guys :) I'm borrowing my buddies GoPro this weekend so I should have some video of it tooling around by next week.
:tu: It came with the motor and such already but it's taken a lot it to get it where it is now. As far as the body the car is rust free aside from what surface rust you can see. She's a little rough on the panels and paint but in great condition otherwise. I actually really dig the patina roughed up original look though.
I appreciate the battery concern, I do need to get a sealed box but I just haven't gotten around to finding one.
The wheels are 14x7 -9 w/ 185/55/14's all around. GL with your project.
PostPosted: Wed Oct 19, 2011 7:49 pm
can't wait to hear this thing! Make sure you do some in cabin filming with the gopro too!
PostPosted: Thu Oct 20, 2011 6:55 am
Me either! I've yet to ever rev it past 5K since I didn't really trust the old tune, and I've only driven once to work since I got it back with the retune. It will be the first time I rev it to 8K and I bet that motor is going to just scream :tu: In cab filming is all I'm going to do, not my camera so I don't want to take a chance of it falling off mounted outside.
PostPosted: Sun Oct 30, 2011 7:24 am
:shock:
so
perfect
ahhhhhhhh
mx32 2jz swap in progress
PostPosted: Wed Nov 02, 2011 1:20 am
TITS!
I love NA cars, they sound better... 8)
Bow
Old School Rules
'91 S13 Fastback Saki Sipper
PostPosted: Sat Nov 12, 2011 3:37 pm
Location: Taytay..Miami,Texas,New Orleans,Italy, France,Germany,Spain, Mexico..etc...next year Asia JAPAN..
the face looks exactly the same as the GTR nissan skyline...nice car...
MAILBOX.group@facebook.com
https://sites.google.com/site/mailboxfacebookcom/
PostPosted: Sat Nov 19, 2011 5:19 pm
looks sweeeeet :tu:
PSN=BigBadBarstow
NCRW Gaming Clan
My FaceBook
PostPosted: Sun Nov 20, 2011 11:03 pm
One of my favorite videos on youtube of a 4dr SR powered 510 is of your car. Not sure if you know these videos exist, there are about three that I saved on my favorites.
Car picks up some good speed @ 1:55
http://www.youtube.com/watch?v=-92JAmetbzo
Dyno pull
http://www.youtube.com/watch?v=t7YWNH6- ... re=related
First start
http://www.youtube.com/watch?v=ErgpQPFGJko&NR=1
Glad its in good hands. :tu:
http://www.HistoricJ.com
PostPosted: Sat Dec 17, 2011 2:26 am
Thanks all :)
Norcal510 - Yeah, I watched those vids numerous times before buying the car. Loved everything about it!
So I borrowed my buddies gopro for a day since I've had a lot of request to hear the VVL / ITB combo. Hopefully I can get more footage soon since I was only able to get a couple of pulls in.
http://www.youtube.com/watch?v=Waxlac41Q0w
PostPosted: Sat Dec 17, 2011 8:20 am
Definitely wasn't expecting any videos on this website to have some Big K.R.I.T. to it. That put a big smile to my face.
