It is currently Tue Mar 03, 2015 8:18 am
Post a new topicPost a reply Page 4 of 4   [ 65 posts ]
 Post subject: Re: Datsun Fairlady rescued from junkyard
PostPosted: Thu Jan 02, 2014 12:00 pm
next step - Front axle
- fully new built aluminum hub
- vented brake discs
- bigger calipers
- new wheels
- track tires
As I mentioned before I want to swap my bolt pattern from 4x114,3 to 4x100 because of the bulk of parts on our market. So I can use bigger, non OEM vented rotors from a .... fiat and calipers from a BMW E36.
So I have to design my own Hub and brake caliper adaptor. Because of the diamensons and the nonsuspended masses of course I used 7075 aluminum which is used in formula student and race cars too.
both aren´t last revision
1999 TOYOTA Altezza RS200, XE10
1969 DATSUN Roadster, SPL311
1972 NISSAN "Hakosuka" Skyline GT-X, GC10
1994 TOYOTA MR2 Turbo (GEN3) *RIP
PostPosted: Sat Jan 04, 2014 4:46 pm
I used the christmas and new year holidays for some work.
I got the new aluminum hubs
and pressed in the new bearings
aaand new bolts
Problem: caused of the radius I had to grind down a bit of the head
And this was my Advent wreath on third advent 8)
PostPosted: Sat Jan 04, 2014 4:52 pm
My selfmade christmas present:
These are DRAG DR20´s
15x7
Offset: 10
Tires are Federal 595 RSR
205/50 R15
PostPosted: Sat Jan 04, 2014 4:56 pm
Built up
a little bit to wide
but with a bit of camber adjustment
better 8)
PostPosted: Sat Jan 04, 2014 7:41 pm
Better a wide radius cut than a stress point! You made the right decision! You are doing an exceptional job.
MikeRL411
