It is currently Sat May 18, 2013 5:21 am
 Post subject: '82 Challenger- Running lights not illuminating
PostPosted: Mon Jul 20, 2009 8:23 am
I've had this problem ever since I bought the car, the brake lights work when I hit the brakes, but when I turn on the headlights (only 3 out of 4 work?) the tail-lights and markers don't light. I've checked all the bulbs and the stop light failure relay. I checked the inside of relay and visually it looks brand new.
All my signals, hazards, brakes and back up lights work, just not the running lights.
Got any ideas?
PostPosted: Thu Jul 23, 2009 7:02 am
Ok it keeps popping the #6 fuse, "Tail- Clearance meter illum".
I put a new one in and flipped on the lights. The fuse started heating up and was too hot to touch by the time it blew. I think the power to the running lights must be grounding out somewhere along the way.
Could this be a relay or should I mainly be looking at the wiring harness?
PostPosted: Thu Jul 23, 2009 7:28 pm
I think you need to check out Kev's project Hako build :)
