It is currently Sat Apr 25, 2015 9:08 am
 Post subject: And Flatty makes 3
PostPosted: Tue Sep 29, 2009 8:41 pm
I got another one. Damn if these things aren't crack. 84 Starion LE. Having a random electrical issue, but I'll be able to figure it out eventually. Already replaced the airdam. Repainting, some 16s, couple other things in the works.
Chassis had 203K/mi on it(swapped to the digital speedo below). LOVE it.
First one: Red 88 - 245whp/312wtq-HIN: Nightshift-Chicago '07 WINNER
Next one: White 84 Flatty - T3/T4 - VELNAS - Saved from CERTAIN DEATH
PostPosted: Wed Sep 30, 2009 12:18 am
Nice find. 8)
PostPosted: Wed Sep 30, 2009 1:18 am
Very nice find. :tu::D Love the license plate.
1979 Plymouth Fire Arrow
2005 Scion xB Super Toaster
PostPosted: Wed Sep 30, 2009 4:51 am
Great purchase, very clean car.
PostPosted: Wed Sep 30, 2009 6:18 am
Thanks. It wasn't always as clean as it is now. The guy I originally bought it off of didn't take very good care of it, and the woman he bought it off of went thru engines like kleenex.
I was originally going to pick it up in St Louis, but as my train came into STL, I got a call that the engine blew. I had a guy local that picked it up to see what the issue was, and he found glitter mud in the pan, and could move the #2 rod alot. The guy was kind enough to give me one of his engines and get it going for me about 10 hours before I picked it up. Here's just a sample of what he had to fix:
Engine was rewired to BYPASS the fuseable links
Power steering pump was blocked off w/ JB weld
BOV vac line routed into the valve cover
eBay turbo(still need to replace)
No inspection plate
Engine NOT bolted down
See why my sig says, "saved from certain death." I'm still having a few issues, like trying to find where the ISC is supposed to plug into. The plug for it is gone and I can't find any wires(pertaining to this item) that aren't connected to anything.
But we're getting there. Spring's gonna be FUN.
PostPosted: Wed Sep 30, 2009 10:43 am
JNC Fanatic
there is a charcoal starion a few hours away from me with teh wheels n all. I beleive it has factory lsd as it has abs as well. It's been sitting for 10 years and the paint is shot, and I dont like getting cars that ahve sat outside for that long as mice have usually ruined the interior. One of these days I will find a decent flatty to build.
Nice car though. Sounds like it has some ghetto crap done to it.
88 starion
86 mighty max 4x4
78 lancer
65 Debonair Deluxe
80's Hero
PostPosted: Thu Oct 01, 2009 2:33 pm
Flatty LOVE!
PostPosted: Thu Oct 01, 2009 8:35 pm
JNC Fanatic
:D Very cool
PostPosted: Thu Nov 19, 2009 11:51 am
She runs and she's fixed! I drove her to work today! WHEEEEE!
- The MAFt that came w/ the car was for a 2G(<_<). They had to change some of the wiring for it to work. They confirmed all the voltages and readings.
- Idle is 13.6 on the wideband, 11.8 @ WOT. Don't remember what MID was. The T3/T4 is boosting @ 6 PSI.
- The idle is a bit rough @ times but doesn't die. If it starts to bog I tap the gas and it'll go back to idling @ about 1250 to 1500 RPM. I'm getting some blue smoke from the exhaust that I'm sure is from the eBay turbo that's on it. I'm also burning some oil, but I'm sure that's from the rear main leak.
- VELNAS is wonky. Thinks I'm getting 2 MPG. :/
Other than that, the car pulls pretty good for only 6 PSI. The w/g is supposed to be an 8 PSI setup, but I'm fine that it's running a little low for now. Last thing I need to do is blow something else out.
But damn to I miss power steering lol.
Here's some pics of how she looks now(sorry for the crappy pics):
PostPosted: Fri Nov 20, 2009 11:25 am
Have you fixed the VELNAS yet? Just found this link about with the proper wiring... http://starquest.i-x.net/viewtopic.php? ... a801e31a81
There is literally ZERO information about this system out there it seems! Was a two year only option and not every car got it I guess.
Off topic...you swapped to 16's? Looking to sell the factory alloys?
Brad D.
'83 Sapporo Technica; '84 Starion ES; '74 Colt; '80 Colt; '79 Cressida
PostPosted: Fri Nov 20, 2009 12:29 pm
Ooo, nice find. I'm not going to be tearing the interior apart until spring, but I'll certainly rock in on it then.
I would be looking to sell the alloys eventually. I've got the stock 15's on there now. Looking to get staggered 16s :P
PostPosted: Fri Nov 20, 2009 12:53 pm
JNC Fanatic
better get that power steering fixed or you are gonna toast that coupling on the steering shaft. These things are such a bear without out. I've broken a few lines over the years on my old starions.
88 starion
86 mighty max 4x4
78 lancer
65 Debonair Deluxe
80's Hero
PostPosted: Fri Nov 20, 2009 12:55 pm
Well I am looking for a decent set for the winter, I want to restore the Enkie 92's and run those in the spring. Maybe I will just through my Cressida wheels on for the winter.
Brad D.
PostPosted: Fri Nov 20, 2009 2:52 pm
JNC Fanatic
I have access to a set of 83 power steering lines, but they run a different pump than the 84. I managed to make them work on my challenger though.
88 starion
86 mighty max 4x4
78 lancer
65 Debonair Deluxe
80's Hero
PostPosted: Fri Nov 20, 2009 3:21 pm
I've got all the lines and everything but the pump. That's on the "spring" list :P
