It is currently Thu Jan 29, 2015 1:34 am
Post a new topicPost a reply Page 6 of 7   [ 135 posts ]
Go to page Previous  1 ... 3, 4, 5, 6, 7  Next
 Post subject: Re: my datsun 1800 c30 laurel
PostPosted: Sun Jan 05, 2014 12:48 pm
I love it, all of it! We have a great japanese classic car event coming up next year, ill make sure you'll get an invitation too!
Japanseklassiekers!
1970 C30 Laurel
1972 240Z
1973 610 Wagon
1977 260Z
1995 Micra
1999 200SX
PostPosted: Tue Jan 07, 2014 2:18 am
Super cool project! 8)
Love the retro-racer-style that you've gone for.
Hmmm... but curious about the roll hoop? Do you plan to always drive the car with a crash helmet on? Cause if you're invovled (God forbid!!) in a minor fender-bender, you'll no doubt whack your head against the roll hoop, and rather than being a safety device, it'll actually inflict way more harm to you than would have been the case without the roll hoop in place. :roll: Just a thought...
Best Regards,
Anders.
PostPosted: Tue Jan 07, 2014 4:56 am
hi 02anders
actualy i have the same thoughts!!
but i have to protect the roll cage with foam tubes.
not for the good look but for my own safety.
and i will never get it registered in switzerland without these protections!!
i dont like many of our car rules but this one makes sense!!
PostPosted: Fri Jan 24, 2014 12:49 pm
hey eric,i liked my last stay in the netherlands very much,as well as my girlfriend!so feel free to send me an invitation.maybe im planing 2 trips to you guys??!! 8)
PostPosted: Fri Jan 24, 2014 1:07 pm
in christmas holidays i worked with my Dad on the cylinder head of the G18 engine.widened intake for the G20 manifold,worked on valve seats,changed valve stem seals and head gasket and put the head back on the engine.
i restored and painted my frontbrake calipers.added new brakelines and pads.
PostPosted: Fri Jan 24, 2014 1:23 pm
i also picked up my valve cover from powdercoating and sanded down the letters.very happy with this one 8)
also cleaned out the radiator and put it back to the car.
PostPosted: Fri Jan 24, 2014 1:31 pm
some of the next work i will do is to build a G18 exhaust manifold.stay tuned 8) 8)
PostPosted: Sun Feb 02, 2014 8:24 pm
awesome
PostPosted: Mon Feb 03, 2014 1:26 am
Engine looks sweet :tu: .
I read somwhere that G18 exhaust manifold portspacing matches L18 but flanges have different
boltpattern. Would need to get that verified tho. L18 has way better design of the manifold than the G18.
Did you compare the twin carb G20 camshaft to the G18 cam ?
PostPosted: Mon Feb 03, 2014 2:14 pm
hey tojo,
jep the l18 manifold looks better,but i want to create my own manifold.
i will order 3 pcs. of boltpatern.we have a lasercutter in our workshop.
so when i have finished the manifold you can decide if you would like to have one too!
i did not compare the cams,i am not that engine crack!do you think it would be an upgrade with the G20 cams?
PostPosted: Tue Feb 04, 2014 1:17 am
Sounds great Stev.
Not sure. Going from brochures Ive seen there appears to be two vertions of the G20 :
High comp. twincarb and low comp. single carb.
Im guessing as G18 is low comp it would have the same cam as low a comp G20 and possably
the High comp twincarb G20 would have a more agressive cam.
Raising the compression ratio a bit + a more agressive cam would be an upgrade along with
your twin carbs and header.
I didnt have valvefloat issues with the G18 even tho I used to rev it realy hard. Both G18 and G20 have double valve springs
Like I said, Im just guessing on the cams as I dont have parts catalog to compare.
but higher static comp ratio often means larger cam.
If you still got the G20 it would be easy to measure the valvelift using a dial gauge
PostPosted: Tue Feb 04, 2014 4:29 am
nice info thank you!
i still have the g20 but its still how it came to me.
i just have removed the intake manifold.
i think i want to have my engine running first then i check out if the cams would be a good upgrade.
my engine manual is still at my dads house with the carbs.
maybe there is a describtion about the different cams.
PostPosted: Tue Feb 04, 2014 4:41 am
sounds like a good plan 8)
PostPosted: Tue Feb 04, 2014 9:06 pm
Cams are the same...no difference on the part number
PostPosted: Wed Feb 05, 2014 2:30 am
Thank you :D
PostPosted: Wed Feb 05, 2014 4:44 am
thanks!
PostPosted: Wed Feb 05, 2014 2:06 pm
If you want new custom cam, contact isky
PostPosted: Thu Feb 06, 2014 4:57 am
isky? member?
btw: @yayoi your parts are still aside and are waiting for mai. cheers
PostPosted: Thu Feb 06, 2014 8:55 am
Iskycams.com :D i should be back in april...are you making an octopus exhaust...similar to this: Image
PostPosted: Mon Feb 10, 2014 12:18 pm
@yayoi
i think my manifold will more look like the tomei manifold for the 310.
the manifolds on your pics will maybe look too agressive for our police officers :cry:
Users browsing this forum: DmK66 and 6 guests
