It is currently Sat May 25, 2013 1:05 am
 Post subject: Specs of Flywheel Bolts for 4g52 Engine?
PostPosted: Fri Mar 25, 2011 1:55 pm
Help Please!......anybody knows the size of bolts to use?
PostPosted: Sat Mar 26, 2011 11:47 pm
I can let you know in the morning if no one else gets back to you.
I'm assuming chain and belt driven are the same.
It's the typical mitsubishi bolt pattern which I thikn is 1.25 if I remember right. I think its ,m8 1.25 pitch or is it 1.0 pitch. I cant remember at the moment.
Take a fender bolt off the inside of the engine bay and it should screw in, then you can get an idea. They are maybe a half inch deep with lock washer.
31 3000gt vr4
88 starion x2, 83 starion
88 cordia turbo
86 mighty max 4x4
78 lancer
73 galant coupe
65 Debonair Deluxe
80's Hero
PostPosted: Sun Mar 27, 2011 9:15 am
thanks a lot!
 Post subject: Re: Specs of Flywheel Bolts for 4g52 Engine?
PostPosted: Wed Dec 07, 2011 2:06 am
don't flywheel bolts have to have "shallow" heads? like not a big bulky generic bolt. don't they also have to have higher elasticity or whatever the term is.
