It is currently Mon May 25, 2015 6:49 am
Post a new topicPost a reply Page 5 of 5   [ 93 posts ]
Go to page Previous  1, 2, 3, 4, 5
 Post subject: Re: Here's my '78 Arrow
PostPosted: Fri May 23, 2014 12:24 pm
She ate a piston.
I'll get a full assessment and pictures up ASAP.
PostPosted: Sat May 24, 2014 8:28 pm
What a cool car!
Sorry to learn about the piston. Hope you get her back on the road soon
Thanks for sharing
kolxoz
PostPosted: Thu Sep 25, 2014 12:34 pm
Thanks Matches
she's back under the knife.
http://www.ilostmymind.com/upload/imag0216.jpg
http://www.ilostmymind.com/upload/imag0219.jpg
http://www.ilostmymind.com/upload/imag0220.jpg
http://www.ilostmymind.com/upload/imag0218.jpg
http://www.ilostmymind.com/upload/imag0217_copy1.jpg
As you can see, the piston has a hole in it.
The jet valve shroud also got melted.
I'm making a plan of attack here. Once I get the bottom end out and torn apart, I'll let yall know the scoop.
PostPosted: Thu Sep 25, 2014 8:44 pm
Yours looks much nicer than mine, I like the color.
PostPosted: Fri Oct 10, 2014 12:53 pm
Thanks Toasty!
http://www.ilostmymind.com/wp-content/u ... 82426.jpeg
PostPosted: Tue Mar 17, 2015 5:05 pm
button wrote:
Got the Hid bulbs/balasts today.
They helped a ton.
I never took any pics with the bulbs that came in the housings, but I know these look a lot better just in the garage.
http://www.ilostmymind.com/upload/img_2 ... 220551.jpg
I used the housing mentioned above and this hid kit http://www.ebay.com/itm/110957394783
Low cost and makes for a pretty clean install. I am going to make brackets for mine instead of using the double sided tape that comes in the kit.
could you post pics of how you set this up? been looking to upgrade into HIDs for a while now. thanks.
PostPosted: Wed Mar 25, 2015 12:21 pm
hiimrico wrote:
They helped a ton.
That setup actually proved to be a downgrade on the street.
There was no real cutoff line. Just a mess of flares.
From driving behind friends, they don't like them.
It also seemed like I would outrun them quickly (under 100mph).
Everything seemed good in the garage, but it didn't turn out on the street.
I'll post an update of my new setup once I get some time/pics.
PostPosted: Fri Mar 27, 2015 8:09 am
http://www.ilostmymind.com/wp-content/u ... 71354.jpeg
http://www.ilostmymind.com/wp-content/u ... 84306.jpeg
http://www.ilostmymind.com/wp-content/u ... 96154.jpeg
These are the new lights. I'm not set on HIDs or halogens yet. The HIDs have a clean cutoff line in these housings. I only tested 55w. I would use 35w/55w for Hi/Lo.
I have the 35w and 100w Hella bulbs in for testing. They have a decent cutoff, but some minor flares.
I'll update with wiring stuff and picks of the actual light.
PostPosted: Wed Apr 01, 2015 9:30 am
make that thing run and come visit.
1973 Mitsubishi Galant Wagon, turbo, 4G63, fuel injected, on work wheels.
1975 Mitsubishi Galant Wagon, 2.6 5 speed, soon to be 2.4 efi, 4 speed auto
1976 Dodge Colt Sedan, 2.6 swapped, 3 speed auto.
follow me on instagram: @incorporatedx
PostPosted: Wed Apr 01, 2015 12:20 pm
Hah! That's on the list of stuff to do. Don't worry.
PostPosted: Wed Apr 08, 2015 9:05 am
http://www.ilostmymind.com/upload/img_2 ... 011405.jpg
Working on a 4-2-1 tri-y header.
I'm going to get her running, tuned, and dynoed in NA form first.
Then we can see what 15psi does.
PostPosted: Wed Apr 15, 2015 1:11 pm
http://www.ilostmymind.com/upload/imag0137.jpg
The new intake is coming together.
The initial design was a bit too tall. So I had to cut it down a bit and change the angle of the throttle body.
PostPosted: Thu May 14, 2015 10:54 am
Shes got bungs!
http://www.ilostmymind.com/wp-content/u ... ag0073.jpg
