It is currently Mon May 20, 2013 10:04 am
Post a new topicPost a reply Page 3 of 6   [ 102 posts ]
PostPosted: Sun Apr 10, 2011 8:30 am
Eric wrote:
Funny why everyone calles this an s110 and not just s11, like the s12 and s13 and s14..
Well, that's because Nissan called it an S110. If it was good enough for them, then... :P
Now if you're arguing they should have called it an S11, I'm with you. :tu: :mrgreen:
PostPosted: Sun Apr 10, 2011 1:02 pm
so nissan did it, well we cant argue with that :)
Japanseklassiekers!
1970 C30 Laurel
1972 240Z
1973 610 Wagon
1977 260Z
1995 Micra
1999 200SX
 Post subject: Re: Datsun Silvia S110 SR20DET project
PostPosted: Tue Apr 19, 2011 10:57 pm
The S110 was the next in the chain. This Silvia was unusual because it was originally intended to feature a rotary engine, designed and built by Nissan. This engine however was fairly unreliable, and forestalled production. Ironically it shared a chassis code with the also ill-fated Mazda Cosmo, first Japanese production car to feature a rotary engine. This generation saw the debut of the "Gazelle" name, used for the luxury models of the S110. It was redesigned shortly after it was originally released, the rotary replaced by several piston engines for different markets, most based around the new Z-series engine, including the Z20, and the turbocharged and fuel injected Z18ET. It was not the most powerful though—the Silvia RS240 was a notchback S110 fitted with a 2.4 litre, DOHC, FJ24 engine, built between 1983 and 1985, past the end of production for the S110 itself.
PostPosted: Sun May 01, 2011 12:33 pm
The clock in the dashboard isn't working! Does anyone know how to repair it? or anyone who can repair it?
PostPosted: Mon May 02, 2011 9:35 am
er i smij verteld dat je die hele klok dan in peut ozo moet hangen, zodat het oude vet oplost wat erop zou zitten, als dat opgelost is moet ie weer lopen gaan...
ik ben er nog niet aan toegekomen dat te proberen.
Japanseklassiekers!
1970 C30 Laurel
1972 240Z
1973 610 Wagon
1977 260Z
1995 Micra
1999 200SX
PostPosted: Fri May 06, 2011 3:03 pm
reincarnation :tu:
PostPosted: Sat May 07, 2011 12:04 am
What did you use to drown your clock in? Good stuff!
Japanseklassiekers!
1970 C30 Laurel
1972 240Z
1973 610 Wagon
1977 260Z
1995 Micra
1999 200SX
PostPosted: Mon May 09, 2011 12:30 pm
HG Rust and Oxidation Remover, great stuff! :tu:
PostPosted: Mon May 09, 2011 5:30 pm
Does it have a list of ingredients? I would like to know what acid is in it.
Thanks
Rory
Neverliftgarage.com
1976 Laurel SGX
PostPosted: Mon May 09, 2011 11:24 pm
HG :) Who can live without it :)
Took the clock form my carina today and tried to get it working but i think i killed it :)
Japanseklassiekers!
1970 C30 Laurel
1972 240Z
1973 610 Wagon
1977 260Z
1995 Micra
1999 200SX
PostPosted: Tue May 10, 2011 12:51 am
Thanks
Rory
• PRODUCTINFORMATION
Characteristics : an acid free oxidation remover
Density : ±1,06 g/ml
pH : 7 - 9
Components : organic sulphur components and water.
http://en.be.hg.eu/userfiles/product/info/EN/P211.pdf
PostPosted: Wed May 25, 2011 5:30 pm
Awesome build, nice work! Good to see other s110 out there.
PostPosted: Tue Jun 07, 2011 1:26 am
Updeetje,
[img width=264 height=600]http://i820.photobucket.com/albums/zz122/B12-power/ombouw99.jpg[/img]
Erwinneke een strip laten knippen en zetten! O0
PostPosted: Tue Jun 07, 2011 1:28 am
PostPosted: Tue Jun 07, 2011 1:34 am
PostPosted: Tue Jun 07, 2011 8:59 am
Nice, i bought an s110 too, the red on from Marktplaats, ill pick it up at the end of the month, hope it doesnt take too much work to get it on the road again.
Japanseklassiekers!
1970 C30 Laurel
1972 240Z
1973 610 Wagon
1977 260Z
1995 Micra
1999 200SX
PostPosted: Tue Jun 07, 2011 10:13 am
I saw the add on the internet! If you get it on the road you've a cheap car to drive because it's free of tax and running on LPG-gas! :tu:
PostPosted: Tue Jun 07, 2011 10:51 pm
Thats the reason why i bought it ;)
Japanseklassiekers!
1970 C30 Laurel
1972 240Z
1973 610 Wagon
1977 260Z
1995 Micra
1999 200SX
PostPosted: Thu Jun 16, 2011 9:43 am
PostPosted: Thu Jun 16, 2011 8:22 pm
Nicely done. :tu:
I love the color. :mrgreen:
