It is currently Thu May 23, 2013 5:37 am
 Post subject: Advice please - 4G93 + 5-speed gearbox.
PostPosted: Sat May 26, 2012 3:53 pm
There's a lot of info on using in-line 5-speed boxes with "Gen. 1" & "Gen. 2" 4G63s in rwd Lancers / Starions etc...
My application is a little different...
I have a 4G93 from a "Gen. 2" 1996/97 4wd GSR (CM5A) that I'm going to install in a box Lancer
and I'd like to avoid using an adapter plate if possible.
Was the "Gen 2" 4G93 from the 1996 GSR (CM5A) ever used "in-line" (rwd) in any Mitsubishi model?
If not, can you suggest any "in-line" 5-speed that can bolt to the 4G93?
Any advice and suggestions on the build will really be appreciated. Thanks.
Walk softly... and carry a BIG stick! Image
 Post subject: Re: Advice please - 4G93 + 5-speed gearbox.
PostPosted: Sat May 26, 2012 6:46 pm
I know any narrow block rwd trans (KM 119 or 132) will bolt to a 4G92 MIVEC. Should be the same for a 93?
Mark
PostPosted: Sat May 26, 2012 6:49 pm
I don't see any mention on wikipedia, so I will ask, is it a narrow block or wide block.
If the lower bellhousing bolts are 12.75" appart then you have a "narrow block" and if they are 13.75" apart you have a "wideblock".
PostPosted: Mon May 28, 2012 8:23 pm
Hi guys. Thanks a lot for the feedback.
Mark
I'm not sure. I don't have much info on these model gearboxes.
I know "narrow block" and "wide block" refers to the Gen 1 and Gen 2 4G63/64 blocks.
I didn't know that other Image engines were similar.
What are the actual measurements for the 4G93 "narrrow" and "wide" blocks?
PostPosted: Wed Jun 06, 2012 9:45 am
I'm not sure if this will help you specifically, but this website has a vast amount of information on rwd "Sirius" (4GXX) engine applications and transmission configurations, etc...
http://projectzerog.com/
PostPosted: Mon Oct 01, 2012 4:34 pm
Project Zero is a good place to start. As for the 4G9x motors they are all the same block within each generation except for they are progressively taller starting with the 4G92. All of the trans from those models are interchangeable. The heads swap as well with a few exceptions ( example: 97-98 4G93 doesn't have oil squirter ports for self adjusting lifters found on 99+ engines ).
Best bet would be a 4G64 though. Cheap and easy to find. DOHC can be found easily too. And best of all, its been done before by project zero.
PostPosted: Mon Oct 01, 2012 10:51 pm
Depends on where you live though, a 4g63 may not be as easily obtainable in some countries vs the other motors like the 4g93.
I also wouldn't think the wide block attribute would apply to these motors since they are coming out of a fwd based car in which case and not a rwd car where you might have a wideblock variant.
91 Galant VR4 1350/2000
76 Colt Galant Coupe
75 Colt Galant Wagon
77 Colt Galant Wagon
PostPosted: Tue Oct 02, 2012 1:09 pm
Correct, there are NO rwd variants for the 4G9x family of engines. Therefore the Wide Vs Narrow arguement is moot. This being said there may be other Mitsu transmissions that might work. The rwd swap has been done on this engine but it is much simlper to go for a 4G6x engine instead. As I understand there is no direct bolt up and some fabrication is required. Do a google search on 4G93 rwd...
http://www.rollaclub.com/board/topic/20 ... n-to-ke20/
Actually the 4G63 is certainly more available outside the USA. There have been variants in both front and rear wheel drive since the early '80s ( the Starion debuted in the US with the 4G54 as opposed to all other markets that recieved the 4G63 ).
PostPosted: Tue Oct 02, 2012 2:51 pm
I said some countries, not all, as not every country had the same line of cars as each other, but in the case of the Starion, both Europe and the GSR model in Japan were fitted with the 4g54. Different market, different availability ya know.
PostPosted: Tue Oct 02, 2012 4:04 pm
Getting back on track... the "4G93-into-KE20" swap used a KM132 gearbox from a GJ (Narrow) Image Sigma.
Link--> 4g93t In To Ke20.
This may be the answer to my problem...
However that 4G93 has the turbo on the right side of the engine (looking forward to the timing gear cover.)
My turbo is on the left side of the engine (looking forward to the timing gear cover.)
Is there any change in bell-housing pattern (on the block) from 1st-to-2nd generation 4G93 engines?
Accurate KM132 bolt-pattern dimensions or alternative gearbox suggestions will be welcomed.
Thanks
PostPosted: Tue Oct 02, 2012 5:23 pm
That could be a problem if your setup is flipped a 180 degrees much like the late 4g63s/Evo4-9s, is the starter located on the other side? I could see that being a problem with a KM132.
PostPosted: Tue Oct 02, 2012 5:36 pm
The gen1 and gen2 4G93 engine blocks are different. To compare, the gen1 block will bolt to a 6 bolt 4G63 and the gen2 will bolt to a 7 bolt 4g63. Had to do a search on thhe topic in my old Mirage forum...
Id think that a trans from a later Mitsubishi SUV like a pajero would work. Ill keep looking...
PostPosted: Tue Oct 02, 2012 7:27 pm
If that's the only issue to contend with I'll be happy.
A 'sectioned' and relocated starter housing (cup) will be a pita... but still "doable."
BTW is a version of the KM132 also found in the 2.6L Image Starion?
PostPosted: Tue Oct 02, 2012 10:56 pm
Sanctifier wrote:
i'm thinking that anybody who tries this will eventually give up like the rolla dude
PostPosted: Tue Oct 02, 2012 11:33 pm
Have a look at the following link which is of a mivec 4g92 to rwd http://www.mivec.co.nz/forums/viewtopic.php?f=44&t=7429
PostPosted: Wed Oct 03, 2012 7:22 pm
Nothing's impossible... but that's unlikely. Too much invested in equipment and parts. Take a look at the 'build' thread to see what I mean...
Link--> "GroceryGetter!" - Lancer 1800 GTX (A175X.)
Thanks for the link.
PostPosted: Fri Oct 05, 2012 1:08 pm
Following the statement i made earlier about 6 bolt and 7 bolt 4g63 trans bolting up to 1st and 2nd gen 4g9x engines, respectively, the only option i can find for the later versions of these engines is by making or purchasing an adapter plate. Buschar Racing comes up often in these conversations as they have made a plate that matches up to an early small/big block chevy trans. Unfortuneatly, everything else seems to point to the early model 4g9x and 4g6x engines in rwd swaps and not so much with the later models.
