It is currently Wed May 06, 2015 11:34 am
 Post subject: MMC 4G52 engine, carburetor Mikuni, need photo
PostPosted: Fri Oct 22, 2010 8:16 am
Hi!
I'm very need photos of mikuni carburetor connected in to 4G52 engine, with all vaccum, fuel, water heat connections. My car MMC Galant Lambda A133.
Mitsu Sapporo 79, 1.6 4G32B
PostPosted: Sat Oct 23, 2010 7:54 am
looks like you needed a manual more than just pictures, that is if those connection were out of place before your knowledge :)
PostPosted: Sat Oct 23, 2010 2:07 pm
Post a pic of what youve got and we can draw arrows on it of what goes where.
'69 Honda C50 Cub
'79 Honda C50 Cub
'73 Honda ST90 Mighty Dax
'70 Honda SL100 motosport
'75 Honda CF50 Chaly
'86 Honda Z50R
'85 RX7 FC3S
PostPosted: Mon Oct 25, 2010 2:05 am
ok, pair of photo, sorry for quality
http://forums.drom.ru/attachment.php?attachmentid=1286474&d=1287757584
http://forums.drom.ru/attachment.php?attachmentid=1286475&d=1287757615
 Post subject: Re: MMC 4G52 engine, carburetor Mikuni, need photo
PostPosted: Sun Oct 31, 2010 8:13 am
skd wrote:
Hi!
PostPosted: Mon Nov 01, 2010 10:56 pm
Not to sure about the other side, very different to mine, a few of those probably go to the auto choke that's usually on the side.
'69 Honda C50 Cub
'79 Honda C50 Cub
'86 Honda Z50R
'85 RX7 FC3S
PostPosted: Fri Nov 26, 2010 2:50 am
I have now a same problem...
Хорошему коту - и в декабре март..
PostPosted: Sat Nov 27, 2010 3:30 pm
skd wrote:
Id have to go look but from memory the rearmost thing on the minifold (with a square base) is brake booster, next is heater, little one on the botom is water to bottom of carb
do you have the rubber adapter bit that goes on small brass fitting next to the idle mixture screw?
the fitting on the diaphram housing is a fuel return
the little brass one under the carb on the inside goes to rocker cover
the others and the vac/temp switch ones are a little more difficult and you really need to grab the set from a wreckers to get all the fittings that go with the hoses ,
edit, arrr ok maybe not where u are Il get a photo of one later on , you will need T pieces etc or can you delete things like the egr valve and other pollution gear?
NSW AUST.
PostPosted: Mon Jan 10, 2011 2:46 am
Se-R wrote:
skd wrote:
Hi!
Se-R,
I've noticed the dual card. What carbs are those? I'm planning to get dual carbs for my 4g52 as well. What works best?
PostPosted: Mon Jan 10, 2011 2:57 am
skd wrote:
Hi!
Hi SKD,
Here's a picture of my Carburetor in my 4g52 engine:
PS: It's not stock. :)
PostPosted: Mon May 30, 2011 3:13 pm
rockerben143 wrote:
Se-R wrote:
skd wrote:
Hi!
Se-R,
<Hi sory for delay.. this are Stock dual carb, are mikuni 29/30mm twin barrel.
They are poor carb... the best I found, Dellorto DHLA ;)
PostPosted: Wed Jun 01, 2011 1:56 am
Se-R,
I see. Thanks for the info.
Ben
cron
