It is currently Sat May 25, 2013 9:12 pm
 Post subject: 1988 Chrysler Conquest TSi
PostPosted: Thu Jun 07, 2012 12:44 am
Specs:
Automatic
117k
R04 (Mexican Red, ooohhh)
Sport Handling Package! (16x9 rears, and 16x8 fronts)
This car is 100% stock. It's an Arizona car 8) , so it's rust-free. It had been sitting, waiting, for almost 2 years, and not regulary driven for even more. It was by mere chance that this car came into my life, and I am so glad it did.
In a new light, years of neglect is sadly obvious:
Let's get to work!
More pics to come! :tu: Please comment, let me know what you think! :mrgreen:
Repair log:
31-Mar-12 replaced battery, replaced positive terminal, replaced throttle body to intake coupler, closed up hole in driver door, adjusted hatch, cleaned body ground under battery,
1-Apr-12 removed broken fuel feed coupler
7-Apr-12 replaced O2 sensor, replaced fuel filter, replaced fuel line, replaced turbo heat shield bracket, cleaned heat shield, painted cowl vent panels, painted wiper arms, acquired tail-light bulbs from junkyard
8-Apr-12 removed throttle body, disassembled throttle body
14-Apr-12
reattached throttle body, removed radiator, removed radiator hoses, replaced TB coolant hoses, replaced heater hoses, removed thermostat, removed fuel line
28-Apr-12 rebuilt dizzy, replaced distributor cap, removed power steeriing resorvoir, removed power steering resorvoir-to-pump-hose, replaced crank pulley seal, removed heat shield,
29-Apr-12 cleaned water pump, replaced water bump-bypass-hose, rebuilt power steering pump
4-Jun-12 replaced shifter bushings, removed both power steering hose/pipes, replaced speedometer seals
dates forgotten replaced fuel feed coupler, adjusted jet valves, torqued head bolts, painted valve cover
1979 Toyota Corolla SR5
 Post subject: Re: 1988 Chrysler Conquest TSi
PostPosted: Sat Jun 09, 2012 2:43 pm
what are you using to get into those really tiny spots to polish that?
PostPosted: Sat Jun 09, 2012 4:26 pm
I've just been using really strong degreaser (it's called Purple Power) and old hand towels, wrapped tight around my index and middle fingers. It works really well, but really dries out my fingers.
I see lots of people use WD40, a paint brush, and microfiber towels, but I have yet to try it.
PostPosted: Sun Jun 10, 2012 6:52 am
:tu: Nice! Love seeing another Starquest make it over here. So far so good man! Looks like it's cleaning up real nice!
Keep those pics coming.
PostPosted: Mon Jun 11, 2012 11:25 pm
wow cool. That stuff almost looks polished, it's insane!
