It is currently Thu Jun 20, 2013 12:36 am
Post a new topicPost a reply Page 5 of 6   [ 108 posts ]
PostPosted: Wed Oct 21, 2009 10:49 pm
The gold wheels really go nicely with the car. :tu: :tu:
PostPosted: Fri Oct 23, 2009 1:41 pm
They are not too bad. I took them off my lancer since the engine blew something the other day. The offset isnt very good but it looks decent. The color is actually bronze, and a crappy paint job at that.
I need to buy some coil over sleaves and make some coilovers for the front and then figure out what to do with the rear.
31 3000gt vr4
88 starion x2, 83 starion
88 cordia turbo
86 mighty max 4x4
78 lancer
73 galant coupe
65 Debonair Deluxe
80's Hero
PostPosted: Thu Nov 19, 2009 1:49 am
Well, I was having some fun with friends the other day and did a 1 2 3 gear burnout and the car started idling rough and blowing some smoke out the valve cover vent, no exhaust smoke though. We pulled the hea off later that night and didnt see anything wrong. Tossed it back on so I could get home. I pulled the engine out last night as quite a few people convinced it was rings even though I had a gut feeling it was. Fresh engine with 1200 or so miles and only 12lbs of boost isnt enough to shaffter a ring or ringland.
Anyways, got the engine out and pulled it apart. pulled the pistons out, everything was f;n cherry. I was happy I was right, but it looks like I need to find a new head. The crack in it may have went all the way through or a valve seal blew out and I may have floated a valve.
Since I had the engine out I cut off a flywheel bolt that had been rounded off, and will buy a 11lbs fidanza flywheel and 6 puck clutch as my old clutch was slipping pretty good. The difference from the stock 35lbs flywheel and a fidanza is huge.
I might see about importing a magna head from australia. They flow more than a heavily ported head that we got here and dont have the shit aluminum casting.
Here are a few pics. Glad to see the inner engine paint job is holding up nicely. I need to clean her up though.
[/img]
31 3000gt vr4
88 cordia turbo
86 mighty max 4x4
78 lancer
73 galant coupe
65 Debonair Deluxe
80's Hero
PostPosted: Thu Nov 19, 2009 1:53 am
Little update on the car. I found a early 83 starion top of the line lsd, abs ac and 15inch wheels in the kjyard today, unfortunately it didnt have the stock hood.
I snagged the front strut assemblies, and the lsd for the challenger.
I also put in a order for some sw20 kyb agx for the front and will order some coil over sleaves and springs tomorrow.
I'm going to machine the starion lsd down to work with the 180mm challenger diff. Should be done in a week or 2 depending on how long it takes to get the parts.
I'm still headless, I have to go look in my parts garage and see if I sitll have a head with bent valves, if so, I may use it, or see if my old marnel is sitll in the machine shop. It's been a few years :cry:
31 3000gt vr4
88 cordia turbo
86 mighty max 4x4
78 lancer
73 galant coupe
65 Debonair Deluxe
80's Hero
PostPosted: Thu Nov 19, 2009 8:37 pm
A bit OT, but was that engine painted that orangey reddish color?
PostPosted: Thu Nov 19, 2009 10:37 pm
I did a quicky spray with some engine paint. I think it was chevy red. Then when my water line broke the rusty water sprayed all over the engine bay, that dark area is from the water, and then oil dripping down fromturning the engine around on the stand.
31 3000gt vr4
88 cordia turbo
86 mighty max 4x4
78 lancer
73 galant coupe
65 Debonair Deluxe
80's Hero
PostPosted: Fri Nov 20, 2009 2:38 am
well, I pulled the head off my old plymouth arrow truck that bent the intake valves due to the lower crank gear breaking from the previous owner installing it backwards.. I stripped that head down and will be installing the valves off another head onto it after I take them over to a friends and use their valve grinder.
God I hope I get this thing on the road again pretty soon. Both my vintage mitsu are down right now :roll:
31 3000gt vr4
88 cordia turbo
86 mighty max 4x4
78 lancer
73 galant coupe
65 Debonair Deluxe
80's Hero
PostPosted: Fri Nov 20, 2009 1:00 pm
The pleasures of driving old cars! Would you be able to grab the 15's off the junkyard car? Looking for a stock set for my flatty!
