It is currently Sun May 19, 2013 10:05 pm
Post a new topicPost a reply Page 5 of 6   [ 105 posts ]
PostPosted: Tue Apr 06, 2010 1:19 am
Haha, should take the muffler off on that civic again... Vttttttteeeeeecccccczzzzzzzzzzzzzzzzzzzzzzzzzzzzzz at 3k rpm yo!!
-Robert
My Build/Pic thread
PostPosted: Thu Apr 15, 2010 1:53 am
lol, you cant hear hx vtec lmao
A little news, THe top end is back on, and I'm almost back where I was a few months ago lol.
I've taken some time fof the lancer to deal with issues with my daily drivers. I had to do a injector o ring change on the terror van today, busted a injector clip while I was at it, but she is all good now.
I bought a new turbo also, well new used. I have a holset he351cw... U havent decided what it will go on, but..... I dont think it will be the lancer lol.
31 3000gt vr4
88 starion x2, 83 starion
88 cordia turbo
86 mighty max 4x4
78 lancer
73 galant coupe
65 Debonair Deluxe
80's Hero
PostPosted: Thu Jun 17, 2010 3:45 am
It;s coming together. I dove into the wiring tonight. Spliced in the switched powers from the ignition switch wiring. And I'm runnign a nice heavyg auge wire from the battery to the fusebox so I can add additional accesories.
I picked up a 1g monbtero fusebox and will be running a 30a fuse for the ecu power. Both run an start will go through the same fuse. I believe it should work fine plus give me the added safety of a fused relay instead of hard wired.
I'm also adding a 80a hard fuse at the abttery for the constant 12v going into the cab for the montero fuse box.
I also picked up a battery and a harness for the alternator.
The eonly thign left to do in the engine bay is install plug wires, a water pipe coupling for the hater corem vac lines and a downpipe as far as I can tell at this point.
I think I may have it running tomorrow. :tu:
Other things I wrapped up. Installed the clutch pedal plunger n bled the clutch,. Gas pedal was installedm ecu mounted, eci relay mounted, and heat shielf for the turbo installed.
Im debating if I want to try installing the 4 link sapporo axle I have o go get the firearrow axle from the jyard. Either way, good progress for such a long on work stretch,
31 3000gt vr4
88 cordia turbo
86 mighty max 4x4
78 lancer
73 galant coupe
65 Debonair Deluxe
80's Hero
PostPosted: Fri Jun 25, 2010 1:36 am
drunk typing for the win. I should have some pics up tomorrow. The fuel pump wiring was a little more work than I thought.
I ended up using a long piece of pvc hose that I sued for my fuel injector cleaner rig to protect the wiring from sharp edges. I run it from the back of the seatbelt side panel all the way through the front seat rail hole so it is nice and protected. I also sringed it through the zipties that held up some other misc wiring which wa son the back ofthe rear seat x frame.
Ecu is mounted and tucked in behind the glove box as is the new fuse box. I'm real happy with the install. I should be test firing it in themorning as soon as I get the downpipe bolted on.
31 3000gt vr4
88 cordia turbo
86 mighty max 4x4
78 lancer
73 galant coupe
65 Debonair Deluxe
80's Hero
PostPosted: Tue Jul 06, 2010 9:45 am
where have i seen you before :oops:
PostPosted: Tue Jul 06, 2010 2:13 pm
finally made your way over here eh? :D
31 3000gt vr4
88 cordia turbo
86 mighty max 4x4
78 lancer
73 galant coupe
65 Debonair Deluxe
80's Hero
PostPosted: Tue Jul 06, 2010 7:55 pm
yup
PostPosted: Mon Aug 02, 2010 4:25 pm
Well it runs. Pretty loud open downpipe. I have a lot of work left now. GNeed to put trans fluid in, saccelerator cable, bolt shifter on, bolt seats in. Bolt ecu back in with fuse box. Loop heater core line, install a fan, finish exhaust, and probably some other crap. Oh, I need to actually run a alternator harness still
31 3000gt vr4
88 cordia turbo
86 mighty max 4x4
78 lancer
73 galant coupe
65 Debonair Deluxe
80's Hero
PostPosted: Tue Aug 03, 2010 5:58 pm
As usual few little tid bits are starting to pop up. For some reason I had taken off the water outlet line on the turbo. The fuel pump blockoff plate is leaking so I need to suck the oil out of the spot n reseal it.I dont seem to be leaking any fuel at least. I let it warm up a bit today since I finally put water in it. I found my clutch needs more bleeding as well. I migh be able to take it on a test drive tomorrow.
