It is currently Wed May 22, 2013 9:37 am
 Post subject: quick question on hr31 skyline
PostPosted: Mon Sep 06, 2010 9:32 pm
Hey all. My mate just bought a hr31, and its having problems turning over, takes a lot of tries to start it and now its not turning over at all. So.. i am thinking its starter motor and was wondering if the australian r31's starter motor will fit on to the hr31.
Cheers
Edit: Also if anyone has some spare parts they would like to sell or know of anyone that would like to, the car just got back from the suspension shop, and he needs to source some front strut rubber peices that go between the chassis and top of the strut, rear wheel bearings, and power steering pump as normal australian r31's dont fit, that's why i was asking in above question. which is not so quick anymore. lol.
Also, he needs a power window motor.
This car before he bought it, a few weeks ago was not treated very good and hasn't been looked after well at all. So it should be nice again soon =)
PostPosted: Tue Sep 07, 2010 9:05 pm
RB30 Starter motor should fit, as will one from a later RB20, i.e. R32. Tentatively I'd say any RB one will work...Best shot would be to go to an import wrecker with the offending item and compare and use the newest one which will fit.
Otherwise many auto electrical specialists can rebuild them.
It is a soul destroying trial to try and remove/refit the starter with the engine in the car, I am warning you now.
I believe you can adapt strut tops from the Aussie cars...Have not tried however. I would imagine the rubber is the same for both, get a urethane replacement aftermarket.
Rear wheel bearings, you have two choices. Knock out the old ones and go to a bearing shop, or just buy them new from Nissan (around $270 to kit both sides with bearings and seals).
Power steering pump is dual chamber and unique to HR31s. I threw mine out I am afraid :oops: but there would be many places who can rebuild them.
Power window motor should be available new from Nissan ex-Japan in the short term.
Do check out http://www.r31skylineclub.com
I wish him good luck, these cars are brilliant when working correctly but can hide many costly and obscure problems.
PostPosted: Tue Sep 07, 2010 9:44 pm
Ahh thank you so much for all that info!!
Yesterday we solved the problem, there was some thing connected to the battery and a lead going off somewhere else. still not sure what it was but it was a piece of metal shaped like a semi circle and had another little bit on it that you could click around it. we moved it and it started up. moved it back and it didn't go. so it must be some immobiliser or some sort..
Cool, i will tell my friend about this, and thanks once again :D
also.. You are from tassie aswell? Where abouts. we are from launceston.
Here is a pic i took the day he bought it. not too good quality, but oh well. i will try and get some good ones later :D
PostPosted: Tue Sep 07, 2010 10:50 pm
Yeah I'm in Hobart. I know that car, well, knew of it when it was living on the Eastern shore anyway.
PostPosted: Tue Sep 07, 2010 11:28 pm
Coo. Yeah, he bought it from a guy in risdon vale...
PostPosted: Wed Sep 08, 2010 12:10 am
I might have a power steering pump.
Have to have a look (I've got boxes of HR31stuff-see my thread)
What is wrong with your pump?
Hooks
PostPosted: Wed Sep 08, 2010 12:27 am
Thanks, I'll check out your thread. :)
It has a leak in it and have to fill it up every now and then.
PostPosted: Thu Sep 09, 2010 2:42 pm
OMG! you have an HR31 with a power steering leak! :shock:
:lol:
It'll be a hose.
Hooks
PostPosted: Sun Sep 19, 2010 1:07 am
lol its more then likely goin to be the rack itself leaking and not a hose
PostPosted: Sun Sep 19, 2010 6:33 pm
I think HR31s come from the factory with a power steering leak. :lol:
Hooks
PostPosted: Wed Sep 22, 2010 1:25 am
all r31s come factory with power steering leaks :P
PostPosted: Sun Sep 26, 2010 7:09 pm
mine didnt!!!!!!....but it does now :(
gimme all your cars!!!
PostPosted: Thu Sep 30, 2010 3:36 pm
haha yeah.
mine actually didnt leak untill i tried to remove the hicas.
haha
but its fixed now and hicas is dead :)
PostPosted: Fri Oct 01, 2010 12:50 am
This is a misconception.
Not all R31s had power steering.