Brad D.
PostPosted: Fri Nov 20, 2009 2:51 pm
I can if they are still there but the yard isnt cheap. They are around 50 for a aluminum wheel and tire. The local u pull its keep getting bought out and the prices keep getting worse :roll: 170 bucks for 2 struts and a lsd center :td:
31 3000gt vr4
88 cordia turbo
86 mighty max 4x4
78 lancer
73 galant coupe
65 Debonair Deluxe
80's Hero
PostPosted: Fri Nov 20, 2009 3:54 pm
city hunter wrote:
No idea why they sold it as a a challenger, but look at the next gen of challenger, were the fwd k cars basically.
There was never a gen of Challenger that was FWD K car based. You have that mixed up with the Charger. One gen of Charger was the FWD Omni/024 platform changed to Charger/Turismo 2.2.
The Challenger has always been RWD, whether it be American or Japanese version. :|
1988 Acura Da3 Integra RS
1981 Toyota Te72 Corolla
1983 Toyota Ae72 Corolla
PostPosted: Fri Nov 20, 2009 5:01 pm
challengers are a galant lambda, the next gen galants are fwd. cant believe you are trying to correct me :roll:
31 3000gt vr4
88 cordia turbo
86 mighty max 4x4
78 lancer
73 galant coupe
65 Debonair Deluxe
80's Hero
PostPosted: Fri Nov 20, 2009 5:15 pm
What does the Galant fwd have to do with the Galant Lambda rwd(which we never got.. other than as the Challenger/Sapporo twins). Neither one has to do with the K car. Get it right. :roll:
Read your post, I corrected you on, it makes NO sense, dude.
Other than the 1st gen American Challenger, the 2nd gen Mitsu Challenger.. there were NO other gens of Challenger, which you say "is next gen is K car basically". The latest gen is the NEW 2009 American one.
Prove me wrong. Just because you own a Challenger doesn't make you an expert. I owned 2 Sapporos, a 78 and an 82. What am I special? :evil:
PostPosted: Fri Nov 20, 2009 10:57 pm
dud galants came as generations. The challenger is nothing more than a galant lambda Pull your head out of your ass. This generation lambda, eterna, etc.. were the last of the rwd galants, the next generation is front wheel drive.
31 3000gt vr4
88 cordia turbo
86 mighty max 4x4
78 lancer
73 galant coupe
65 Debonair Deluxe
80's Hero
PostPosted: Sat Nov 21, 2009 7:04 am
Pull your head outta your own ass, the fwd Galants still weren't Challengers. I know, the Galants came as generations(no shit).. the 1st US version Galant was the 1985 fwd version called the Sigma platform thru 88-89. The Galant Sigmas in the 80s in Japan were rwd.
PostPosted: Sat Nov 21, 2009 11:17 am
Mitsubishi_Classic_Owner wrote:
Careful now....you are arguing with somebody that hacks cars to make things work :wink:
LOL.. MacGyver style :lol:
PostPosted: Sat Nov 28, 2009 2:03 am
ohhhh shit, you are right, drunk posting ftmfw. I see what you are saying, I didnt quite read my post right lmao. Yeah you are right sorry man.
31 3000gt vr4
88 cordia turbo
86 mighty max 4x4
78 lancer
73 galant coupe
65 Debonair Deluxe
80's Hero
PostPosted: Sat Nov 28, 2009 10:04 am
It's cool. Not trying to sound like a no-it-all or nothing.. I just heard k-car and Galant and was like "what"? LOL :wink:
PostPosted: Thu Dec 10, 2009 11:26 pm
LMAO... you just gotta know Shaun...
-Robert
My Build/Pic thread
PostPosted: Fri Dec 11, 2009 12:17 am
Haha... found some old pics of him in my phone...
Yes, that's a super rare DOHC g54b head powering that BMW wheelbarrow.
-Robert
My Build/Pic thread
PostPosted: Fri Dec 11, 2009 12:22 am
man we so pimped out that wheelbarrel lmao
31 3000gt vr4
88 cordia turbo
86 mighty max 4x4
78 lancer
73 galant coupe
65 Debonair Deluxe
80's Hero
