It is currently Wed Jun 19, 2013 7:40 pm
 Post subject: Junk aftermarket fuelpump ground metal of cam gear face
PostPosted: Sat Nov 13, 2010 7:09 pm
I decided to check my valve clearances today to hopefully reduce the sewing machine noise in my l20b. Once I got the camcover off and started turning the motor over I noticed the fuel pump arm wasn't riding on the fuel pump eccentric, it was loose, so the arm could move left and right, and it did just that, wearing a chunk of metal out of the front of my cam gear, will be switchin to an electric tommorow. I am sure it was recently swapped out for an aftermarket one but there are no receipts to be found in the pile o'maintenance records :( Has anyone ran an electric on these before, if so anything I should look for in particular and should i use a fuel pressure regulator?
PostPosted: Tue Jan 18, 2011 4:00 pm
did you have the spacer insulator installed?
 Post subject: Re: Junk aftermarket fuelpump ground metal of cam gear face
PostPosted: Tue Jan 18, 2011 6:04 pm
It's usually minimal fuss.
FYI, the block-off plate for a big block Chevy fits right onto an L-series head. :tu:
Depends on the pump, carbs, engine, etc.
Assuming stock-ish L20b and 2-barrel carb, if you use the low pressure Holley/Facet pump you won't need a regulator.
FYI, these types of pumps work better as "pushers" than "pullers", so try to mount it low at the rear of the car.
