It is currently Wed Jun 19, 2013 12:34 am
Post a new topicPost a reply Page 5 of 5   [ 96 posts ]
Go to page Previous  1, 2, 3, 4, 5
 Post subject: Re: '76 Colt Galant Coupe
PostPosted: Sat Aug 25, 2012 11:51 pm
lol blow dry your 4g63 at 65lbs/min. :wink:
91 Galant VR4 1350/2000
75 Colt Galant Wagon
77 Colt Galant Wagon
PostPosted: Mon Sep 24, 2012 7:09 pm
Going to order all my brake components (lines, MC) and Pressure Plate so I can install the transmission once and for all, then I can take measurements and call up Driftmotion to make me a driveshaft :).
PostPosted: Mon Sep 24, 2012 9:45 pm
aluminium tube d.s.?
PostPosted: Mon Sep 24, 2012 10:40 pm
No, no aluminum, that's not ideal for the twisties, sticking with Steel :) .
PostPosted: Sat Oct 13, 2012 6:17 am
Supra trans mounted at last!
PostPosted: Sat Oct 13, 2012 8:23 am
what you gonna drag race or something? :lol:
PostPosted: Sat Oct 13, 2012 12:03 pm
Race yes, drag race No lol.
PostPosted: Sat Oct 13, 2012 12:26 pm
nothing illegal i hope :shock:
else we'll have to throw you out of here :P
PostPosted: Sat Oct 13, 2012 1:35 pm
Road course racing :D.
PostPosted: Sat Oct 13, 2012 9:17 pm
cut out this tiny transmission hump meant for a KM110 4spd, will widen it later to suit the R154.
Bolt up new trans for mockup purposes
need to make some adjustments to fix this, we don't want to have to cut through the cross beam sections. It can actually sit lower than this if we remove the stock cross member which is supporting the trans to allow the car to remain mobile in the shop. Plan is to angle the motor just a tiny bit to the sweet spot where the tailshaft housing clears the tunnel just enough.
PostPosted: Mon Oct 15, 2012 10:14 pm
Pedal assembly mounting plate arrived, now hacking up the firewall will be easy and clean! Makes installing the wilwood stuff and hydraulic clutch easier.
PostPosted: Thu May 02, 2013 12:00 pm
Acquired some 5 lug front hubs and starion knuckles, just need some flatty starion struts!
PostPosted: Fri May 10, 2013 9:39 pm
Hell with it is how things went. Just need to get camber plates to correct the positive camber caused by the widebody struts, but as of today, 5 lug swap complete. Now I can order new brake and fuel lines (-3 AN & -6AN respectively) as well as all three master cylinders.
PostPosted: Sat May 11, 2013 3:40 pm
Left side still needs a coil cut to match the right side and sit right where it should with a lightened front end (dummy block and head with trans bolted in only).
PostPosted: Sat May 11, 2013 3:47 pm
Looking good :tu:
Give the poor thing a wash while it is outside enjoying the sun 8)
http://www.70scoltgalant.com/
PostPosted: Sat May 11, 2013 4:14 pm
Got to pressure wash the engine bay anyway lol. :lol:
