It is currently Tue Jul 07, 2015 11:37 pm
Post a new topicPost a reply Page 1 of 2   [ 25 posts ]
 Post subject: breakerless??
PostPosted: Tue Sep 28, 2010 6:02 am
is there a breakerless ignition that can be retrofitted to a chain drive 4g32 motor?
PostPosted: Tue Sep 28, 2010 3:35 pm
JNC Fanatic
You could do pertronix. According to this it should fit.
http://www.streetperformance.com/part/p ... u-141.html
Or try adapting something off a later mitsu electronic ignition.
There isnt a bolt in electronic dizzy as far as i know though. I dont think the 4g37 will bolt in.
88 starion
86 mighty max 4x4
78 lancer
65 Debonair Deluxe
80's Hero
PostPosted: Wed Sep 29, 2010 10:18 am
Good question.. quite interested too.
Has anybody tried installing this?
PostPosted: Wed Sep 29, 2010 3:55 pm
JNC Fanatic
You find them quite often on older datsuns. I had something similar to this on my 240z, but it was some other sort of ignition setup.
88 starion
86 mighty max 4x4
78 lancer
65 Debonair Deluxe
80's Hero
PostPosted: Wed Sep 29, 2010 7:41 pm
I checked on that link and contacted streetsideauto, was planning to get one but had second thoughts when I found out that there's a no return policy on it once installed.
PostPosted: Wed Sep 29, 2010 8:44 pm
I have a Pertronix Flamethrower setup on my MGB and I love it. :tu: Someone told me that leaving your key in the ignition will drain your battery very quickly, though, once installed.
1988 Mazda RX-7
PostPosted: Wed Sep 29, 2010 11:54 pm
JNC Fanatic
might be correct, I seem to remember my coil getting very hot without the car running and the ignition on.
88 starion
86 mighty max 4x4
78 lancer
65 Debonair Deluxe
80's Hero
PostPosted: Thu Sep 30, 2010 1:17 pm
that's what i'm afraid of, or worse..if it won't work with my stock dizzy and I'd be stuck with it.
PostPosted: Thu Sep 30, 2010 2:55 pm
JNC Fanatic
call pertroinix up and ask them about it.
88 starion
86 mighty max 4x4
78 lancer
65 Debonair Deluxe
80's Hero
PostPosted: Thu Sep 30, 2010 9:16 pm
Yup, I did call them a couple of months ago. They asked for the code stamped on the dizzy, gave it to them & they said that they don't have any to match it.
PostPosted: Mon Oct 11, 2010 3:58 am
anyone tried using these?
http://www.autopartswarehouse.com/sku/D ... Drivetrain
PostPosted: Mon Oct 11, 2010 7:52 am
wow.. nice price :wink:
 Post subject: dist
PostPosted: Mon Oct 11, 2010 8:28 am
I bought an electronic distributor from mallory made for 4g32 awhile back
i check the part number for who wants it.
 Post subject: Re: dist
PostPosted: Tue Oct 12, 2010 7:03 am
is that for a timing chain driven 4g32?
PostPosted: Tue Oct 12, 2010 11:46 am
I use pointless distributor from 1986 MMC Galant 4G63 for my 4G32b
Mitsu Sapporo 79, 1.6 4G32B
 Post subject: dist
PostPosted: Tue Oct 12, 2010 2:08 pm
Yes for a chain type 4g32
PostPosted: Tue Oct 12, 2010 7:55 pm
i think your engine is a belt driven 4g32
PostPosted: Tue Oct 12, 2010 7:56 pm
thanks, i'll look into that, just post 'em in :)
 Post subject: dist
PostPosted: Tue Oct 12, 2010 9:52 pm
Originally it was belt type, I changed it to Saturn chain type its much better. The part number is 3763501
PostPosted: Fri Oct 15, 2010 4:19 pm
Depending which dizzy your car has the ignition from an early Montero will fit in.
Cheers,
Charlie
If it ain't broke, modify it.
