It is currently Mon Mar 30, 2015 10:31 pm
Post a new topicPost a reply Page 4 of 5   [ 88 posts ]
 Post subject: Re: Here's my '78 Arrow
PostPosted: Wed Apr 10, 2013 12:14 pm
I stuffed a couple 1050cc FIC injectors in the conquest TBI and stacked some nuts and a washer as spacers.
Not as fancy as some machined billet, but quick, easy, cheap, and effective.
PostPosted: Wed Apr 10, 2013 8:57 pm
Warm weather seems to help a lot.
Here is my custom cut 36-1 trigger wheel for the g5xb early crank pully.
I suppose It could be welded onto a rubber inserted one as well. I'll probably get more cut in time.
PostPosted: Fri Apr 12, 2013 11:42 pm
So, I got a set of Black Velour seats from a 1987 Conquest TSi (you remember those right?) from quikconq on starquestclub.
Then I cleaned them up a little.
Then I wanted to see how they look in the Arrow. I was unsure how I would like them in there.
Until I found out the Arrow sliders bolted right on.
Then I sat in them. Ooooohhhhhhh.
Again, Black Velour. They kind of have a blue look to them.
This is where they are going.
:D
PostPosted: Sun Apr 28, 2013 2:51 pm
36-1 trigger wheel is mounted.
Silicone couplers are on the way.
Megasquirt is built.
I need to get crackin on that wiring.
PostPosted: Sun May 05, 2013 12:50 pm
Now we are talking.
But, hindsight being 20/20, I need to put the radiator in before the IC due to the location of the trans cooler and the bolts go in from the IC side.
I need to figure out if I am going to put the AIT in the intake pipe, or the IC pipe.
PostPosted: Thu May 09, 2013 6:44 pm
Hoods on. That's a good thing.
PostPosted: Thu May 09, 2013 7:48 pm
thought the fmic was going to be further forward?
1973 Mitsubishi Galant Wagon, turbo, 4G63, fuel injected, on work wheels.
1991 Mitsubishi Galant VR4
follow me on instagram: @incorporatedx
PostPosted: Thu May 09, 2013 9:54 pm
Hey, it lined up perfectly inside. Function.
Now the oil cooler might be another story. I don't know how that's going to go.
The front needs dropped and I need lower profile tires. I think the bigger rears are fine for now.
PostPosted: Sat May 11, 2013 9:57 pm
Oil cooler.
Looks like it should be able to handle the job.
I don't have a front plate, but you get the idea.
PostPosted: Fri May 31, 2013 9:47 am
It runs.
http://ilostmymind.com/upload/imag0033.jpg
And, my hooker aerochamber
http://ilostmymind.com/upload/imag0037.jpg
and a video.
http://youtu.be/ODT6Z77ESYo
PostPosted: Tue Jun 04, 2013 7:14 pm
runs and drives:
PostPosted: Wed Jun 05, 2013 6:29 pm
Hey thanks brotha
PostPosted: Thu Jun 06, 2013 12:49 am
If you two were closer I'd toss my g52b block in josh's trunk so you can have even more G52s lol. Got to get new valves for my g52b head before I throw it on the g54b :).
91 Galant VR4 1350/2000
76 Colt Galant Coupe
75 Colt Galant Wagon
77 Colt Galant Wagon
PostPosted: Fri Jun 07, 2013 6:08 am
NICE!!
http://s812.photobucket.com/user/pakundo951/media/cl6_zps6b098826.jpg.html
PostPosted: Sun Jun 09, 2013 6:13 am
I love the way it sits, so tough looking!
1988 Mazda RX-7
PostPosted: Fri Jun 21, 2013 9:22 am
Like anything else, fix one thing and another breaks.
So I had a charging issue, wound up being a bad alternator. No big deal. I put the old one on. Problem solved.
Then I test drive it and the steering is super touchy.
My whole steering system is wrecked.
Parts will be here Tuesday. From rockauto it was just under $100 for ball joints, inner and outer tierod ends, pitman arm, idler arm, water pump (thats making a rattly noise now as well), and headlights (my 35w hids are too much I think for the 50amp alternator).
Pics to come of the carnage/replacement.
PostPosted: Sat Jun 22, 2013 4:22 pm
Dear Pitman Arm,
I hate you.
That is all,
Jay
PostPosted: Thu Jun 27, 2013 7:52 pm
RockAuto should have some!
PostPosted: Thu Jun 27, 2013 9:12 pm
That's the thing, it is the best looking part of the steering, but I figured, hey, while i'm in there i'll get it all.
I broke 2 pitman arm pullers, and one ball joint puller. The damn thing still looks good. So it's staying and I have a spare pitman arm.
Otherwise it's all good, other than needing a professional alignment. I did it well, but I have some toe out, I'll play with it for a week before I finally decide.
PostPosted: Sat Apr 05, 2014 3:14 pm
Spring general checkup.
Compression is 175-175-173-179.
Still healthy.
Plugs look decent.
Got the tune dialed in a bit better. Maybe I'll get some dyno time soon.