31 3000gt vr4
88 cordia turbo
86 mighty max 4x4
78 lancer
73 galant coupe
65 Debonair Deluxe
80's Hero
PostPosted: Mon Aug 09, 2010 11:27 pm
Well, other than cleaning out half a years worth of crap in the car, I need to find the throttle cable. and wire up the pusher fan. Other than that, this car is ready to drive, well at last it's maiden drive.
31 3000gt vr4
88 cordia turbo
86 mighty max 4x4
78 lancer
73 galant coupe
65 Debonair Deluxe
80's Hero
PostPosted: Mon Aug 09, 2010 11:41 pm
ben wrote:
Looks better w/o the rally lights imo :)
Love the old school Oregon plate too :tu:
Gotta say I agree there and if the intercooler could be hidden somehow or at least matt blacked so it didn't detract from the cars appearance as much she'd be a 10/10 from me.
Great project, love the way old Mitsu's just seem to love playing pass the parcel with there engines :tu:
'92 Mitsubishi Delica Super Exceed
'89 Mitsubishi Starion 2.6 Widebody
'87 Honda Civic Silver GT
'85 Honda Civic Gold DX with Brown Top
'79 Mitsubishi Celeste GSR
'78 Mitsubishi Sigma GE
'74 Datsun Laurel
PostPosted: Tue Aug 10, 2010 2:52 am
it shouldnt stick out so bad once the grill n lights are back on. I cant hide it anymore. It's literally up to the top of the upper bumper cover. And I have no other place to run pipes except for exactly where those pipes are coming off the intercooler.
31 3000gt vr4
88 cordia turbo
86 mighty max 4x4
78 lancer
73 galant coupe
65 Debonair Deluxe
80's Hero
PostPosted: Tue Aug 10, 2010 3:38 am
Yeah I can see you have had to squeeze alot in there already. Nice work
'74 Datsun Laurel
PostPosted: Tue Aug 10, 2010 7:18 pm
Took it for a test drive today. Seems to drive fine, I hadnt wired up the fan so I didnt go far. It's gonna be pretty damn fast when I can start beating on it. It takes basically no gas to move the car or keep it going down the road which is nice.
I wired up the fan just a while ago, but im gonna let it cool down and retorque the head tomorrow.
I gave it a quick wash too.
31 3000gt vr4
88 cordia turbo
86 mighty max 4x4
78 lancer
73 galant coupe
65 Debonair Deluxe
80's Hero
PostPosted: Wed Aug 11, 2010 12:24 am
Awesome!
'74 Datsun Laurel
PostPosted: Wed Aug 11, 2010 2:05 pm
Now if I could only figure out what I did with the screws for the other headlight bucket.
31 3000gt vr4
88 cordia turbo
86 mighty max 4x4
78 lancer
73 galant coupe
65 Debonair Deluxe
80's Hero
PostPosted: Fri Aug 13, 2010 12:02 am
I need a surge tank, a water temp gauge, and more fans.
31 3000gt vr4
88 cordia turbo
86 mighty max 4x4
78 lancer
73 galant coupe
65 Debonair Deluxe
80's Hero
PostPosted: Thu Aug 26, 2010 2:57 am
My alternator died, my fault, but it wasnt charging that goo to begin with, so eh, I accidently wired the exciter directorly to the positive on th battery. End of story, dead battery the next day and a alternator that would barely do 12.5v charge. Thats my hiold up right now. I either have to spend 100 bucks on a remanned or use my montero alternator which is a whoppin 50a. It should probably be enough for the old car2, but I may try and find a 96 millenia alternator. Apparently its a 110a bolt in.
I wired a honda shadow 500 puller fan to the car the other day, and I think I have enough airflow now, but I need to get the right coolant temp sensor in to confirm.
31 3000gt vr4
88 cordia turbo
86 mighty max 4x4
78 lancer
73 galant coupe
65 Debonair Deluxe
80's Hero
PostPosted: Thu Aug 26, 2010 2:17 pm
Nearly there mate, keep at it :D
'74 Datsun Laurel
PostPosted: Fri Aug 27, 2010 9:43 pm
What does the plug look like on the alternator out of curiousity? Is it a divided 2 pin or a straight 4 pin or something different?
Thinking of other possible alternator options and if it's the same as a dsm/gvr4? I run a 85amp Subawho legacy alternator on the vr4, because my stock 90amp died on me.
I've been looking into getting a high output alternator from these guys, I've heard good things of them on the subaru forums
http://www.maniacelectricmotors.com/index.html
91 Galant VR4 1350/2000
76 Colt Galant Coupe
75 Colt Galant Wagon
77 Colt Galant Wagon
