It is currently Thu Jun 20, 2013 12:42 am
 Post subject: What Rear gearing was an option in the 70's
PostPosted: Mon Nov 30, 2009 6:06 pm
I have a 77 Arrow GT with a Direct-><-Connection LSD
and I'm woundering what gears came stock as well as optional through
the dealer as well as after market?
Question I have is, my rear gear seem really tall, and the motor Revs really high while on the Highway?
I think I have a 3:54?
PostPosted: Mon Nov 30, 2009 7:59 pm
3.9 to 1 with 1600cc with 4-speed, 3.545 with 1600cc automatic and 3.90 to 1 with 2000cc with 5-speed; 4.22 with 1600 and 5-speed; 3.55 to 1 with 2000cc and automatic.
PostPosted: Mon Nov 30, 2009 9:11 pm
4.22 :shock: holycow!
If this is right I should have a 3.90rear?
How do I go about finding out my ratio with out cracking open my pumpkin? :oops:
PostPosted: Mon Nov 30, 2009 9:14 pm
If you have a 3.90, 4000rpm in 4th gear should be right at 70-72mph. Try that first. If your RPMs at 70mph are lower, you have a lower number diff ratio, higher RPM, higher number ratio. :tu:
PostPosted: Mon Nov 30, 2009 9:26 pm
My arrow was a 2000 5sp maual, so should be a 3:90 if joes right.
But the Original owner (2 people before me) had a LSD instaled at the dealer when purchesed, but i'm not sure of the gearing?
I thought there was a math-matic way to spin the wheel 1 rotation and count the drive shaft rotations then us that math stuff to figure it out?
PostPosted: Mon Nov 30, 2009 9:54 pm
Yes, there is. It's just never worked for me. :P
The 70mph test is easier... 8)
PostPosted: Tue Dec 01, 2009 1:04 pm
You can also get gears off a sapporo rear end assuming yours is still a 180mm Give you the option of a 3.3 if you can find it
if you get hard core enough to look inside
3.54 has a 39 tooth ring with a 11 tooth pinion
3.90 has a 43 tooth ring with a 11 tooth pinion
4.22 has a 38 tooth ring with a 9 tooh pinion
31 3000gt vr4
88 starion x2, 83 starion
88 cordia turbo
86 mighty max 4x4
78 lancer
73 galant coupe
65 Debonair Deluxe
80's Hero
