It is currently Fri May 24, 2013 2:52 am
 Post subject: MY Mitsubishi collection - GK Scorpion
PostPosted: Wed Aug 18, 2010 5:03 pm
GK Scorpion specs:
Block
• bored .060”
• forged alloy pistons (dome size 3.1cc which was a bit less than 1mm)
• moly rings (not sure about this, may have been chrome only at this oversize)
• notched upper block to suit gasket bore binder and further unshroud intake and exhaust valves (removed approximately 1mm material from top of bore above top ring level)
• compression est. 10.8:1
Head
• M7 Head
o extensive porting
o enlarge chamber around valves to improve clearance to extent possible confined by bore-binder
o new valve guides
o new stellite valve seats
o oversized exhaust valves
o machined and re-chamfer valve guides for clearance of retainers at max lift
o re surface cylinder head (removed .015”)
o valve springs tension tested and shimmed to correct tension (310lbs open)
• Cam (specs)
o duration
 Intake 345.8o (241.8o at 0.050”)
 Exhaust 373o (242.9o at 0.050”)
o lift
 Intake .4704”
 Exhaust .4625”
o overlap 129.5o
o if comparing to a common old style cam grind spec such as ’30-60’ or ‘40-70’, this cam grind is a 36.6-72.9
o cam is suited to efficient 3000rpm – 7000rpm operation
• Double valve springs
Other
• Magna (248cc) injectors
• XF T/B
• Commodore VN Air box
• Microtech Digi 1 ecu
• Low & Hi pressure fuel pumps
o 6psi rear lift pump (35 gph)
o 50psi high pressure pump (not sure about flow)
• H/Duty clutch
• Extractors, 2 ¼” exhaust
some photos to follow
PostPosted: Wed Aug 18, 2010 5:04 pm
http://s70.photobucket.com/albums/i107/gj_wagon/Scorp%20-%20motorkhana/
I'll put up some more when i get home and have more photos
PostPosted: Thu Aug 19, 2010 1:59 am
The body donor
PostPosted: Sun Aug 22, 2010 3:29 am
NICE.
Any dyno charts?? What brand are your pistons and exhaust manifold??
Any vids?? I want to hear that thing run... high comp 4g54 FTW.
-Robert
My Build/Pic thread
PostPosted: Fri Aug 27, 2010 1:05 am
NO Dyno run yet.
Not sure on the pistons. Exhaust manifold is newer then the photos custom tuned 4into1
Videos are one Youtube
http://www.youtube.com/user/brend0n123?feature=mhum#p/u
