It is currently Wed Jun 19, 2013 3:39 pm
 Post subject: 1963 datsun p312 engine rebuild
PostPosted: Wed Apr 13, 2011 12:38 am
Hi all,
Just in the middle of an engine rebuild for my 312 bluebird and have a question for anyone who has rebuilt a nissan E1 engine,
would they know if the timing chain is the same as what is fitted to the datsun A12 engine .....? I have seen some infomation recently that would sugest that it may be but have not been able to confirm it...
Any help appreciated. :lol:
Drew.
PostPosted: Wed Apr 13, 2011 5:46 am
I don't believe it is...... but I have nothing other than the vague feeling i read it somewhere.... lemme check a bit more.
www.ndsoc.com.au
 Post subject: Re: 1963 datsun p312 engine rebuild
PostPosted: Thu Apr 21, 2011 7:28 am
E1 Engine = 52 link chain
A12 Engine= 54 link chain
Beside the amount of links, the chains are identical-
1971 TE28 Corolla
1980 TE72 Corolla
1995 S14.5 240sx
2005 R6
PostPosted: Thu Apr 21, 2011 11:57 pm
cheers mate,
I think i may have solved the problem by using a timing chain from a 1968 mgb.
all i need to do is a few more measurements and should be sweet.
Already have a new set of pistons 30 thou over size to go in and motor is
being line bored & tunnell bored as we speak, or type....
have drilled out and removed all the oil gallery plugs from the block and have new ones to go in.
Will keep you posted, am also using a timing case cover from an mgb as it runs a rubber seal instead of the factory felt seal the nissan ran.
thanks, Drew.
Users browsing this forum: Nismopunch and 2 guests
