It is currently Wed May 22, 2013 6:03 pm
 Post subject: Lowering the wagon... what gives good ride???
PostPosted: Sun Jan 02, 2011 8:46 pm
Like the title says, I'm dropping the wagon: 2.5". Does anyone know a part #/vehicle of shorter REAR shocks that would work?
Thanks in advance.
-'bræd
PostPosted: Sun Jan 02, 2011 8:48 pm
Maybe you should tell us what kind of wagon? :mrgreen:
 OnlineProfile
PostPosted: Sun Jan 02, 2011 9:05 pm
1972 Dodge Colt Wagon 8)
 Post subject: owering
PostPosted: Mon Jan 03, 2011 12:41 pm
if youre using a lowering block youre not changing the shocks height and lenght. what you need to do is shorten the bump stop rubber and maybe get a stiffer shock absorber. Im using KYB gasadjust w/c is stiff enough for me.
 Post subject: lowering
PostPosted: Mon Jan 03, 2011 12:44 pm
The front setup Im not sure, maybe get a same circumference spring and cut it short, maybe someone can help you find a harder spring rate.
 Post subject: Re: owering
PostPosted: Mon Jan 03, 2011 9:14 pm
Thanks. Is there a part # - haven't been able to locate one, yet?
w/c???
Taking suggestions/recommendations, what gives a good ride...
-'bræd
PostPosted: Mon Jan 03, 2011 11:53 pm
comfortwise you can't beat blocks, but not to use for handling or horsepower
i'm using bilsteins from a toyota landcruiser, you just re-use the factory crushtube
but those might be too stiff for your liking
PostPosted: Tue Jan 04, 2011 8:54 am
What part # are those landcruiser shocks?
Well, with cars this light, compared to heavier cars using the same type of blocks(Mustangs, Camaros, etc.), the handling/hp issue shouldn't factor too heavily.
I'm using blocks and am looking for a shock, not overly harsh but will handle luggage and tag-alongs - me and the wife will be using it for local getaways and weekend cruising.
My wagon might see some added hp, in time, but it's a wagon. I'm not gonna auto-X or drift it - just cruising and some occasional highway "floating".
-'bræd
PostPosted: Tue Jan 04, 2011 12:24 pm
there was a thread on this in the colt forum, but i can't find it
forum search turns up nothing :roll:
PostPosted: Tue Jan 04, 2011 12:49 pm
Much appreciated, matt. Just trying to get a feel for what offers a decent ride - not rock hard, not too squishy. I tend to favor a bit stiffer than stock.
Thanks again.
-'bræd
