It is currently Sun May 19, 2013 7:31 pm
 Post subject: 1976 galant clock wiring
PostPosted: Sun Apr 04, 2010 6:52 am
looking for help, :oops:
i just want to know if anybody here knows how to wire the clock on a 76 galant?? wiring diagram might help a lot...thanks :cry:
PostPosted: Sun Apr 04, 2010 7:57 am
isn't there just a green wire and a blue wire?
PostPosted: Sun Apr 04, 2010 8:44 am
where will i connect the wires?? :oops:
PostPosted: Sun Apr 04, 2010 8:49 am
how bout you show some pics of the clock and wiring?
PostPosted: Sun Apr 04, 2010 2:51 pm
This will answer your questions and more...
http://www.sigma-galant.com/viewtopic.php?f=42&t=3280
PostPosted: Sun Apr 04, 2010 5:38 pm
wow!!!!!!!!!!!that really helps, thanks a lot dave...i will soon post pics of my galant there... :D
PostPosted: Sun Apr 04, 2010 7:35 pm
i just dismantled the clock on my galant but i found out that the wires are still connected...i am wondering why it is not working, how will i test or know if the clock is broke?? :cry:
PostPosted: Mon Apr 05, 2010 3:41 pm
I don't have a clock that works anymore either. The one I had in my car worked when I bought it, but stopped shortly after. The car hadn't been driven for at least 4 years before I got it.
That's part of the reason why I replaced it with a tacho. How hard are tacho's to get in the Philippines (that is where you are from isn't it?)?
I have a clock that goes in the console for models fitted with the tacho. It didn't work when I got it. I pulled it apart and cleaned the gears and now it works but only for about 10 seconds then stops again. I can't see any reason why it is stopping?
Maybe try to pull it apart. See if the motor runs unloaded? It might be similar to my problem?
PostPosted: Mon Apr 05, 2010 6:18 pm
Tachos were a bit hard to find here in the philippines, i tried todirectly hook up the clock into the battery and it only moves it "sec" hands a bit... :cry:
