It is currently Sat Mar 28, 2015 7:30 am
Post a new topicPost a reply Page 2 of 4   [ 62 posts ]
 Post subject: Re: lime yellow 240z
PostPosted: Tue Dec 20, 2011 4:44 am
Now that the body is almost painted i need to think about getting the motor ready to fit.
while i have the engine on the engine stand i will replace all the gaskets and seals as well as the cam belt and water pump. and give the engine a general clean up.
I have most things that i need to get the rb20 in and running but one thing i need is a fuel delivery system. I recently purchased a surge tank but i still need the lift pump and main pump. I will probably use a vl turbo for the main pump but i am on sure what pump i will use for the lift pump.
PostPosted: Sun Feb 12, 2012 11:54 pm
All the body has been painted at last ;D Now i just have to wait for all the trims and garnishes tyo be painted and there will be no stopping me putting it all back togeather
PostPosted: Mon Feb 13, 2012 9:29 am
Gorgeous.
PostPosted: Wed Feb 15, 2012 3:20 am
i have been getting to work 1 hour and a half just to i can get time to work on my car so i have managed to get a little bit done in the last few days :tu:
had the tail light surounds flares and bumbers painted today
PostPosted: Thu Feb 16, 2012 2:01 am
Great work mate! I'd love to check it out sometime, I live out north of Adelaide
PostPosted: Thu Feb 16, 2012 2:49 am
im out at murray bridge. maybe wen its all done we should have a south ozz jap nostalgic cruze :tu:
PostPosted: Thu Feb 16, 2012 5:22 am
Sounds like a plan mate :D You heading All Japan Day on the 26th @ Glenelg?
PostPosted: Fri Feb 17, 2012 6:02 pm
i would like to say yes but dont think i am going to find the time..
PostPosted: Sat Feb 18, 2012 2:12 am
I fit some old second hand rubber to my rims for now so i can fit up my willwood brakes. unfortunatly they would not fit in side the 14 inch rims and i still need to be able to roll it around. I will put some new tyres on when it gets closer to putting it on the road. These tyres are 235/45x17 all around but i will more than likely run 245 when the time comes.
PostPosted: Sat Feb 18, 2012 4:26 pm
Looking very sexy. 8)
PostPosted: Wed Feb 22, 2012 4:03 am
This is dam clean man, loving the work and the rb is just what it needs.
Btw you wouldnt happen to have the original engine harness would you?
PostPosted: Thu Feb 23, 2012 2:44 am
I am going to wait till i have it all together before i go getting rid of any parts as i might still need it. Plus i am from australia so the harness may be different because mine is right hand drive
PostPosted: Fri Feb 24, 2012 8:35 pm
looking real good mate, starting to come together, love the colour and the contrasting flare colour. will be awesome when your done im sure!
PostPosted: Fri Feb 24, 2012 9:44 pm
Oh yeah that might be a problem, your z is clean man though very jealous.
PostPosted: Sat Feb 25, 2012 3:52 am
zzzzed wrote:
Thanx man. 5 years on the body work. It would want to look smooth :)
I checked out your build thred. Yours looks cool man. You will get there. Atlest you can drive yours with out being worried about damaging or scratching it. I have been building mine for 8 years now. I have forgotten what it was like to drive.
PostPosted: Fri Mar 02, 2012 3:10 am
More pretty pictures ;D next week i will be putting in some brakes so i can bring it home ( i have a rather steep drive way and would like atleast a hand brake so i dont lose it through the back of the shed :o
PostPosted: Sat Mar 10, 2012 3:17 am
this week i have been working on getting the brakes fitted up. the fronts were easy as they came in a kit. but the rears are from an r31 skyline and i had to do some work to make them fit, Next week I will be fitting up the brake lines and hand brake cables and hopefully it will be able to stop when i roll it down my drive way :D I will be rebuilding the rear brakes before the car goes on the road. ;)
PostPosted: Mon Mar 12, 2012 2:20 am
Awesome work, that lime is the best colour for S30s IMHO.
Regarding the rear brakes...honestly...Aussie R31 rear calipers are garbage. I would have stuck with the drums, at least you'd have a functional handbrake and they wouldn't seize.
PostPosted: Wed Mar 14, 2012 3:07 am
i need rear disks to get it past for rego with the rb20 in it. I will be upgrading to willwoods for the rear a bit later, I have already hooked the hand brake up and it works fine :tu:
PostPosted: Fri Apr 20, 2012 5:21 am
loaded up and homeward bound
its new home
