It is currently Tue May 21, 2013 6:21 am
 Post subject: oxygen sensor for air/fuel ratio
PostPosted: Wed Feb 10, 2010 10:49 pm
has anyone installed an oxygen sensor for their carburetor type engines? i searched the net for this. it says it'll aid me in tuning my carb.
OEM knows best :)
PostPosted: Thu Feb 11, 2010 2:41 am
Get a wideband system:
AEM Uego
Innovate LC-1(with gauge)
These types of oxygen sensors are able to output a wider range (resolution) / more precise measurements of the air/fuel ratio. Most stock sensors are called narrow bands, as they only output rich or lean of 14.7:1 (stochiometric optimal gasoline to air ratio), while still helpful... a wideband is a much better tuning tool.
-Robert
My Build/Pic thread
PostPosted: Thu Feb 11, 2010 3:07 pm
I use a Techedge wideband in mine. Very handy and makes quick work of setting up a carb.
You can see the TE unit in the lower right corner near the firewall.
I do not have any pics of the display.
Cheers,
Charlie
If it ain't broke, modify it.
www.ffmsd.com
PostPosted: Fri Feb 12, 2010 3:24 am
thanks guys!
it seems that both are way off my budget... do you know a setup that's more from the ghetto. :D
OEM knows best :)
