It is currently Sat May 25, 2013 6:52 pm
 Post subject: Mitsubishi 1983 Gj Sigma turbo! (From Australia)
PostPosted: Thu Oct 08, 2009 6:59 pm
Hey guys its Matt here again just leting you know that i also have a GJ SIGMA turbo as well it runs a 2.6 block with forged pistons and bal bottom end and i also have put a later model injected Magna head on it as they have bigger inlet ports, 45mm Weber and water/methnol injection it also has a supra 5 speed and a ford 9 inch Lsd diff as for quater mile times it has run a 11.89 @ 116 mph so its a bit of fun too. :P
PostPosted: Wed Nov 18, 2009 12:05 am
how does the carb's induction sound like, when the turbo is spooling at the same time?
PostPosted: Fri Nov 27, 2009 10:46 am
Forgot about cars running Turbos with carbs, could be idea for my other LT that I can't sem to get running properly.
Seen some pressurised carb systems, but with yours having the fuel go through the compressor, does this cause any problems ?
PostPosted: Sat Nov 28, 2009 12:35 am
Nice.... I really dig this body style.
PostPosted: Wed Jan 20, 2010 4:13 am
Very nice Sigma!
Pls visit my blog dedicated to my GE Sigma!!!
http://bad-sig.blogspot.com
Also check out http://www.sigma-galant.com for all your oldschool Mitsubishi needs!!
 Post subject: Turbos with carbs
PostPosted: Wed Mar 31, 2010 2:40 pm
Very nice engine setup. Can you give more details about the engine please? Like how's that setup going so far?
PostPosted: Fri Apr 02, 2010 11:17 am
Oh man, nice setup.l I'm trying to gather the parts for a factory turbo setup right now? Does that 45 offer much better fuel than the solex?
Shaun
31 3000gt vr4
88 starion x2, 83 starion
88 cordia turbo
86 mighty max 4x4
78 lancer
73 galant coupe
65 Debonair Deluxe
80's Hero
PostPosted: Sun Apr 11, 2010 12:10 pm
Cool engine, looking like new. How clean collectors? my starting to rust and I want to brighten them somehow ...
mmc galant sigma hardtop eterna 1985... ilove it
viewtopic.php?p=86485#86485
PostPosted: Mon Apr 12, 2010 4:38 am
i've run a few suck through systems myself, on isuzu G series motors.. the fuel running through the compressor draws the heat out of the charge air, basically a chemical intercooling effect. the only downside to this is that in cold climates (ie under 5 degrees centigrade) you can end up with the throttle plate icing up to the point it sticks... so its a good system in hotter climates, not great in snow. and you cant run a normal intercooler system as it will turn into a bomb if u have a backfire. happily though water/methanol injection was invented, so you dont need any other type of intercooling..
over here grant williams FC RX7 tube frame drag car was running high 7's with a suck through carby turbo 13B about 10 years ago, running methanol. so yes they have mega power potential!
