It is currently Sat May 18, 2013 10:12 pm
 Post subject: tranny swap question
PostPosted: Sat Jul 25, 2009 12:27 am
what mods would be necesarry to transplant a 5-speed tranny (from a boxie) to a 4g32 (chain type) from a 73 dodge colt?
PostPosted: Sat Jul 25, 2009 5:36 am
The transmission crossmember needs to be moved back some.
The two studs that bolt the mount to the transmission are spaced wider on the 5 speed. You can elongate the slots in the mount to work.
Occasionally the shifter opening will be a bit off but is easy to deal with.
Cheers,
Charlie
If it ain't broke, modify it.
www.ffmsd.com
PostPosted: Tue Jul 28, 2009 11:44 pm
Yeah that all the issues I had, also the drive shaft cover piece on it (where it slots into the gear box) cut off.
http://www.youtube.com/user/ColtSSR
'69 Honda C50
'79 Honda C50
'73 Honda ST90
Custom Honda Chaly
'85 RX7
'79 B1600
