It is currently Fri May 24, 2013 12:45 pm
Post a new topicPost a reply Page 2 of 4   [ 69 posts ]
 Post subject: Re: Here's my '78 Arrow
PostPosted: Sun Apr 22, 2012 8:29 pm
I might make a grill if I get bored, but more than likely I won't.
I'll have to check the tire size. They are the cheapest and smallest tires the used tire place had. They mostly deal in 20" plus. :roll:
PostPosted: Mon Apr 23, 2012 7:00 pm
195/45-15s and another 1-2" down and that would be the sexiest Arrow going. 8)
PostPosted: Mon Apr 30, 2012 6:25 pm
195/60-15 front
215/60-15 rear
It looks fine. :wink:
anyways, I rebuilt the carb and eliminated the egr. still have lean spikes, but they are not anywhere near as bad. they dont slam your face into the steering wheel anymore, just slight discomfort.
it seems to be at about 3-9" vacuum.
It only goes to about 16-17:1 now, instead of maxing the gauge out. Still idles super lean as well, the idle enrichment screw still doesnt do anything.
ehh, carburation... I knew I shouldn't have wasted the time/money on that thang.
PostPosted: Wed May 02, 2012 8:46 pm
http://ilostmymind.com/upload/20120502_22.47.03.jpg <-over 800px wide and high
Installed a Conquest oil cooler, works quite well.
one line is hot, the other is cool.
PostPosted: Mon May 07, 2012 7:25 am
Forgot to update this.
http://ilostmymind.com/upload/20120505_17.52.13.jpg
I have not driven it yet. I'm waiting some epoxy to set before I can do anything. Plus it's been raining here.
PostPosted: Mon May 07, 2012 5:09 pm
Drove it today.
I figured out my fuel pumps max pressure is 4psi. That is not enough for the 7-10psi wastegate.
So I ordered a dirt cheap pump that pushes up to 14psi. E8153. Yes, it is designed for diesel, but I've read of it used on gasoline applications. It only needs to last one summer, if that.
PostPosted: Tue May 08, 2012 5:16 am
you can buy a higher pressure carb pump from auto zone.
why so much turbo?
because racecar.
"This is where mechanical excellence and one-thousand, four-hundred horsepower pays off."
76 Colt sedan, 73 Colt Wagon, 92 Galant VR4, 77 XS400
PostPosted: Tue May 08, 2012 7:16 pm
So much turbo?!? You make it seem like a gt3788r running 30psi!
My turbo is a 12a from a Conquest. So it has the 7psi/10psi wastegate. Yes, one port for 7psi, one for 10psi.
PostPosted: Sun May 13, 2012 8:31 pm
Made me a top hat. I want to say it is 2.25" pipe. Kept poppin the coupler off.
I have the primary jet as standard, and just removed the secondary jet. Gets a mid-11 afr under boost. 7 psi for now.
http://ilostmymind.com/upload/20120513_20.29.33.jpg
^bigger than 800px or whatever.^
PostPosted: Mon May 14, 2012 7:36 am
Depending on how smooth this drives and how reliable it is, I might have to do it to the sedan, just for the novelty of it being old school turbo'd.
So, sell me on it :D prove to me it's reliable haha.
have you considered the overdrive unit out of a dakota? I've been thinking about it, controlled via switch. I've got the website bookmarked, I'll post it when I get to my home computer later. With overdrive I'd be willing to drive the Colt anywhere, currently I dont like winding it up passed 60mph really.
PostPosted: Mon May 14, 2012 2:00 pm
driving above 60 is no beuno lol.
91 Galant VR4 1350/2000
76 Colt Galant Coupe
75 Colt Galant Wagon
77 Colt Galant Wagon
PostPosted: Tue May 15, 2012 8:35 am
it is with overdrive...
PostPosted: Thu Sep 13, 2012 8:53 pm
Going under the knife.
PostPosted: Tue Sep 18, 2012 10:33 pm
I broke 3 of the 4 hood bolts taking the hood off, the trans mount cross beam crumbled to rust chunks, but otherwise, so far so good.
I'm getting stuff cleaned up and chasing it with a few beers.
I am photoshopping some ideas for the setup.
http://ilostmymind.com/upload/img_20120 ... 364g63.jpg
^need to make a new intake manifold. That is pretty close to scale, and there is no way the intake will fit, and I am not going hydrobrakes.
http://ilostmymind.com/upload/img_20120 ... gauges.jpg
^The hill billy that ruined my dash, gave me a reason to make a new cover with some gauge holes. I plan to install one dash speaker and a low wattage amp fed by a bluetooth reciever. Who cares if its mixed mono.
This should be fun.
PostPosted: Fri Sep 28, 2012 7:49 am
PostPosted: Fri Sep 28, 2012 12:43 pm
:tu:
PostPosted: Thu Oct 04, 2012 9:42 pm
http://www.ilostmymind.com/upload/img_2 ... 194644.jpg
wood grained.
PostPosted: Thu Oct 04, 2012 10:18 pm
You could go Manual brakes :mrgreen:.
PostPosted: Fri Oct 05, 2012 7:53 am
I'll just make a new intake.
I have one drawn up, just need to order some bends and get some stuff cut.
I thought I was going to have enough room to remove the cas if I needed to, but there is a dang brake line in the way.
I downgraded my cams the other night, went from king kams to bc 280s. The bc 280s should net me a lot more low end power, where the king kams were more for all out drag/high rpms.
I have to decide on which ems I plan to use.
PostPosted: Fri Oct 05, 2012 8:13 am
dude, just put some 264's in it and knock off with the high power nonsense! :lol:
