It is currently Sat May 25, 2013 11:07 am
 Post subject: 1980 a10/ 510 wagon question
PostPosted: Thu Sep 16, 2010 5:33 pm
so i picked up a 1980 510 wagon about a month ago and been having lots of trouble finding info on it. or any parts for it. so any info would be very helpful. but my main question was should i go ahead and give it the shakotoan treatment or leave it stock. ps its in really great condition no rust or problems at all just 235xxx miles on the od.
thans to anyone help
PostPosted: Thu Sep 16, 2010 6:01 pm
Haha. I searched for "Stanza wagon" and got a bunch of Prairie vans :lol:
Anyway, I'd never cut apart a decent car but I suppose the violet/stanza/510 would be one of those cars that lends itself to the look...
I wouldn't fault jdm grille/headlights etc. But I'd likely stop there...
In any case, there don't seem to be any shakotan pics of such a car on the internet.
 Post subject: Re: 1980 a10/ 510 wagon question
PostPosted: Thu Sep 16, 2010 7:21 pm
Welcome to the world of the unloved and under appreciated car. 8)
And as Dachsund alluded to, you probably need to be searching "Violet" or "Stanza", the names it was sold under elsewhere. :tu:
Shakotan. All the way. :twisted:
Good. Then all you need to do is add all the fun stuff. :mrgreen:
PostPosted: Fri Sep 17, 2010 11:55 am
ok shakotan all the way :D .i have tried every name its just the same info as wikepedia.lol :D
PostPosted: Fri Sep 17, 2010 5:31 pm
Good then. You'll be the first. 8)
If you need any info on brake/performance upgrades, ask away. I've owned 4. And modified 3. So... :mrgreen:
PostPosted: Wed Sep 22, 2010 4:42 pm
yay someone that knows about my car.lol.do you what larger brakes will fit.thanks
PostPosted: Wed Sep 22, 2010 7:56 pm
You need to visit the junkyard and find a complete set of front struts/brakes from a '79-83 280ZX. 8)
Do that, then I'll tell you how to get them in the car. :P
PostPosted: Wed Sep 22, 2010 8:56 pm
Look for Datsun 140J/160J, that was the name of that car here in South America.
1973 Datsun 260C Hardtop
1980 Datsun 280ZX 2+2
1982 Datsun Bluebird 1,8SSS, Megasquirted.
PostPosted: Thu Sep 23, 2010 7:07 am
What??!!! Those 80's square headlight wagons are pretty rare. They look very similar to the Skyline wagons in Japan.
Leaf suspension in the rear. I'm sure Datsunfreak has a trick up his sleeve. :wink:
PostPosted: Wed Sep 29, 2010 6:01 pm
i picked up some 280zx struts and brakes finally from a guy down the street.lol.so wats the secret for putting them on.lol :D :D
PostPosted: Wed Sep 29, 2010 8:38 pm
Use the strut housing, insert (preferably new), caliper, hub, and rotor from the 280ZX. Use the springs, upper spring isolator, and upper strut insulator from the 510. The 510 spring will be a smaller diameter so you either need to cut the 280ZX spring perch off and weld on the 510 perch, OR you can cut off the top 1/3 of the 510 spring perch and set it inside the 280ZX spring perch. You can then weld it (if you have access to a welder), or just leave it as is. It will "nest" in there perfectly, and the spring will hold it in place. Generally I will cut the 510 spring down to a height where you can just put it back together without a spring compressor. This usually gets the tire right even with the edge of the fender (zero fender gap). The stock master cylinder will usually be fine with the upgrade, especially with cars that have power brakes.
PostPosted: Fri Oct 01, 2010 11:55 am
We don't call him Da'freak for nuttin' :)
PostPosted: Sat Oct 09, 2010 3:19 pm
ok.thanks for the help and info. :D ill post pics when im finished.lol
