It is currently Tue May 21, 2013 2:31 am
Post a new topicPost a reply Page 3 of 13   [ 253 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6 ... 13  Next
PostPosted: Tue Dec 07, 2010 8:27 pm
love the ken mery do you own the 1970 mach 1 also?
PostPosted: Tue Dec 07, 2010 10:27 pm
very hot mate, do want. but my dream is a 72 kpcg10 GTR
http://xs39.xs.to/pics/05302/snoopsig.jpg
this is nissan country thats why i gate people
PostPosted: Tue Dec 07, 2010 11:46 pm
drift86 wrote:
This whole thread screams JNC MEET!!! WHEN? WHERE?
I'm in so long as the weather holds.
PostPosted: Tue Dec 07, 2010 11:51 pm
Im down, Bay area seems like the place to do it, seems like most of you guys live over that way.
PostPosted: Wed Dec 08, 2010 8:08 am
Yes weather permitting we should come up with a day....sorry for the thread jack Norcal510, but i know you wont mind having an idea of a meet thrown out there. The only hard desicion you'll need to make is..Hako?..Kenmerri? :lol:
PostPosted: Wed Dec 08, 2010 6:15 pm
I'm in for a meet, I'd love to see another Skyline in person. Now that I have the roadster back on the road I can even show up in something vintage and Japanese.
Will
'87 BMW M3
PostPosted: Thu Dec 09, 2010 12:33 am
Lets do it, Norcal510, you should bring both...
PostPosted: Thu Dec 09, 2010 3:00 am
Hello all,
As I can see the thread has grown a lot since I last posted. I had been busy enjoying my time off from work & working on the C110.
Few things I bought from YAJ.
I wanted to re-install the original badges so I ordered what was missing and the correct GT-R badges.
Once the rain let up I started to pull off the current badges and installed the new ones.
If you look closely you can see the original holes for the GT-X badges. The mounting studs on the GT-R badges run up & down vs. side to side so I'll have to weld those up. I have a trick to remedy that until I decide to pull the panel off to fix the dent & weld the holes up.
Since I don't have the exact measurements on where the badge sits. I pulled out a copy of my favorite magazine "Nostalgic Hero". If you look closely you can see the badge is placed slightly off to the right of the skyline badge. The top of the R lines up about halfway down the middle of the "E" on the skyline badge.
Rather than just drilling holes without making sure it’s even I used tape below as a guide to make sure everything is lined up. I also added some paste to the back of the mounting studs so once I had decided on a final location the paste would leave a white mark on the panel to show where to drill
Next what to do with the original holes? Well I plan to remove the rear panel to repair the dent that could be seen in a few of the pictures. But at the current moment I want to enjoy the car before I start to tear into it. So what I’ll do is lay a bit of epoxy glue as a skim coat between the holes. It’s not a permanent fix but will remedy the problem until I weld up the holes. I also have some grey metallic paint left over from past jobs I've done that I could use as touch up.
The epoxy sets in less than 5 minutes which allows the glue to remain stiff. I set some tape over the holes then punctured the holes. The tape allows me to spread the glue in the hole without getting it all over. Let it set for two minutes & then removed the tape.
The final product
Although the badge has small retaining clips as security measure I added some double stick tape
The color of epoxy actually somewhat matches the panel. I still plan to touch it up with some paint.
Next the front badge & the water pump. I can see I have a few ppl to reply to so Ill get to that first.
http://www.HistoricJ.com
PostPosted: Thu Dec 09, 2010 8:31 am
im crying tears of joy...or is it jealousy? lol maybe just cuz im at work and you are playing with your new skyline adkl;askdl;aksd :twisted:
PostPosted: Thu Dec 09, 2010 10:40 am
Nice job with the badge. It's good to see that this car is in the hands of someone who really pays attention to the little details. :tu:
PostPosted: Thu Dec 09, 2010 11:40 am
GTS-Retro wrote:
Are you going to enjoy the car as is, or have bigger plans?
For now just enjoy the car. I did get another pair of Watanabe wheels from a member here. 15x12 -51. I had planned to put them on the c10 but maybe Ill put them on the c110.
Haha yeah its been so long since the last one. We should have one for sure!!
How did you know it’s a Mach 1? The pictures don’t give much detail. Oh and yes that’s one of my cars.
If xs10shl comes out we must have a meet. I waited a long time for this car but waited even longer to see an s20 in the flesh. :lol:
Yes there are a few of us here in the bay area. When do you plan to come out this way?
Lets make this happen. Treasure Island is right in the middle of everything. Suggestions?
Will
Perfect I was hoping to see your roadster in person .
Again thank you for all your comments. :tu:
PostPosted: Thu Dec 09, 2010 12:33 pm
Vs
The rear badge should have the surrounding surfaces blacked out similar to the rear badge.
Time to mask the face off & spray some S.E.M. trim black. I started to use a grey scotchbrite but as you can see its not coarse enough to prep the surface so I switched to the red scotchbrite.
Masking the face using painters tape & razor blade.
The difference once using the red scotchbrite.
After scuffing all the surfaces really good it's time for some color.
After three coats & letting it dry
There are a few edges that need to be defined but that will be fixed by some polish.
Final product
Next the water pump... will post later today
PostPosted: Thu Dec 09, 2010 1:31 pm
Holy cow, nice job masking that front emblem. :tu: Not a whole lot for you to clean up, hm? This is a nice education for me, as I never knew the Kenmeri GT-R emblems were any different until I saw this thread.
PostPosted: Thu Dec 09, 2010 5:13 pm
I don't know how hot it gets where you are, but those aftermarket water pumps are a known problem. The stamped steel impeller doesn't pump water as well as the stock cast steel impeller.
I've had 3 Datsuns with cooling problems that were hard to diagnose. All were fixed with removing that pump and installing a factory pump.
PostPosted: Thu Dec 09, 2010 6:22 pm
wow thats an amazing detailed post just for emblems! definitely makes me look forward to the rest of the build! oh and the emblems came out great too :wink:
PostPosted: Thu Dec 09, 2010 11:50 pm
usually 100-110 would be the hottest around here for a few days out of the year.
as for meeting up im always down for a meet. unfortunately my Z can't join the skyline fun, but ill bring one of my other non-JNC rides.. :cry:
PostPosted: Fri Dec 10, 2010 1:55 am
First time reading this thread. DAMN!!! Luke we need to join the Skyline club. =)
PostPosted: Fri Dec 10, 2010 4:14 pm
Dude..i might be a little turned on....it looks like that GTR badge was giving us the striptease treatment 8)
PostPosted: Sat Dec 11, 2010 2:45 pm
haha yeah i know...i dont have enough room for anymore cars so buying a house is priority one...so that i can buy more!! haha
PostPosted: Wed Dec 15, 2010 11:03 pm
So the water pump was leaking when It arrived. Not much but it was time to swap out a new one.
I figured the water pump on the L20 would be the same as on L28 so that’s what I ended using.
The old & the new
It appears they both are similar.
As datsunfreak pointed out the old pump impeller is made of cast steel.
I didn’t like color of the pulley and while it was off I decided to paint it black.
The fan was in good condition
New pump installed.
Before I put everything back together I wanted to make sure the pulley and fan lined up.
While I was painting the pulley I decided to pull the alternator bracket as the paint looked a bit tired & needed a fresh coat.
After
Final product with everything put back together.
Next the side rear quarter panel emblems. It appears the sun will be back out tomorrow so I will take the car out for a spin.
