Not much of a updatre but I made some progress tonight.
I got my new oem water banjo washers for the turbo, oilcooler banjo washers, and turbo gasket set.
I spent most of the night playing with the turbo figuring out where to clock it. The 14b has htis annoying notch on the cartridge and a pin on the compressor housing so it can only be installed one way. I had to file a new notch into the cartridge as I have it clocked way off from factory.
Anyhow, pic is of my 14b turbo mounted in a td05 housing ground out for a td05h wheel. This turbo should be fine for the time being. I know with the evo 3 housing these turbos will flow 300rwhp. I figure if I can get 250rwhp I will be happy. I know my torqu will be over 300 with some luck
I also installed the water linues for the heater core. Along with that I cut some of the cloth intercooler pipes to fit my intercooler configuration.
The only thing I have left in the engine bay right now is the following.
-Install starter
-Install dizzy
-install new vc gasket
-Secure starion wiring harness
-Install coil
-trim stock harness so it only fires the starter, or run the starion starter trigger. I'm undecided.
-Make some simple radiator mounts for the fiero radiator and tie in a puller fan.
-make a small oil cooler mount
-bolt the grill and bumper back on
-install the new pcv hose
-install a 1 way valve between the intake and booster off a starion
-install fuel filter, feed and return lines
Basically a ton of small things I can wrap up in a day easily.
Other things I still have to do with the car.
Interior
-reinstall blower motor
-clean and paint the dash parts
-install some black starion carpet
-install starion seats
-paint and clean the entire interior trim
Misc
-install banjo for the slave cylinder
-weld in the upper mount for the clutch pedal
-install clutch pedal to master rod
-redo all the brakes and flush brake system
-cut and weld up my resonator and side dump exhaust
-wire the couple wires off the starion harness.
-run a fuel pump power wire off the stock starion harness
I think thats about it. I should have this baby up and running in a few days.
This is how the engine sits now. I forgot to bolt on the wastegate actuator.
31 3000gt vr4
88 starion x2, 83 starion
88 cordia turbo
86 mighty max 4x4
78 lancer
73 galant coupe
65 Debonair Deluxe
80's Hero
