It is currently Fri May 24, 2013 11:32 pm
 Post subject: what transmission is this?
PostPosted: Tue Aug 21, 2012 11:04 pm
anyone here know more about this kind of transmission?, it is a manual but it also use a torque converter from what it looked like, its from a jdm galant sapporo non turbo sohc 4g63
 Post subject: Re: what transmission is this?
PostPosted: Tue Aug 21, 2012 11:07 pm
PostPosted: Thu Aug 23, 2012 9:53 am
old colt would know
PostPosted: Thu Aug 23, 2012 10:09 am
matt wrote:
old colt would know
yep i hope he does, just wanna know if this ones worth using :)
PostPosted: Thu Aug 23, 2012 6:04 pm
FWIW, I believe Volkswagen had a similar set-up in some of the old Beetles. It shifted like a stick shift but had no clutch pedal...
PostPosted: Thu Aug 23, 2012 7:47 pm
i also think so, we had an auto stick bug before, but this galant still had a clutch pedal and well, a clutch... haha
i'm thinking how do you use this thing as i never driven one, let alone ever seen one, like do you use the clutch only in first gear when going from a stand still then no more clutching when its running or do you use it the same way a real manual and clutch every shift?, OLD COLT WHERE ART THOU?... hahaha
PostPosted: Fri Aug 24, 2012 6:41 am
Probably on Classic-Colt where he is more active? :wink:
I messaged him on ClassicColt, so he'll probably jump on here sometime soon. :)
91 Galant VR4 1350/2000
76 Colt Galant Coupe
75 Colt Galant Wagon
77 Colt Galant Wagon
PostPosted: Fri Aug 24, 2012 9:42 am
PostPosted: Fri Aug 24, 2012 4:13 pm
Some interesting reading that may shed some light on this transmission. http://www.allpar.com/mopar/fluidrive.html
PostPosted: Fri Aug 24, 2012 9:45 pm
thanks, almost the same set up or actually the same set up :)
PostPosted: Mon Aug 27, 2012 5:50 pm
FYI
Apparently the NSU RO 80 also used a torque converter and clutch:
The alternative NSU finally chose was the three-speed Saxomat, a semi-automatic transmission made by Fitchel & Sachs, also used by Porsche under the name Sportmatic. The Saxomat was essentially a standard three-speed synchromesh gearbox (with an overdrive top gear) with both a dry-plate clutch and a torque converter, sharing the engine's oil supply. The clutch was operated by a vacuum servo, controlled by a switch in the top of the shift lever; simply touching the gearshift knob would disengage the clutch. The Saxomat's torque converter offered two major advantages for the Ro 80. First, there was no direct mechanical connection between the engine and the gearbox (the gearbox input shaft was driven by the converter turbine), largely eliminating the overrun snatch. Second, the converter provided additional torque multiplication at lower speeds (2.3:1 at stall), helping to compensate for the Wankel's mediocre low-end torque, as well as reducing the need to shift in gentle driving. (A fully automatic transmission was apparently ruled out because it would have sapped too much engine power.)
(from here:http://ateupwithmotor.com/luxury-and-personal-luxury-cars/298-nsu-ro80-history.html?start=2)
PostPosted: Tue Aug 28, 2012 1:06 am
john wrote:
FYI
thanks also, but i think the fluidrive is much similar to the one i had which is seemingly only a manual tranny with just a torque converter, no servos or vacuums or switches or whatnot...
