It is currently Tue May 21, 2013 12:56 am
 Post subject: Sunny 210/310 Suspension Compatibility?
PostPosted: Wed Jun 09, 2010 12:58 pm
I own a 1980 Sunny 210/310 and was wondering what suspension, whether or not from another datsun/nissan or even a toyota, is compatible? I'm a bit of a Corolla Freak and was thinking about swapping the front suspension and rear springs for that of an AE86... is it possible (before I actually try it out)? Anymore info is greatly appreciated.
Oh and by any chance, what are the gear ratios on the rear differential? Will it hold extra power?
Thanks guys!
1980 Toyota Corolla 2DR Sedan - 3TC Street Modded
1980 Datsun B310 Coupe - Low + Slow
2006 Scion xB - DD
 Post subject: Re: Sunny 210/310 Suspension Compatibility?
PostPosted: Wed Jun 09, 2010 6:04 pm
I wouldn't waste my time with the AE86 stuff. Brakes aren't really big enough to justify all the fab work involved. If you can get the complete front struts/brakes from a '79-83 280ZX they are a HUGE upgrade and a piece of cake to install. No real fab work involved. :tu:
Nope. It barely holds the stock HP. :P
Try finding a rear axle assembly from a '78-82 510. MUCH beefier, and fairly simple to transplant. Common upgrade for B310 race cars. :tu:
Stock ratio should be a 3.90, as are most of the Datsun 4cyl cars. :mrgreen:
PostPosted: Thu Jun 10, 2010 8:01 am
What about a 240's strut/brakes (they're easier to come across)? And isn't the 510 IRS? The sunny is a solid rear I'm not sure how difficult that'll be to transplant. Would a pickup rear do? Sorry I don't mean to be such a headache it's just that these cars are so rare to come across and no one really modifys them as much as Z's and 510's.
2006 Scion xB - DD
PostPosted: Fri Jun 11, 2010 2:07 pm
The late style 510 (chassis code a10) is not IRS.
If you mean 240Z fronts, that won't work on a Sunny because the king pin inclination is all wrong. You'll have a bunch of positive camber.. too much to sort out with camber plates or eccentric bushings.
If you mean 240SX, I think that can be done, but requires a lot of fabrication to get things to go together. At least as hard as doing an AE86 swap would be.
Like DF said, 280ZX stuff is common, cheap, and a very nice upgrade and the swap can be done with just the right mix of junkyard parts and very little fabrication compared to the 240SX or (probably) AE86.
I had 280ZX stuff on my 510, and it stopped better than my Sentra does with a 12" Brembo 4-pot kit...
PostPosted: Fri Jun 11, 2010 8:27 pm
As he said, the 68-73 510 is IRS. The 78-82 510 is 4-link live axle (just like a B310/210).
Well, it's the wrong style (leaf spring, not 4-link), and it has a 6-lug (not 4-lug like yours) wheel bolt pattern. :wink:
So, no. Not a good idea. :P
I've modified plenty of them, so ask away. :mrgreen:
PostPosted: Sat Jun 12, 2010 5:33 pm
Thanks guys...now the problem is finding a 280 or a 510 @ a junkyard. Lol. I think I know where a 280 might be. Let's see what happens.
2006 Scion xB - DD
PostPosted: Sun Aug 01, 2010 12:31 pm
@ TE72 - I think I recognize you from another forum. Your bro is MetalMonkey right?
I'm fallin more in love with the 210's. There's an 81' by my place, that I've left notes on the guy's car and been checking it out almost every other night. No response yet but hope for the right price, I can scoop it up and give it a good home.
PostPosted: Mon Aug 02, 2010 6:45 pm
Yup, Ratsun! :D I don't know about metalmonkey being my brother, but he's definitely a 210 guy!
I wish you luck, pal! Cars are a great addiction and if you can afford it and obtain a collection, more power to you! Make sure you post pictures though.
2006 Scion xB - DD
PostPosted: Mon Aug 02, 2010 6:56 pm
Just make sure it's a 280ZX, not a 280Z. :wink:
You'll know because only the 280ZX has vented rotors.
PostPosted: Mon Aug 02, 2010 7:30 pm
Cool thanks for the heads up! What's the difference anyway?
2006 Scion xB - DD
PostPosted: Mon Aug 02, 2010 8:17 pm
Bolt pattern where it bolts to the steering knuckle is wrong on the 280Z strut. And the spindle angle is all wrong too, so when you try to swap them onto a B310 the wheels will have crazy positive camber. :td:
Also, the 280ZX has vented rotors, not solid like the 280Z. :tu:
PostPosted: Mon Aug 02, 2010 8:33 pm
Awesome man! You really are the "Datsunfreak" you can just call me newbie :lol:
2006 Scion xB - DD
PostPosted: Wed Aug 04, 2010 12:11 am
Yeaahh :tu: I probably read too much into a ratsun post to assume that.
After seeing the 'restored.co.jp' Sunny, I've been eyeballing that 81' 210 Datsun by my house with the "Datsun" name on the grill. Stock wheels are so thin and sunk inwards.
Good job on your setup so far though. Longchamps look like a winner for sure. Nice score.
